Exclude and then include again will Z-wave ID change?
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
when you have a aeotec Gen5 Zstick You can easlily include/exclude devices locally(not with domoticz)
my question.
when you exclude lest say device 7 and right after that include the same device/module again will it assign the same ID?
so I am talking about the Zwave ID's, not the Domoticz IDX(which will probably change)
ThinkPad
Re: Exclude and then include again will Z-wave ID change?
Post by ThinkPad »
It will change, i thought.
Gravityz
Post by Gravityz »
ok bummer
i have read that when you attach a temperature sensor you need to exclude/include the module again.
Egregius
Domoticz version: v2024.7
Post by Egregius »
It will get the largest ID + 1.
Example:
You have ID's from 1 till 14. You exclude 7, after inclusion the new ID will be 15.
If you exclude 14 it will be 14 again because the largest ID after exclusion was 13.
So, if it's the last included device you want to exclude/include the ID won't change.
Edit: this was a mis, seems that every exclude/include generates a new node ID.
Gravityz
Post by Gravityz »
ok thanks
then I am in the clear
the last device is 10, which is de device i need to exclude/include because of connecting a temperature sensor.
now the second question is will those domoticz IDX numbers change or will it only add the IDX numbers for the newly added Temperature sensors
Egregius wrote:It will get the largest ID + 1.
Example:
Egregius
Post by Egregius »
The IDX numbers aren't that important. Why are you afraid they will change?
But, since the node ID won't change there's a great chance the devices will stay just the same. Not sure, but pretty shure. ;)
Gravityz
Post by Gravityz »
not afraid. i just do not like al thoose double device id's which i need to delete afterwards.
thanks for the answer.
i will try out as soon as ik get my temp probe
Egregius wrote:The IDX numbers aren't that important. Why are you afraid they will change?
Egregius
Post by Egregius »
I know that feeling. Sometimes a pain to find all obsolete devices after exclusion.
Gravityz
Post by Gravityz »
i tried it today.
exclude number 10
include
the module gets number 11
maybee this was for the best because now i could delete every device starting with A
Egregius
Post by Egregius »
Yes, sorry for that. I tought I saw that in the past. Yesterday I learned that it isn't the case.
