Show DENON AV reciever input in Text switch
- Egregius
- Domoticz version: v2024.7
Re: Show DENON AV reciever input in Text switch
Why is everybody so afraid of running a webserver with PHP scripts?
mKotek
I do not think, anyone is afraid. In fact I am currently testing your solution, but I think, having a small remote icon next to Denon in Domoticz, invoking a controller like for Kodi would be nice. I have implemented the volume control using slider and a short LUA script, but for source change I have put just switches that switch into my OSMC source and back to my cable/sattelite, same for Chromecast and back to cable/sattelite, that is being used when Denon is switched off.Egregius wrote:Why is everybody so afraid of running a webserver with PHP scripts?
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
dijkdj
I'm hesitating because it would further increase the load on my Pi. There are enough protocols available in Domoticz to do it without PHP and PHP has no functionality in this regard that could not be solved in any other way. Only thing is that you need to take the time to program it.
pepeEL
But can you explaine me step by step how i must configure it?Egregius wrote:Why is everybody so afraid of running a webserver with PHP scripts?
But it is not the same as manufacturer web interface from Denon ?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
- Egregius
The CPU usage will not be very different if you run scripts as PHP or LUA or Bash or ...dijkdj wrote:I'm hesitating because it would further increase the load on my Pi.
My average CPU usage is 0,2%...
There are hundreds of tutorials online on how to install Apache or nginx with php support.pepeEL wrote: But can you explaine me step by step how i must configure it?
alfred_j_kwak
- Domoticz version: 2.3530
I used first post from this thread to enable run php scripts: viewtopic.php?f=38&t=6088Egregius wrote:The CPU usage will not be very different if you run scripts as PHP or LUA or Bash or ...dijkdj wrote:I'm hesitating because it would further increase the load on my Pi.
pepeEL
But then how control Denon ? How create button/device in domoticz?
dijkdj
You can create a custom tab, by placing a file in your domoticz folder (don't know the name of the folder)
pepeEL
But in this folder placing file with script from first post ?
Panda
I had the problem that whenever the Input contained a spacing in the nam for example "Online Music" it would give me a bad web request, because it tried to send domoticz a curl command with an space in it which domoticz doesn't understand.
To fix this replace the #input part with the following code
# Input
AVinput=`grep -oP '(?<=<InputFuncSelect><value>).*(?=</value)' test.txt`
# Process the AVinput to replace spaces with %20 (so domoticz knows what to do)
# Instead of giving a bad request
AVinput1=`echo "$AVinput" | sed -e 's/ /%20/g'`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$DENON_INPUT_IDX&nvalue=0&svalue=$AVinput1"-
pepeEL
I read this thread and i dont understand how i can do it. Please users write me step by step how add this to domoticz to cvontrol DENON.
- Egregius
Depends on what you want.
Do you want several pushbuttons inside domoticz to do some functions?
Then add in the ON actions for example "http://192.168.0.2/MainZone/index.put.a ... tion/TUNER
If you want the grey controlpanel I wrote you'll need a PHP enabled webserver and host the page there. Google knows everything about running webservers with PHP.
pepeEL
But how use php panel grey in domoticz ?
Ok i done push button but when i have info about volume and it is not correct. My Denon has set 33 vol but in domoticz show me 47 vol.
Is any chance to add button to set Volume in Domoticz(up, down) in one button ?
And we can use manual button with selector ? How works and configure button with selector ? Maybe this type we can use to configure button with turn on/off Denon and select INPUT. But i dont know how configure it.
- Egregius
You cannot use my grey control panel inside domoticz.
With an on/off switch you could simulate volume up/down but that happens at maximum 1 step at a time. Painly slow.
pepeEL
But can you describe me step by step how use your grey panel ?
Anyone know how use and configure manual switch with selector ?
pepeEL
Ok but how then use it in Domoticz?
- Egregius
You can not used it inside domoticz!
It a seperate webpage.
pepeEL
In custom tab ? But it not read php.
pepeEL
But separate page i have when i go to IP DENON...
