Control AirPlay with AppleScript and Domoticz
kvanhoorn
Post by kvanhoorn »
Here's a project I'm working on for a while now.
I have a couple of airplay locations in house (for example: bathroom, kitchen, garage).
At 6:30 radio starts playing in the bathroom, at 7:00 in the kitchen etcetera.
But I also wanted to control it manually on location with a hardware button.
The KlikaanKlikuit AWST-8802 switches trigger a switch in Domoticz (on Raspberry Pi) which does a webcall to my Mac which triggers the AppleScript.
The on-button has three functions:
(if music is not playing) start playing a specific radio station from specific playlist or
(if music is playing but not on this speaker) add this airport to itunes selected devices or
(if music is playing on this speaker) play next song.
The off-button has two functions:
(if music is playing on this speaker) remove this airport from selected itunes devices or
(if music is not playing on this speaker) let itunes stop playing over all speakers and remove all speakers as selected device.
The On-Action of the device looks like this:
http://admin:[email protected]/radio_control.php?state=on&speaker=AE_Kitchen&volume=50
The Off-Action of the device looks like this:
http://admin:[email protected]/radio_control.php?state=off&speaker=AE_Kitchen
The webcall is a simple php script (with basic authentication) that looks like this:
<?php
if (count($_GET) >= 2) {
    $speaker = str_replace('_', ' ', $_GET['speaker']);
    $cmd = 'sudo su "kevin" -c "/usr/bin/osascript /path/to/script/radio_airplay.scpt ' .
        $_GET['state'] . ' ' .
        '\'' . $speaker . '\' ' .
        (@$_GET['volume'] ?: '') . '"';
    $result = exec($cmd);
    var_dump($cmd);
    var_dump($result);
The AppleScript looks like this: (I couldn't upload a scpt-extension file, edit with Script Editor app)
on run argv
	try
		set onOff to item 1 of argv
		set inpDevicename to item 2 of argv
		set inpVolume to 0
		if (onOff is "on") then
			set inpVolume to item 3 of argv
		end if
	on error
		error number -128
		return
	end try
	if onOff is "on" then
		speakerOn(inpDevicename, inpVolume)
	else if onOff is "off" then
		speakerOff(inpDevicename)
	end if
end run
on stopItunes()
	tell application "iTunes"
		pause
	end tell
end stopItunes
on speakerOn(speakername, vol)
		# check if speaker exists in home network
		if not my is_speaker(speakername) then
			log ("Airplay device '" & speakername & "' not found")
			error number -128
			return
		end if
		# check if speaker is already active
		if not my is_current_speaker(speakername) then
			log ("setting device " & speakername)
			my set_speaker(speakername, vol)
			# else play next track (speaker is active)
		else if player state is playing then
			next track
		end if
		# if itunes is not playing yet, start with 3FM
		if player state is not playing then
			play playlist "Stream (radio)"
			play track "3FM" of playlist "Stream (radio)"
		end if
	end tell
end speakerOn
on speakerOff(speakername)
			error number -128
			return
		end if
		if my is_current_speaker(speakername) then
			log ("unsetting device " & speakername)
			my unset_speaker(speakername)
			my unset_all_speakers()
		end if
	end tell
end speakerOff
on set_speaker(speakername, vol)
		set apDevices to (get AirPlay devices where selected is true)
		set speaker to (first AirPlay device whose name = speakername)
		set sound volume of speaker to vol
		# add speaker to speakerlist
		copy speaker to the end of apDevices
		set current AirPlay devices to apDevices
	end tell
end set_speaker
on unset_speaker(speakername)
		# remove speaker from speakerlist
		set apDevicesNew to {}
		repeat with aDevice in apDevices
			if (aDevice's name as string is not speakername) then
				copy aDevice to the end of apDevicesNew
			end if
		end repeat
		set current AirPlay devices to apDevicesNew
		if (count apDevicesNew) is 1 then
			my stopItunes()
		end if
	end tell
end unset_speaker
on unset_all_speakers()
		set speaker to (first AirPlay device whose name = "Computer")
		set current AirPlay devices to speaker
		my stopItunes()
	end tell
end unset_all_speakers
on is_speaker(speakername)
		set apDevices to (get name of every AirPlay device)
		set deviceFound to false
			if (aDevice as string is speakername) then
				set deviceFound to true
			end if
		end repeat
		return deviceFound
	end tell
end is_speaker
on is_current_speaker(speakername)
		set apDevices to (get name of AirPlay devices where selected is true)
			end if
		end repeat
		return deviceFound
	end tell
end is_current_speaker
Please feel free to modify the code, it's absolutely not optimal. This is the first time I'm coding AppleScript.
cristou
Re: Control AirPlay with AppleScript and Domoticz
Post by cristou »
Hello, im a french guy (sory for my bad english...)
Can you explain how you processes ?
I have a mac itunes and airport express.
I 'd like domoticz sending sound to my airport express ?
I do not really know apple script ...
Can you explain me in private ? send me the file by email can be ?
Thank you for your help.
thebeetleuk
Post by thebeetleuk »
I would like to understand this a bit more as well. When you say you have a few airplay locations. What are these devices? Also how are you streaming the audio to the device?
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
thebeetleuk
Looking at the script it looks like you are connecting to itunes and playing through that?
thebeetleuk
kvanhoorn
Post by kvanhoorn »
cristou wrote:Hello, im a french guy (sory for my bad english...)
Dear Cristou, this is al the code I use.
I have a couple of Airport Expresses, and my Mac Pro controls those speakers from its iTunes installation.
Please try to set it up, if you come by any trouble, contact me.
I have an installation of OS X Server for the php-file, but you can also use the free application MAMP.
kvanhoorn
Post by kvanhoorn »
thebeetleuk wrote:I would like to understand this a bit more as well. When you say you have a few airplay locations. What are these devices? Also how are you streaming the audio to the device?
Dear thebeetleuk, I use Airport Expresses with speakers connected to them.
iTunes on my Mac Pro connects to these devices.
Domoticz calls the applescript on the iTunes computer via the PHP-script on a webserver.
From the arguments domoticz sends and the current state of a speaker, it decides which action it should take.
Users browsing this forum: Google [Bot] and 0 guests
