Z-Weather
Ricard1
Z-Weather
Post by Ricard1 »
Hi All,
Just included my new Z-Weather wind/weather meter but it seems I get no values from it... Searched for Z-Weather but did not get a single hit here! Am I the first one with it? :lol: :?:
Product link: http://www.popp.eu/products/sensors/z-weather/
Cheers!
/Ricard
gizmocuz
Re: Z-Weather
Post by gizmocuz »
i tested this device a while back.... what version of domoticz are you using ?
also note, that this device does send updates on it's own time frame... it could take some time
also while testing, the battery drained very fast...
Ricard1
Re: Z-Weather
Post by Ricard1 »
Thank's I'm using 2.3530.
Still no data received.. However I am not experienced in Z-Wave devices, I migth do something wrong... Just been running some 433 devices for a month now and it works fine, mostly, so I realized I wanted a more reliable system for critical functions. Yesterday I started with some Fibaro Smoke sensors and they showed up with sensor data. I did not test if they trigger fedbeck on smoke or heat but will test that to be sure.
I have tested manualy "request configuration" but no responce from the Z-Weather (or smoke sensors), only time I get "last seen" updated is if I "repair" the nodes or Razberry radio.
Best regards,
Ricard
Razberry nodes.JPG (122.53 KiB) Viewed 1362 times
gizmocuz
Re: Z-Weather
Post by gizmocuz »
i see there is no configuration file for the z-wave.me
my test node was showing as 'popp'
you could copy/paste the popp configuration in the manufacturer specific file and add it to Z-Wave.me
also make sure your controller (node 1) is in group 1 of the zweather, better to consult the manual to see to which group the zweather is reporting (most times group 1)
Ricard1
Re: Z-Weather
Post by Ricard1 »
Thanks sounds promising. However no power avaliable for testing, not even at sun set today... :( ok it was a cloudy and rainy day, not much light to charge the built in capacitor, still it have to be designed to work regardless of winter and bad weather! If the Z-Weather keeps failing in solar powering I have to return it for money back. Hope it will be enough solar rays tomorrow...
Cheers!
