Newbie RLlink Q: Although the RFLink shield is not expensive, I'm curious if it is possible to use the Aurel TX-4MSIL and Aurel RX-4M50RR30SF because I have them laying around and it seems like a waste to not using them... I bought them to use for a NODO project but I never did build it.
Thanks for the great work on the RFLink project!
Separate Aurel Transmitter and Receiver for RFLink?
- Stuntteam
Re: Separate Aurel Transmitter and Receiver for RFLink?
Yes! No problem at all.
You could wire like this:
Aurel TX-4MSIL:
Pin 1: Antenna (get a 433mhz antenna or use a wire of 16.8 cm)
Pin 2: (data) to Arduino D14
Pin 3: to Arduino ground
Pin 4: (vcc) to Adruino D15
RX-4M50RR30SF:
Pin 2: to Arduino ground
Pin 3: Antenna (get a 433mhz antenna or use a wire of 16.8 cm)
Pin 7: to Arduino ground
Pin 10: (vcc) to Adruino D16
Pin 11: to Arduino ground
Pin 13: not connected
Pin 14: (data) to Arduino D19
Pin 15: (vcc) to Adruino D16
Aurel TX-4MSIL:
RX-4M50RR30SF:
john316
- Target OS: OS X
I greatly appreciate your answer, thank you!
Eawo
Ive been searching alot on how to wire these cheap chines 433mhz like these http://www.ebay.com/itm/380717845396?rmvSB=true im quite new to homeautomation if i can get same discription as above i will be really happy
Backbone
- Domoticz version: 2023.2
TX > VCC to Arduino Mega D15
TX > GND to Arduino Mega GND
TX > Data to Arduino Mega D14
TX > Antenna 16.8 cm wire
RX > VCC to Arduino Mega D16
RX > GND to Arduino Mega GND
RX > Data to Arduino Mega D19
RX > Antenna 16.8 cm wire
Eawo
Thanks now everything working like it should
