Low cost wireless energy meter CT
tuspam
Post by tuspam »
Somebody got Mieo HA102 or test this unit? Compatible with domoticz?
LINK
Look promising and have 433mhz transmitter.
Specification:
1) Accuracy: ≤5%
2) Measuring current: 100mA-70A Measuring range: 10W~17.5KW
3) Voltage setting: 100~250v AC
4) Transmitter sample rate: 2s, 8s, 64s
5) Transmission frequency: 433.92MHz
6) Carbon ration: 0.5kg CO2/KWH
7) Power supply: 3pcs AA for receiver(battery not include); 3pcs AA for transmitter (battery not include)
8) Wireless transmitting range:30m-70m insight.
9) Operating Temperature: -10oC~ 60 oC Storage Temperature: -20 oC ~75 oC
b_weijenberg
Re: Low cost wireless energy meter CT
Post by b_weijenberg »
The Owl CM180i is already supported.
Almost the same price and up to 3 CT's are supported.
http://www.planete-domotique.com/transm ... n-owl.html (main unit)
http://www.planete-domotique.com/pince- ... ndard.html (71Amp clamp)
http://www.planete-domotique.com/pince- ... large.html (200Amp clamp)
RFX-433, RFX-433EMC, RFX-868
tuspam
Post by tuspam »
b_weijenberg wrote:The Owl CM180i is already supported.
Almost the same price and up to 3 CT's are supported...
Almost. Transmiter 39,95 € + 1 CT 8,95 € = 48,9 € + shipping vs 48.43 $ (free shipping) with this good looking monitor (display unit). So if this is supported it will be better solution if U need 1 phase CT sensor.
On the diagram U can see the central unit connects to the router via wifi (and connected to PC) so maybe is the ability to take data via LAN to domoticz without the use of expensive devices rfxcom?
FrankEggert
Domoticz version: V2.3530
Post by FrankEggert »
Hi, I own this device,but up to now I have no idea to get the signal.
My Rfxcom will not reconize the device..... :cry:
KR Frank
b_weijenberg
try with RFXmngr and enable only the Oregon protocol.
FrankEggert
I connected the RFXmng and set Oregon only with undec.
I received following Signal
Packettype = UNDECODED RF Message
UNDECODED OREGON3:537CD0A50C191014ADC43C01
UNDECODED OREGON3:537CD0A508191014AD44D401
UNDECODED OREGON3:537CD0A504191014ADC48D01
Maybe it is the device, but I have no knowledge to decode it.
b_weijenberg
Please contact support [at] rfxcom.com
