SDM120C - RS485 Meter
fabix68
Post by fabix68 »
Hello.
I'm trying to use Domoticz for power management in my apartment.
I use the meter SDM120C RS48-mode connected to the Raspberry PI.
I installed the library MODBUS
When doing a "sdm120c -A1 -PN -b 9600 / dev / ttyUSB0" I get this data
Voltage: V 233.40
Current: 2.37 A
Power: 545.10 W
Active Apparent Power: 548.72 VA
Reactive Apparent Power: 0.00 VAR
Power Factor: 1.00
Phase Angle: 0.00 Degree
Frequency: 50.00 Hz
Import Active Energy: 1842537 Wh
Export Active Energy: 0 Wh
Total Active Energy: 1842537 Wh
Import Reactive Energy: 273398 VARh
Export Reactive Energy: 0 VARh
Total Reactive Energy: 273398 VARh
OK
I can import them into Domoticz?
TNK
gianfrdp
Domoticz version: 3.8805
Re: SDM120C - RS485 Meter
Post by gianfrdp »
First of all you have to define a virtual sensor, type 'Electric'
You can create a script that reads values and sends them to domoticz using JSON API.
For example, if domoticz IP is 192.168.2.31 and idx for virtual meter is 2:
#!/bin/sh
W=`sdm120c -a 1 -b 9600 -pq /dev/ttyUSB0 | awk '{print $1}'`
WH=`sdm120c -a 1 -b 9600 -iq /dev/ttyUSB0 | awk '{print $1}'`
curl -s "http://192.168.2.31:8080/json.htm?type=command&param=udevice&idx=2&nvalue=0&svalue=$W;$WH"
Execute script via cron
Users browsing this forum: willemd and 1 guest
