Idiots guide to Raspberry Pi Installation
TheBod
Re: Idiots guide to Raspberry Pi Installation
By the way, how do I load the Domoticz screen on the Pi rather than through the pc?
- Westcott
Thanks Jos.jvdz wrote:Just follow the Wiki i linked in one of the previous posts, which also has the info for the RPI image.Westcott wrote: Thanks, but that also only has Windows setup files.
Jos
Are you saying that
domoticz-raspberrypi-sdcard-3530.7z 2015-11-01 248.6 MB
is the one to use?
TheBod
That is the one that I used. The image file is 2,078,277,632 bytes
TheBod
Extract the zip file and there is a file in there called "domoticz-raspberrypi-sdcard-3530.img". This is what you need to copy to the SD Card
- Westcott
Thanks all!
Bit of a steep learning curve there, I'd never seen a .7z file before.
It's now written to the sd card, which got renamed 'Boot' by Win23DiskImager.
Where did most of the 2Gb image go, I can only see a few Mb-sized files on the sd?
- jvdz
- Domoticz version: 4.107
I am using the RPI just as the server without any GUI type interface.TheBod wrote:By the way, how do I load the Domoticz screen on the Pi rather than through the pc?
I connect to the CLI using Putty and am using SAMBA to access the data on the RPI with my Windows computer to allow for easy access to config files.
Jos
NietGiftig
- Domoticz version: V3.6224
To a second partition (Linux format) on your card that you windows computer cannot seeWestcott wrote: Where did most of the 2Gb image go, I can only see a few Mb-sized files on the sd?
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
Micrit431
Checkout my blog about creating a simple zwave home automation network on the PI www.ComputerTrail.net
Sent from my SM-T530 using Tapatalk
