I've seen Robert's updaterostyk wrote:Works good.
Robert today implementing some code changes regarding set temperature (to be able to work with clock mode as well) and introduce a server mode whcih also look reasonable because now for every command you use authentication every cycle which is not so good from server (bosch) side.
We should work like iOs/Android app: open connection -> authenticate > execute commands -> execute next command ... repeat.
Nefit Easy™
pepijn
Re: Nefit Easy™ client library (How to install on the Pi)
pepijn
I did not add Low level GET and PUT operations, my intention is to add these values human readable into the dropdown list.rostyk wrote:i know it still not finished but i missing get and put commands in node.
For example i want to read /heatingCircuits/hc1/actualSupplyTemperature
its not possible to do up to now from node-red interface
Doler
Thanks for all your efforts, being able to see my Nefit Easy in Domoticz makes me happypepijn wrote:
TESTERS NEEDED
I published the first version of the Node to github.
You can install it using:
sudo npm install pepijng/node-red-contrib-nefit-easy -g
Installed the new node with success, had to reboot to make it appear in node-red.
Used your sample flow for testing: after configuring the nefit easy nodes and Domoticz idx-numbers it started to work. Had one error 'lost server connection' but that was solved with a restart. Didn't see that since.
One thing that doesn't work is the update of the set-point. I cannot change it from Domoticz, changes applied using the android app came in very slowly (should take max 30 seconds, right?). I had the same problem with your previous solution using the scripts (others mentioned the problem too). When I change the setpoint running the script nefit-set from the command line things work fine! There must be something that I missed?
Appreciate your help.
Thanks, Mark
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
pepijn
Can set your thermostat to manual before changing the temperature from Domoticz? (this is a known issue)Doler wrote:Thanks for all your efforts, being able to see my Nefit Easy in Domoticz makes me happypepijn wrote:
TESTERS NEEDED
sudo npm install pepijng/node-red-contrib-nefit-easy -g![]()
Thanks, Mark
Doler
I tried that #and did before# but to no avail. As said running the script nefit-set or the command easy set temperature "$*" from the command line does work.pepijn wrote:
Can set your thermostat to manual before changing the temperature from Domoticz? #this is a known issue#
When I set the setpoint in Domoticz I see a '#Virtual# Thermostat #Nefit | Setpoint#' in the log but nothing happens.
Mark
pepijn
New version:
- Using nefit-easy-client as dependency
- Fixed set temperature when program is active
sudo npm remove -g node-red-contrib-nefit-easy
sudo npm install -g pepijng/node-red-contrib-nefit-easy
sudo service nodered restart
rostyk
- Domoticz version: 2.4028
ok. then i added this feature by configuring some backend scriptpepijn wrote:I did not add Low level GET and PUT operations, my intention is to add these values human readable into the dropdown list.rostyk wrote:i know it still not finished but i missing get and put commands in node.
http://rostyk.net/test/node_Red_easy.jpg
yes i forgot rbe filter in a node flowtemp when making screenshot
pepijn
You modified Robert's library file, it's better to solve it within the Nefit-easy.js file. I just removed the library from my code and added a dependency.rostyk wrote:ok. then i added this feature by configuring some backend scriptpepijn wrote:I did not add Low level GET and PUT operations, my intention is to add these values human readable into the dropdown list.rostyk wrote:i know it still not finished but i missing get and put commands in node.
its not possible to do up to now from node-red interface![]()
Doler
Updated without a hassle but it doesn't help my case. See if I (being a noob) understand things correct:pepijn wrote:New version:install
sudo npm remove -g node-red-contrib-nefit-easy sudo npm install -g pepijng/node-red-contrib-nefit-easy sudo service nodered restart
MQTT is listening to device updates in Domoticz. When the Setpoint is changed, MQTT and Domoticz communicate using json and when ok, execute action. My guess is that there is something going wrong in communication: I see the log message in Domoticz but see nothing in the debug window in Node-RED. Did I miss some pre-requisites or configuration details?
Thanks, Mark
pepijn
Can you check the device id in filter checkpoint idxDoler wrote:Updated without a hassle but it doesn't help my case. See if I (being a noob) understand things correct:pepijn wrote:New version:install
Thanks, Mark
Doler
That's the thing I overlooked. It works now, thanks a lot.pepijn wrote:Can you check the device id in filter checkpoint idxDoler wrote:Updated without a hassle but it doesn't help my case. See if I (being a noob) understand things correct:pepijn wrote:New version:install
Thanks, Mark
Mark
renebiemans
Hi I've tried to get the client working but I can't get it working on a clean install of domoticz(with the SD card for Raspberry PI). I tried on RPI1 and PRI2. When I look in node-red I can't see the nefit easy part. Are there some parts that has to be installed before installing the client?
During the installation the installer gives an warning about engine wanted node :>=4.0 current node: 0.12.1 npm 2.5.1 I tried to install a newer version of node.js but not maybe not with succes.
pepijn
Did you restart node-red after installing the nefit-easy node?renebiemans wrote:Hi I've tried to get the client working but I can't get it working on a clean install of domoticz(with the SD card for Raspberry PI). I tried on RPI1 and PRI2. When I look in node-red I can't see the nefit easy part. Are there some parts that has to be installed before installing the client?
rostyk
@pepijn
i got once per hour a error with crash of node-red:
looks like connection are closed (dropped by nefit easy) after a 40-50 minutes.
i will report after clean reinstall (probably caused by mine changes in a code)
Error: read ECONNRESET
at exports._errnoException (util.js:870:11)
at TLSWrap.onread (net.js:544:26)
pepijn
You need to upgrade NodeJS to > 4.0.0 , the instructions are on the beginning of this post.pepijn wrote:Did you restart node-red after installing the nefit-easy node?renebiemans wrote:Hi I've tried to get the client working but I can't get it working on a clean install of domoticz(with the SD card for Raspberry PI). I tried on RPI1 and PRI2. When I look in node-red I can't see the nefit easy part. Are there some parts that has to be installed before installing the client?
pepijn
New version available, it includes the flow temperaturerostyk wrote:ok. then i added this feature by configuring some backend scriptpepijn wrote:I did not add Low level GET and PUT operations, my intention is to add these values human readable into the dropdown list.rostyk wrote:i know it still not finished but i missing get and put commands in node.
Doler
I have the same problem, 7 minutes after a restart of red-noderostyk wrote:@pepijn
i got once per hour a error with crash of node-red:looks like connection are closed (dropped by nefit easy) after a 40-50 minutes.Code: Select all
Error: read ECONNRESET at exports._errnoException (util.js:870:11) at TLSWrap.onread (net.js:544:26)
6 Jan 17:26:26 - [red] Uncaught Exception:
6 Jan 17:26:26 - Error: read ECONNRESET
at exports._errnoException (util.js:855:11)
at TLSWrap.onread (net.js:544:26)Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
renebiemans
Yes I tried that. I think the problem is in deed with the update of node. I have tried to update to 5.3.0 but I get an error when I want to copy to package with the command: sudo cp -R * /usr/local/Re: Nefit Easy™ client library (How to install on the Pi)
Postby pepijn » Wednesday 06 January 2016 16:57
I get the following error: cp: cannot create regular file '/usr/local/bin/node': text file busy. I allready tried to reboot remove the files but I can't get premission. I also tried a complete clean installation(sd image).
dorenberg
- Domoticz version: 4.10982
you have to stop node-red first before you can issue that command.renebiemans wrote:Yes I tried that. I think the problem is in deed with the update of node. I have tried to update to 5.3.0 but I get an error when I want to copy to package with the command: sudo cp -R * /usr/local/Re: Nefit Easy™ client library (How to install on the Pi)
sudo ps -ef | grep node
sudo /etc/init.d/nodered stop
node -v
(VERSIE 0.10.4 OID ZOU ER MOETEN STAAN)
wget https://nodejs.org/dist/v5.3.0/node-v5. ... v7l.tar.gz
tar -xvf node-v5.3.0-linux-armv7l.tar.gz
cd node-v5.3.0-linux-armv7l
node -v
(VERSIE 5.3.0 ZOU ER MOETEN STAAN)
pepijn
It seems to be a bug in the Nefit Easy library.Doler wrote:I have the same problem, 7 minutes after a restart of red-noderostyk wrote:@pepijn
i will report after clean reinstall (probably caused by mine changes in a code)MarkCode: Select all
6 Jan 17:26:26 - [red] Uncaught Exception: 6 Jan 17:26:26 - Error: read ECONNRESET at exports._errnoException (util.js:855:11) at TLSWrap.onread (net.js:544:26)
https://github.com/robertklep/nefit-easy-core/issues/2
