Pemoticz: Control Domoticz from your Pebble
KixAss
I created a small app to control your Domoticz-system from your Pebble watch.
This is a first test-version to control scenes. In the next version it will also be possible to control switches and temperatures.
Url: https://apps.getpebble.com/applications ... 3b8f000010
voorstad
Re: Pemoticz: Control Domoticz from your Pebble
Great idea! Installed it, configured it with both ip and ip:port, but nothing is displayed on the Pebble. Smartphone can connect. Do I miss something?
KixAss
Have you entered an internal or external ip-address, and did you include http:// in front and a / after?
voorstad
http://192.168.1.110:8080/
Is what I entered. I do not have a user/pw protection.
Pasting The exact same in my browser shows the site.
KixAss
Strage, should work. I'll make a better errorhandler and post here when its done.
KixAss
Could you try again? First to the settings, then Save and then restart the app.
voorstad
No luck.... I rebooted The Pebble even.
KixAss
Just made version 1.1. Could you update and try again?
voorstad
Thanks! But no luck.
Uninstalled it and reinstalled... No change.
When I switch off my wifi, app reads "Error Connecting". With wifi on, nothing appears.
I removed all items but one switch from my dashboard... No change.
KixAss
Have you got any scenes in your installation?
voorstad
That did the trick! Adding a test scene and now all switches are shown!
philipgoodfellow
- Domoticz version: 4.10085
I have installed Pemoticz. I have entered my Domoticz url as:
https://192.168.0.15:443/ (I also tried without the :port)
All I get on the pebble is Error Connecting: 0
All I can think of is you are not supporting https: Am I right?
It is good to see a pebble domoticz app (even if it does not yet work for me).
Philip.
Philip.
KixAss
It should work. Are you using an official certificate, or a self-signed?
goncaloazevedo
Is compatible with time round?
philipgoodfellow
It is the "self signed" certificate that is installed by the Domoticz installation. It describes itself as "Issued to: Raspberry.local Issued By: Domoticz CA"KixAss wrote:It should work. Are you using an official certificate, or a self-signed?
KixAss
Then I think that's the problem. Other problem is that I don't have control over the certificates (which should be accepted and which shouldn't). You could try to add the certificate to your phone, maybe then it will be accepted.
- Egregius
- Domoticz version: v2024.7
Just received my Pebble Time and installed your app. Worked instantly
Maybe a tip: possibility to use a roomplan.
In a roomplan you can select switches, that way it could be a short list on the pebble. Now it's a list of > 50 devices wich is quite huge to browse on such a small screen.
- Egregius
Sorry, will use the HTTP Push app.
I need to be able to send update commands for switches that can't be switched...
knielen
Hi KixAss,
this app looks great, but doesn't support the Pebble Time Round yet. Is it much work to make an update?
Verstuurd vanaf mijn XT1562 met Tapatalk
