Remember that an iPhone switches off wifi most of the time the screen is off!!rgroothuis wrote:Another question I'm having on this subject is how to use this pinging information (if it works) in the LUA scripts? Any examples?
I found the device I'm pinging in my device list but I cannot add it to my switches dashboard, is this correct? And because of that I also cannot see the pinging result history, so I cannot tell if my iPhone is ping-ed correctly.
Wifi switches for phones
jannl
- Domoticz version: 2026.1.x
Re: Wifi switches for phones
rednas
You should be able to add it to your switches dashboard and use it in LUA as you would use a normal switch.rgroothuis wrote:Another question I'm having on this subject is how to use this pinging information (if it works) in the LUA scripts? Any examples?
I am going to find out how to do this and if it's possible. Will let you know!StanHD wrote:I have disabled IPv6 on my router for my LAN (not WAN) as this gave me other problems. May be worth a try?
rgroothuis
Strangely enough if I click on the green arrow button nothing is happening. Strange. Any idea's? I've not (yet) rebooted Domoticz, is that required?
rednas
I guess it has to do with your Name with the apostrophe. Try removing it, it could be interfering with apostrophes used in the code of Domoticz.
rgroothuis
Excellent, that was the trick. Learned something again, thanks.rednas wrote:I guess it has to do with your Name with the apostrophe. Try removing it, it could be interfering with apostrophes used in the code of Domoticz.
