I have a question about my raspberry with rfxcom.
Can i control zwave and klik aan klik uit together?
Zwave and kaku
- jvdz
- Domoticz version: 4.107
Re: Zwave and kaku
You can't control ZWAVE with RFXCOM.
When you also attached an ZWAVE controller next to the RFXCOM, you will be able to control both ZWAVE and KAKU.
Jos
Jos
Jango
Re: Zwave and kaku
If I buy an usb zwave stick that plugs in the raspberry, Is that enough?
Which usb stick would you advice?
- Egregius
- Domoticz version: v2024.7
Re: Zwave and kaku
Works perfectly together. The mix of different hardware is de biggest advantage of Domoticz.
I have rfxcom and Aeon Z-stick but I guess you should go for Zwave+ stick now.
Jango
Re: Zwave and kaku
Thanks for the quick response
- jvdz
Re: Zwave and kaku
That is indeed what I have: and RFXCOM E USB with a OpenZWave USB and they work very nicely together.
Jos
Jos
