No registration of Gas utility
rjobaan
Domoticz version: 2022.1
Post by rjobaan »
I Have A p1 converter cable from My Smart Meter to my raspberry pi.
In domoticz I could add the device and I see as expected two Smart meters Energy and Gas.
The energy is updating every 5 min, but I still don't see any gas data? How is this possible?
bbqkees
Domoticz version: 4.1x
Re: No registration of Gas utility
Post by bbqkees »
This can take up to 2 days.
Also make sure you tich the box at 'allow new hardware device'.
ThinkPad
Post by ThinkPad »
The gas meter sends its values every hour. But if your smart meter was placed today/yesterday, it can take indeed a few days before everything is working as it should.
bbqkees
Post by bbqkees »
You also need to use gas otherwise it wont show up.
I had that problem when I added a P1 cable in the evening and the return did not show up.
However, in the evening it is dark and thus no solar panel production.
In the morning they were added.
rjobaan
Post by rjobaan »
Thank you very much for trying to help me out here
I have the meter for several months, but I just started to set up my Pi and connect with the cable to the Smart Meter.
Where can I find the box at 'allow new hardware device' to check?
My CV uses gas and also when I cook. So its should be showing
I also taken a picture this morning of the gas meter and now, And I definitely use gas
bbqkees
Post by bbqkees »
Setup->Settings.
Also check if the gasmeter is still in your unused devices list.
Filter on the hardware type.
rjobaan
Post by rjobaan »
The gas meter is not in unused list. And "allow new hardware" was already checked
When I run minicom -b 115200 -o -D /dev/ttyUSB0
I receive below numbers
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(151210111544W)
0-0:96.1.1(4530303033333030303038383632373134)
1-0:1.8.1(001158.190*kWh)
1-0:1.8.2(001799.396*kWh)
1-0:2.8.1(000000.000*kWh)
1-0:2.8.2(000000.000*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.524*kW)
1-0:2.7.0(00.000*kW)
0-0:96.7.21(00011)
0-0:96.7.9(00005)
1-0:99.97.0(1)(0-0:96.7.19)(000101000016W)(2147483647*s)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(000*A)
1-0:51.7.0(002*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.019*kW)
1-0:22.7.0(00.000*kW)
1-0:41.7.0(00.449*kW)
1-0:42.7.0(00.000*kW)
1-0:61.7.0(00.055*kW)
1-0:62.7.0(00.000*kW)
!5919
Only I don't see the gas meter?
I expect something to see like (copied from some website)
0-0:96.1 3.1 (3031 203631 203831 )
0-0:96.1 3.0(3031 32333435363738393A3B3C3D3E3F3031 32333435363738393A3B3C3D3E3F3031 32333435363738393A3B
3C3D3E3F3031 32333435363738393A3B3C3D3E3F3031 32333435363738393A3B3C3D3E3F)
0-1:24.1 .0(03)
0-1:96.1 .0(3232323241 42434431 3233343536373839)
0-1:24.2.1 (1 01 2091 1 0000W)(1 2785.1 23*m3)
0-1:24.4.0(1 )
right?
How come I don't see the gasmeter?
rjobaan
Post by rjobaan »
after some more investigation i found out that Stedin did not activate my gas meter. So to solve this i activated my gasmeter.
For the dutch people https://www.stedin.net/~/media/files/st ... smeter.pdf
After activation its showing in domoticz!
this topic can also be closed
ThinkPad
Post by ThinkPad »
Thanks, very useful post!
These kind of PDF's are known to sudden disappear after some years, so i copied the info for later reference below:
LANDYS + GYR
TYPE G350 G4T t/m G6T
1. Druk één keer kort op de rode knop om het scherm te activeren.
2. Druk nog een keer op de rode knop en houd deze 8 seconden
ingedrukt.
3. Op het scherm wordt nu ‘>>>’ getoond. De gasmeter is dan
geactiveerd.
Ziet u ‘>>>’ niet op het scherm verschijnen?
Dan is het activeren niet gelukt. Herhaal dan de stappen.
Let u erop dat de informatie op het scherm van de gasmeter volledig is
verdwenen voordat u de stappen herhaalt
ITRON
TYPE RF1 G4 t/m G25
U ziet dan rechtsonder in het scherm één of twee pijlen.
ingedrukt.
3. Op het scherm gaat nu de bovenste pijl 60 seconden aan en
vervolgens 60 seconden uit. Dit ‘knipperen’ betekent dat de
gasmeter geactiveerd is.
Gaat de bovenste pijl niet knipperen?
verdwenen voordat u de stappen herhaalt.
ELSTER
TYPE BK G4 t/m G25
1. Druk één keer kort op de grijze knop om het scherm te activeren.
2. Druk nog een keer op de grijze knop en houd deze 8 seconden
ingedrukt.
3. Op het scherm wordt nu ‘install’ weergegeven. De gasmeter is dan
geactiveerd.
Ziet u ‘Install’ niet op het scherm verschijnen?
Search words: slimme meter uitlezing, geen gasverbruik, gasmeter niet gekoppeld, gasmeter not paired, smartmeter, smart meter, p1
