You are only resetting "RESET ROOKALARM" to Off after 6 seconds, so when in the mean time any device changes, this blockly is fired and the test is still true for "RESET ROOKALARM"="On". Why not change this to happen immediately?
Jos
Blocky fires twice
Evelen
- Domoticz version: 2.4538
Re: Blocky fires twice
idk if any wait block exist, but this is how I fixed looping of a light (whem montion detected)
A dummy sw
A dummy sw
Bikey
- Domoticz version: 2020.x
I never knew how to reset the status of the smoke detectors in Blockly, thanks to your example I now now the (undocumented!) Json-command. Had to find out that it is case sentive: bot "normal" and "Normal" give a success as result, not only the latter actually works.
