Wireless temp sensor/transmitter for waterpipes
Heen
Domoticz version: 3530
Post by Heen »
Hi.
I`m a real newbie with Domoticz and my Raspberry Pi.
For heating my home i got a electric heat pump, and now i want to monitor the watertemperature from the pump.
Does anyone has any experience with a wireless transmitter with sensors to clamp on copperpipes? Using a RFXTRX433E, so something broadcasting on 433 mHZ would be preferred
Thanks in advance :)
Heen
Raspberry Pi 2 B - Domoticz 3530 - RFXTRX433E - Z-Stick Gen5
Domosapiens
Domoticz version: V3.5981
Re: Wireless temp sensor/transmitter for waterpipes
Post by Domosapiens »
Not on RFXTRX433E,
but recommended for maximal 4 temp sensors:
Z-Wave factfile Fibaro FGBS-001 Universal Binary Sensor
Cheers
Domosapiens
D'rMorris
Post by D'rMorris »
Or check out mysensors :)
b_weijenberg
Post by b_weijenberg »
The Proove TSS330, TFA 30.3177, WSP-320 can be used.
https://www.m.nu/temperatursensor-kylfr ... -1391.html
RFX-433, RFX-433EMC, RFX-868
Heen
Post by Heen »
Thanks alot. Guess i will try out mysensors.org
jurgen
Domoticz version: stable
Post by jurgen »
Hi Heen,
I'm using a Z-wave usb stick as transmitter and the z-wave qubino switch (zmnhdnd1) with temperture sensor (ZMNHEA1).
These products are compatible with domoticz and you can read the temperture and turn off and on the floorheating pump if you want.
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Simple, reliable, compatible with RFXCom & relatively cheap:
http://weerhuisje.nl/index.php?item=tfa ... d=&lang=EN
