Measuring Gas and electric
har0543
Domoticz version: 2022.2
Post by har0543 »
power counters used for Gas
domoticz counters.jpg (59.8 KiB) Viewed 2112 times
I am new to this forum and also new in de Domoticz.
I started with some measuring tasks, temperature, air pressure and the use of water, gas and power.
I use several esp8266 units with the espeasy firmware. This is a great option for non-programmers.
For the gas and power I use pulse counters.
I have two questions:
1) How is Domoticz calculating the pulses to KWH and M3 Values?
2) For the poweruse I have 2 items, 1 gives the use every 5 minutes and another once the hour. This gives me the option to find peaks in the powerconsuption.
For the use of the gas there is no such option. The gas use is shown once per hour. And I made an extra Powerusage. Is there a way to change the units from Watt to m3 with right calculation?
In the image stoomverbruik and gasverbruik are the items for once per hour.
The verbruik gas (used gas) is the item I would like to change.
kind regards
Har
Gerwin1967
Domoticz version: latest
Re: Measuring Gas and electric
Post by Gerwin1967 »
Do If I understand you correctly the counter that states "verbruik gas" with 0.0 Watt behind it is a esp8266 pulse punter.
You should be able by selecting Aanpassen to change from electric consumption to gas consumption or water consumption what ever is needed.
Hoffan72
Target OS: OS X
Post by Hoffan72 »
How did you do to get the second meter on power working?
