No new items in domoticz
dakkar
Post by dakkar »
Hello
i'm trying to setup domoticz with mysensors but i can't mange to see new nodes :(
What have i done?
* installed domoticz
* configured mysensors ethernet connection
* clicked on "setup" in the hardware tab
* see nothing
* nothing in the devices tab too
logs:
domoticz
2016-01-03 22:52:34.878 Domoticz V2.3530 (c)2012-2015 GizMoCuz
2016-01-03 22:52:34.880 Build Hash: 9eef872, Date: 2015-11-01 11:41:18
2016-01-03 22:52:34.882 System: Raspberry Pi
2016-01-03 22:52:34.884 Startup Path: /home/domoticz/domoticz/
2016-01-03 22:52:34.945 Sunrise: 08:12:00 SunSet:16:26:00
2016-01-03 22:52:34.946 EventSystem: reset all events...
2016-01-03 22:52:34.960 Active notification subsystems: (0/10)
2016-01-03 22:52:34.963 Webserver started on port: 8080
2016-01-03 22:52:34.968 Started shared server on: ::
2016-01-03 22:52:36.971 EventSystem: reset all events...
2016-01-03 22:52:36.972 EventSystem: reset all device statuses...
2016-01-03 22:52:36.973 EventSystem: Started
2016-01-03 22:52:38.971 MySensors: connected to: 192.168.100.10:5003
2016-01-03 22:52:42.903 Incoming connection from: 192.168.200.8
2016-01-03 22:57:51.987 Active notification subsystems: (0/10)
mysensor node:
Starting sensor (RNNNAS, 1.6.0-beta)
Radio init successful.
req id
send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
req id
req id
req id
Init complete, id=255, parent=0, distance=1
req id
req id
So no node ID from controller? But result is the same, even if i use a static nodeID
gateway:
0;255;3;0;9;Starting gateway (RNNGAS, 1.6.0-beta)
0;255;3;0;9;Radio init successful.
IP: 192.168.100.10
0;255;3;0;9;Init complete, id=0, parent=0, distance=0
0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
The reads are coming from the node trying to get an ID
so node => gateway itself seems fine.
Any Idea?
dakkar
Re: No new items in domoticz
Post by dakkar »
hmm its working now. don't ask me what exactly fixed it. must have been a combination of wiping the nodes eeprom, flashing them all and a lot of try n error
D'rMorris
Post by D'rMorris »
dakkar wrote:hmm its working now. don't ask me what exactly fixed it. must have been a combination of wiping the nodes eeprom, flashing them all and a lot of try n error
You probably already know this, but also note that the Mysensors node will only appear after it sends its first value successfully to Domoticz. If nothing is send, then it will never appear.
