Cannot have 4 "OR" statements in one "IF"?
elgarne
Post by elgarne »
If I do what is depicted in the attached figure, I cannot save my event and nothing shows up in the logs. Any reason for that?
Thanks.
Egregius
Domoticz version: v2024.7
Re: Cannot have 4 "OR" statements in one "IF"?
Post by Egregius »
Try lua or php, you'll have endless possibilities.
elgarne
Post by elgarne »
Thanks. But any reason for that?
BTW, if some moderator could move the thread in the events section, I'll be grateful.
mrf68
Post by mrf68 »
I see a + sign in front of the If. Do you have an elseif statement after the first if? If not, choose under Control the If statement without the + sign and try again.
20151224 elseif.jpg (7.9 KiB) Viewed 1932 times
I tried this one and it works.
20151224 ororor.jpg (26.91 KiB) Viewed 1931 times
elgarne
Post by elgarne »
Yes, I have an "elseif" statement.
mrf68
Post by mrf68 »
And whaf if you try it as a single 'if then'?
Just tested it with this:
20151225 1.jpg (31.29 KiB) Viewed 1892 times
.. works great.
elgarne
Post by elgarne »
Actually, it seems I'm limited in the number of 'items'. It I have 2 'elseif' statements and 3 'or' in the first if, then it does not save the event but does not display an error message.
With 2 'or' and 2 'elseif', it works. I have to delete one 'else if', in order to be able to use 3 'or'.
