Simple Christmas Tree Script for Philips Hue
All kinds of 'OS' scripts
mcduarte2000
Post by mcduarte2000 »
Hi, I just finished working in a Christmas Tree script and now sharing it as someone may want to do something similar. I've two Philips Living Whites plugs each controlling one row of lights. I created a group for the lights and two bash scripts. Do you have any suggestion on how to improve the scripts?
The on action passes a time to turn off the tree lights to the script and sends it to the background (as it may run for many hours):
script:///home/pi/domoticz/scripts/bash/christmas_tree_on.sh 23:58 &
#!/bin/bash
while [ $(date +%H:%M) '<' "$1" ];
do
curl --request PUT --data "{\"on\": true}" http://192.168.1.xx/api/xxxx/lights/5/state
curl --request PUT --data "{\"on\": false}" http://192.168.1.xx/api/xxxx/lights/7/state
sleep 2
curl --request PUT --data "{\"on\": false}" http://192.168.1.xx/api/xxxx/lights/5/state
curl --request PUT --data "{\"on\": true}" http://192.168.1.xx/api/xxxx/lights/7/state
sleep 2
echo $(date +%H:%M)
echo $1
done
The off action script kills the script running in background and makes sure the lights are off:
script:///home/pi/domoticz/scripts/bash/christmas_tree_off.sh
#!/bin/bash
killall christmas_tree_on.sh
The group is controlled by timers.
bbqkees
Domoticz version: 4.1x
Re: Simple Christmas Tree Script for Philips Hue
Post by bbqkees »
If your goal is to just turn the lighting on and off why are you using a script instead of the built in timers?
You can just add the LivingWhites as switches in Domoticz and add the timers there or create a scene with timers.
mcduarte2000
bbqkees wrote:If your goal is to just turn the lighting on and off why are you using a script instead of the built in timers?
The script above is turning intermittently each row of light every two seconds (blinking). From what I see, timers don't even have seconds and don't have a way of repeating a cycle (I would have to create n on/offs).
bbqkees
Post by bbqkees »
Ok I did not notice the 'sleep' statements.
Maybe nice to use the dimmer function (if you are not using LED christmas lights)?
You can also set sweeps and blinks etc via the Hue API.
GerardM
Post by GerardM »
Nice,
Adapted it to my needs..
Using nc instead of curl
Just one question, why is there a '&' at the end of your script line ?
[edit]
My ipad prints the wrong caracter when i wat to type '&'
The character i mean is the enpercent sing
Domoticz newbee | arduino and Esp8266 hobbyist
mcduarte2000
GerardM wrote:Nice,
[edit]
It is to send the process to the background, if not, from what I saw, Domoticz would wait for the script to stop (and it doesn't until the time I set on it).
andrew0123
Post by andrew0123 »
It is a good idea.
Christmas lights mean lines — that is quite recently the way it is. Air is attempting to change that with a remote lighting framework that appears to be something out you had always wanted. The enormous, delightful Aura knobs dangle from your trees like trimmings, however, they're considerably more cutting edge than the silver balls you're accustomed to snaring from the branches.
