Idiots guide to Raspberry Pi Installation
Re: Idiots guide to Raspberry Pi Installation
By the way, how do I load the Domoticz screen on the Pi rather than through the pc?
- Westcott
Thanks Jos.jvdz wrote:Just follow the Wiki i linked in one of the previous posts, which also has the info for the RPI image.Westcott wrote: Thanks, but that also only has Windows setup files.
Jos
Are you saying that
domoticz-raspberrypi-sdcard-3530.7z 2015-11-01 248.6 MB
is the one to use?
That is the one that I used. The image file is 2,078,277,632 bytes
Extract the zip file and there is a file in there called "domoticz-raspberrypi-sdcard-3530.img". This is what you need to copy to the SD Card
- Westcott
Thanks all!
Bit of a steep learning curve there, I'd never seen a .7z file before.
It's now written to the sd card, which got renamed 'Boot' by Win23DiskImager.
Where did most of the 2Gb image go, I can only see a few Mb-sized files on the sd?
- jvdz
- Domoticz version: 4.107
I am using the RPI just as the server without any GUI type interface.TheBod wrote:By the way, how do I load the Domoticz screen on the Pi rather than through the pc?
I connect to the CLI using Putty and am using SAMBA to access the data on the RPI with my Windows computer to allow for easy access to config files.
Jos
- Domoticz version: V3.6224
To a second partition (Linux format) on your card that you windows computer cannot seeWestcott wrote: Where did most of the 2Gb image go, I can only see a few Mb-sized files on the sd?
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
Checkout my blog about creating a simple zwave home automation network on the PI www.ComputerTrail.net
Sent from my SM-T530 using Tapatalk
