Combining multiple domoticz instances
alttab
Post by alttab »
Im having some range problems with my rfxcom 433mhz transceiver, but due to my smart energy meter i am bound to one location (downstairs) with my pi.
I would like to add a second raspberry pi with domoticz on another location (first floor) which will then be used with the rfxcom. This should solve my range problems.
However i do not want to manage 2 seperated instances, is it possible to use the 2 domoticz instances as 1 instance? Synchronisation of some kind?
alfred_j_kwak
Domoticz version: 2.3530
Re: Combining multiple domoticz instances
Post by alfred_j_kwak »
I use ser2net with other Pi and rfxcomm. I have two Pi:s and two rfxcomm:s. Two separate buildings with ethernet between. One Domoticz in main building.
alfred_j_kwak
Here is something: http://www.domoticz.com/forum/viewtopic ... 071#p65071
I can't offer any assistance just now cause I'm in service station with freezed car waiting tow truck... Perfect saturday.
alttab
Post by alttab »
Thanks, is it stable?
alttab
Post by alttab »
Me neither. Monday evening i will test it.
I will look into device sharing too but ser2net seems.more transparant.
alfred_j_kwak
alttab wrote:Thanks, is it stable?
It has been running since my post. Only one problem has been - I don't have real ethernet between buildings, so I'm using powerline plugs to transfer net via electric cabling. Yesterday 'net' was down - maybe minus 30 celcius is too much for Raspberry or powerline plug. Heating is in todo list. :)
But other than that zero problems.
alttab
Post by alttab »
Ok sounds good. Even better for me would to share the usb p1 converter over ethernet instead of rfxcom.
Then i would use my main pi on the first floor.
Rfxcom is more critical than power usage metrics.
Users browsing this forum: eddieb, Google [Bot] and 1 guest
