Nefit Easy™
Holland
- Domoticz version: Beta Ch
Nefit Easy™
As just mentioned in this thread, viewtopic.php?f=34&t=755&p=66969&hilit=nefit#p66969, Robert Klep has developed a client that can access the Nefit Easy. For more info please go to https://github.com/robertklep/nefit-easy-client and http://gathering.tweakers.net/forum/lis ... 8#45516548
To install the Nefit Easy client on a Pi please follow the below procedure:
The Nefit Client requires Node 4.0 or newer. Problem is the most recent version of wheezy comes with a rather old version of node (think v0.12 or something). The latest stable version of Node is v5.3.0. Install that version by doing this for the Pi 2:
1. node -v
2. wget https://nodejs.org/dist/v5.3.0/node-v5. ... v7l.tar.gz
3. tar -xvf node-v5.3.0-linux-armv7l.tar.gz
4. cd node-v5.3.0-linux-armv7l
5. sudo cp -R * /usr/local/
6. node -v
At step 6 it should show v5.3.0
Then continue with the installation of the Nefit Easy Client.
1. git clone https://github.com/robertklep/nefit-eas ... server.git (if you need to update later on, issue the following: git pull https://github.com/robertklep/nefit-eas ... server.git)
2. cd nefit-easy-http-server
3. sudo npm i nefit-easy-http-server -g
4. export NEFIT_SERIAL_NUMBER= insert your serial number here
5. export NEFIT_ACCESS_KEY= you get the point
6. export NEFIT_PASSWORD= ""
The installation is now done.
After the above I ran an example script which showed the following: Yes succes!
pi@raspberrypi ~/nefit-easy-client $ node example/current-status.js
Temperature is set to 15.0°C, current is 19.9°C.
Outside temperature is 7.0°C.
System pressure is 0.9 bar.
1. node -v
6. node -v
jeroenkl
Re: Nefit Easy™ client library (How to install on the Pi)
Great! Thanks!
jeroenkl
in case you want to install node.js in on a Raspberry Pi 1 model B revision 2:
pi@raspberrypi $ wget https://nodejs.org/dist/v5.3.0/node-v5. ... v6l.tar.gz
pi@raspberrypi $ tar -xvf node-v5.3.0-linux-armv6l.tar.gz
pi@raspberrypi $ cd node-v5.3.0-linux-armv6l/
pi@raspberrypi ~/node-v5.3.0-linux-armv6l $ sudo cp -R * /usr/local/
pi@raspberrypi ~/node-v5.3.0-linux-armv6l $ node -v
v5.3.0
v5.3.0
dorenberg
- Domoticz version: 4.10982
great news. Will follow this thread!!!!
geezerrr
This makes me happy
+1
Hope we can control the nefit easy with Domoticz soon
+1Hope we can control the nefit easy with Domoticz soon
SweetPants
Can already read the Nefit Easy thermostat with this library. great job
Holland
We can make it even more simple with the CLI.
If you issue the following from the nefit client directory; ./bin/easy status
The following is returned, which is basically a JSON string. Now I need to find out how to get this into Domoticz. Any help is appreciated
{"user mode":"clock","clock program":"auto","in house status":"ok","in house temp":19,"boiler indicator":"off","control":"room","temp override duration":0,"current switchpoint":24,"ps active":false,"fp active":false,"temp override":false,"holiday mode":false,"boiler block":null,"boiler lock":null,"boiler maintainance": null,"temp setpoint":19,"temp override temp setpoint":19.5,"temp manual setpoint":19.5,"hed enabled":null,"hed device at home":null,"outdoor temp":10,"outdoor source type":"virtual"}
jannl
- Domoticz version: 2026.1.x
json decoding will not be that hard using perl or so.
Works great, however, how to the environment vars correctly from a script (sh/bash or perl)
Edit: never mind, was a path setting and type
Perl code below sets a temp value in Domoticz.
Highly depends on the output of the status command not being changed.
Now just finding a way to do this regularly
#!/usr/bin/perl
use strict;
use v5.14;
use strict; # Good practice
use warnings; # Good practice
use Time::Local;
my $domoticz = "192.168.1.2:8080"; # ip and port of your Domoticz server
my @element_array=();
my $nr_elements=0;
my $nefit_cmd = "/home/pi/domoticz/nefit-easy-client/bin/easy status";
$ENV{NEFIT_SERIAL_NUMBER}="serial";
$ENV{NEFIT_ACCESS_KEY}="acces key";
$ENV{NEFIT_PASSWORD}='passwd';
#system ( "set | grep -i nefit");
# Get the JSON url
my $json= `$nefit_cmd`;
#remove first and last character
$json =~ s/^.//s ;
$json =~ s/.$//s ;
#print("$json\n");
my @elements = split(/,/, $json);
foreach my $f ( @elements )
my @lines = split(/:/,$f);
#always 2 element!!
$lines[0] =~ s/^\"//s ;
$lines[0] =~ s/\"$//s ;
$lines[1] =~ s/^\"//s ;
$lines[1] =~ s/\"$//s ;
$element_array[$nr_elements][0] = $lines[0];
$element_array[$nr_elements][1] = $lines[1];
$nr_elements++;
#print("$lines[0] -> $lines[1]\n");
print("$nr_elements\n");
for (my $i=0;$i < $nr_elements;$i++)
if ( $element_array[$i][0] =~ m/in house temp/ )
#print ("$element_array[$i][0] -> $element_array[$i][1]\n");
`curl -s "http://$domoticz/json.htm?type=command¶m=udevice&idx=141&nvalue=0&svalue=$element_array[$i][1]"`;
jannl
Remaining question is, how secure is this.
With the environment vars, basically everyone who has them can see what your nefit is doing and where it is doing that.
As in: vacation program is running.....
ThinkPad
I would say: Python.Holland wrote:We can make it even more simple with the CLI.
Unfortunately i'm not a programmer (otherwise i would help), but i know that parsin JSON with Python is quite easy.
See this script for example: http://domoticz.com/wiki/Mindergas.nl#The_Python_way which parses JSON-output from Domoticz:
meterstand = device_data['result'][0]['Counter']
I think that is a good way to start parsing the values and putting them into virtual sensors in Domoticz.
- mvveelen
Wow, this looks promising! I hope this will be developed more and will also be available on a Synology without too much hassle (i.e. installing programs and such).
pepijn
I started this this evening and have it running using Node-RED.
When finished i will post a more detailed description here
- kraades
- Domoticz version: Stable
Just wondering. Why does the package manager not work? I always end up with a 0.* version.jeroenkl wrote:in case you want to install node.js in on a Raspberry Pi 1 model B revision 2:
From https://nodejs.org/en/download/package-manager/:
curl -sL https://deb.nodesource.com/setup_5.x | sudo -E bash -
sudo apt-get install -y nodejsThere is a node package available from SynoCommunity but it is outdated. You could also compile node yourself for your platform. If you have a Synology that supports docker you could probably also use the node docker image.mvveelen wrote:Wow, this looks promising! I hope this will be developed more and will also be available on a Synology without too much hassle (i.e. installing programs and such).
Thanks, I didn't even know Node-RED was installed by default until I read your post.pepijn wrote:I started this this evening and have it running using Node-RED. When finished i will post a more detailed description here
pepijn
Here is my quick and dirty solution for now:
Step 1) Install Robert Klep's piece of magic
See: https://github.com/robertklep/nefit-easy-client
I used
This will install the 'easy' command-line tool.
Step 2) Communicate to your easy
The command line to get the status of your Nefit boiler is
For now i just created a small bash script that just sets the environment variables and executes the command.
/opt/nefit/nefit-status
There's also a script to set the temperature
/opt/nefit/nefit-set
Don't forget to use chmod +X to make te scripts executable
Step 3) Create virtual sensors
Right now create 3 Virtual sensors, (Setpoint, Temperature and Text) and write down the IDX values Step 4) Node-RED
I used Node-RED to parse the Nefit Easy JSON to Domoticz and to change the setpoint on the LUA
Here is my flow:
When importing it should look like this:
Now you need to adjust the configuration by editing the 'Update Domoticz' function in Node-RED.
Change your Domoticz server IP address and port and use the IDX values from Step 3 to set IDX_SetPoint (Setpoint virtual Sensor), IDX_RoomTemp (Temperature Virtual Sensor) and IDX_Indicator (Text Virtual Sensor)
Now you are ready to deploy the flow and start testing
Notes:
I used
npm install robertklep/nefit-easy-client -gStep 2) Communicate to your easy
easy status/opt/nefit/nefit-status
export NEFIT_SERIAL_NUMBER='XXXXX'
export NEFIT_ACCESS_KEY='XXXXXX'
export NEFIT_PASSWORD='XXXX'
easy statusThere's also a script to set the temperature
easy set temperature "$*"Step 3) Create virtual sensors
Here is my flow:
[{"id":"22a46350.4b5c8c","type":"mqtt-broker","broker":"127.0.0.1","port":"1883","clientid":""},{"id":"8b0bfef4.74f4","type":"inject","z":"b83a61b3.47c5a","name":"Update","topic":"nefit-update","payload":"","payloadType":"date","repeat":"30","crontab":"","once":true,"x":92,"y":40,"wires":[["b358d0b9.4ca73"]]},{"id":"b358d0b9.4ca73","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-status","addpay":false,"append":"","useSpawn":"","name":"Nefit Status","x":255.44443702697754,"y":39.666669845581055,"wires":[["8f9f7e3a.70608"],[],[]]},{"id":"3876c9bf.c78936","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"true","complete":"true","x":841.111083984375,"y":127.44444274902344,"wires":[]},{"id":"8f9f7e3a.70608","type":"function","z":"b83a61b3.47c5a","name":"Update Domoticz","func":"node.log(\"Nefit Easy to Domoticz Update\")\n\n// Configuration\nconst DomoticzServer = '172.30.0.10'\nconst DomoticzPort = '80'\n\nconst IDX_SetPoint = 160\nconst IDX_RoomTemp = 161\nconst IDX_Pressure = 162\nconst IDX_Indicator = 163\n\nvar NefitJSON = JSON.parse(msg.payload);\n\nvar setpoint_msg = {}\nvar temp_msg = {}\nvar pressure_msg = {}\nvar indicator_msg = {}\n\n// Update\nif (msg.topic == 'nefit-update') {\n temp_msg.url = 'http://' + DomoticzServer + ':' + DomoticzPort + '/json.htm?type=command¶m=udevice&idx=' + IDX_RoomTemp + '&nvalue=0&svalue=' + NefitJSON['in house temp']\n indicator_msg.url = 'http://' + DomoticzServer + ':' + DomoticzPort + '/json.htm?type=command¶m=udevice&idx=' + IDX_Indicator + '&nvalue=0&svalue=' + NefitJSON['boiler indicator']\n}\n\n//if (msg.topic == 'nefit-pressure') {\n// pressure_msg.url = 'http://' + DomoticzServer + ':' + DomoticzPort + '/json.htm?type=command¶m=udevice&idx=' + IDX_Pressure + '&nvalue=0&svalue=' + NefitJSON['pressure']\n//}\n\nreturn [setpoint_msg, temp_msg, pressure_msg, indicator_msg];","outputs":"4","noerr":0,"x":447.88887786865234,"y":35,"wires":[[],["3ac46950.c53b96"],[],["b19896ef.4e6768"]]},{"id":"3ac46950.c53b96","type":"http request","z":"b83a61b3.47c5a","name":"Domoticz","method":"GET","ret":"txt","url":"","x":825.7777709960938,"y":33.66667366027832,"wires":[["3876c9bf.c78936"]]},{"id":"1caaaa11.e35556","type":"mqtt in","z":"b83a61b3.47c5a","name":"domoticz/out/#","topic":"domoticz/out/#","broker":"22a46350.4b5c8c","x":85,"y":276,"wires":[["577c156d.a883ec"]]},{"id":"577c156d.a883ec","type":"function","z":"b83a61b3.47c5a","name":"de-jsonify","func":"var payload = JSON.parse(msg.payload);\nreturn payload;","outputs":1,"noerr":0,"x":251,"y":276,"wires":[["342ad05e.cbd53"]]},{"id":"23467d6a.dcb982","type":"debug","z":"b83a61b3.47c5a","name":"","active":false,"console":"false","complete":"true","x":849,"y":344,"wires":[]},{"id":"50e0c648.af1f38","type":"function","z":"b83a61b3.47c5a","name":"","func":"msg.payload = msg.svalue1\nreturn msg;","outputs":1,"noerr":0,"x":596.4444580078125,"y":276.33331298828125,"wires":[["a97981c8.56868"]]},{"id":"342ad05e.cbd53","type":"switch","z":"b83a61b3.47c5a","name":"filter Setpoint IDX","property":"idx","rules":[{"t":"eq","v":"160"}],"checkall":"true","outputs":1,"x":429.4444274902344,"y":275.5555419921875,"wires":[["50e0c648.af1f38"]]},{"id":"b19896ef.4e6768","type":"switch","z":"b83a61b3.47c5a","name":"pressure URL","property":"url","rules":[{"t":"nnull"}],"checkall":"true","outputs":1,"x":661,"y":116.66667175292969,"wires":[["3ac46950.c53b96"]]},{"id":"a97981c8.56868","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-set","addpay":true,"append":"","useSpawn":"","name":"Nefit Set Temp","x":770,"y":276,"wires":[["23467d6a.dcb982"],[],[]]}]
Notes:
- The use of these command line scripts is a bit buggy but since the Nefit Easy Client is written in NodeJS it should be possible to use it in Node-RED directly.
- Set your thermostate to manual when using setpoints in Domoticz. If you use a clock program on the easy and adjust the setpoint from within Domoticz. The clock program will overwrite the setpoint on your easy.
- kraades
About the last note you mention.
It should also be possible with a clock program in place.
See https://github.com/robertklep/nefit-eas ... -168378270.
pepijn
True
So if you change the script /opt/nefit/nefit-set to
You can also change the setpoint when a clock program is used. But note, if the clock program changes the temperature (or you change it on the themostat/ easy app), te setpoint in Domoticz will not be changed.
export NEFIT_SERIAL_NUMBER='XXXX'
export NEFIT_ACCESS_KEY='XXXX'
easy put /heatingCircuits/hc1/temperatureRoomManual \'{\"value\":$*}\'
easy put /heatingCircuits/hc1/manualTempOverride/status '{"value":"on"}'
easy put /heatingCircuits/hc1/manualTempOverride/temperature \'{\"value\":$*}\'
- kraades
There has been an update.
https://github.com/robertklep/nefit-eas ... e8da0b872e
Set temparature should now work.
No need for the workaround. Sorry...
pepijn
A small update on my Node-RED flow
It now uses MQTT to publish the messages and will also retrieve the pressure.
You also need an additional script
/opt/nefit/nefit-pressure
[{"id":"22a46350.4b5c8c","type":"mqtt-broker","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":15,"cleansession":true,"willQos":"0","birthQos":"0"},{"id":"8b0bfef4.74f4","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-update","payload":"","payloadType":"date","repeat":"30","crontab":"","once":true,"x":178.00001525878906,"y":116,"wires":[["b358d0b9.4ca73"]]},{"id":"b358d0b9.4ca73","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-status","addpay":false,"append":"","useSpawn":"","name":"Nefit Status","x":454.4444580078125,"y":116.66667175292969,"wires":[["6ebefa6b.914104"],[],[]]},{"id":"3876c9bf.c78936","type":"debug","z":"b83a61b3.47c5a","name":"","active":false,"console":"true","complete":"true","x":805.111083984375,"y":164.44444274902344,"wires":[]},{"id":"1caaaa11.e35556","type":"mqtt in","z":"b83a61b3.47c5a","name":"domoticz/out/#","topic":"domoticz/out/#","broker":"22a46350.4b5c8c","x":85,"y":276,"wires":[["577c156d.a883ec"]]},{"id":"577c156d.a883ec","type":"function","z":"b83a61b3.47c5a","name":"de-jsonify","func":"var payload = JSON.parse(msg.payload);\nreturn payload;","outputs":1,"noerr":0,"x":251,"y":276,"wires":[["342ad05e.cbd53"]]},{"id":"23467d6a.dcb982","type":"debug","z":"b83a61b3.47c5a","name":"","active":false,"console":"false","complete":"true","x":962.25,"y":261.75,"wires":[]},{"id":"50e0c648.af1f38","type":"function","z":"b83a61b3.47c5a","name":"Get SetPoint Value","func":"msg.payload = msg.svalue1\nreturn msg;","outputs":1,"noerr":0,"x":630.194465637207,"y":275.0833168029785,"wires":[["a97981c8.56868"]]},{"id":"342ad05e.cbd53","type":"switch","z":"b83a61b3.47c5a","name":"filter Setpoint IDX","property":"idx","rules":[{"t":"eq","v":"160"}],"checkall":"true","outputs":1,"x":429.4444274902344,"y":275.5555419921875,"wires":[["50e0c648.af1f38"]]},{"id":"a97981c8.56868","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-set","addpay":true,"append":"","useSpawn":"","name":"Nefit Set Temp","x":820.0000114440918,"y":274.75000381469727,"wires":[["23467d6a.dcb982"],[],[]]},{"id":"6440aca2.9bbf54","type":"comment","z":"b83a61b3.47c5a","name":"Read changes from Domoticz and send to Easy","info":"","x":186,"y":239,"wires":[]},{"id":"6ebefa6b.914104","type":"function","z":"b83a61b3.47c5a","name":"Domoticz MQTT","func":"// Configuration\nconst IDX_SetPoint = 160;\nconst IDX_RoomTemp = 161;\nconst IDX_Pressure = 162;\nconst IDX_Indicator = 163;\n\nvar NefitJSON = JSON.parse(msg.payload);\nvar domoticz_msg = {};\ndomoticz_msg.topic = \"domoticz/in\";\ndomoticz_msg.payload = {};\n\nif (msg.topic == 'nefit-update') {\n domoticz_msg.payload.idx = IDX_RoomTemp;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + NefitJSON['in house temp'];\n}\nif (msg.topic == 'nefit-pressure') {\n domoticz_msg.payload.idx = IDX_Pressure;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + NefitJSON['pressure'];\n}\n\nreturn domoticz_msg;","outputs":1,"noerr":0,"x":641.5,"y":133.5,"wires":[["5bc7035e.a438fc","3876c9bf.c78936"]]},{"id":"5bc7035e.a438fc","type":"mqtt out","z":"b83a61b3.47c5a","name":"Domoticz MQTT","topic":"","qos":"","retain":"","broker":"22a46350.4b5c8c","x":833.25,"y":95.25,"wires":[]},{"id":"2f2db332.d0d24c","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-pressure","addpay":false,"append":"","useSpawn":"","name":"Nefit Easy Pressure","x":433.00000762939453,"y":177,"wires":[["6ebefa6b.914104"],[],[]]},{"id":"baf3b005.450c5","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-pressure","payload":"","payloadType":"date","repeat":"300","crontab":"","once":false,"x":184.00001525878906,"y":177,"wires":[["2f2db332.d0d24c"]]},{"id":"2b4dca2.fd4b236","type":"comment","z":"b83a61b3.47c5a","name":"Publish data from Nefit Easy Client to Domoticz","info":"","x":179,"y":70,"wires":[]}]
export NEFIT_SERIAL_NUMBER='xxxx'
export NEFIT_ACCESS_KEY='xxxx'
export NEFIT_PASSWORD='xxxx'
easy pressure
