Domoticz reinstall on USB stick - part 2
Dutchsea
Domoticz version: v2023.2
Post by Dutchsea »
Today found time to install Raspbian on my Raspberry Pi on a new USB stick. So far it works like a charm.
Next step is to install Domoticz. I can't use the image file for a SD card as I want to install on an existing Raspbian install.
I followed the manual (here https://www.domoticz.com/wiki/Installin ... spberry_PI)
But I got stuck as the file required, http://domoticz.sourceforge.net/domotic ... armv7l.tgz, is not available.
What happened to this file. i can only see Windows i stall files and SD images....
Raspberry PI 3B on USB drive, Debian version: 12 (bookworm), Domoticz 2024.7
Aeon Z-Wave G5 stick, RFXCOM, Sonof Zigbee 3.0 Dongle plus E, Nefit Easy, Fritzbox, Buienradar, Sonos
Dutchsea
Re: Domoticz reinstall on USB stick - part 2
Post by Dutchsea »
Or should i just install the Domoticz image on my USB......?
nayr
Domoticz version: github
Post by nayr »
skip down to Installing from Source, skip the binary install.. takes a bit longer to compile and upgrade, but your not at the mercy of someone else building it for you.
Dutchsea
Post by Dutchsea »
Yup, that should also work. A lot more typing though. ;)
