Doorbell stays "on"
pecora
Doorbell stays "on"
Post by pecora »
I try to build an event with my doorbell, it needs to be "off" but it stays always "on".
Did I something wrong... :mrgreen:
LJ80
Re: Doorbell stays "on"
Post by LJ80 »
pecora wrote:I try to build an event with my doorbell, it needs to be "off" but it stays always "on".
I think you need to give more info, what event, which type of doorbell etc.
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
You could edit your doorbell switch and add an off delay of 5 seconds or so.
Heisenberg
Post by Heisenberg »
without more info or screenshots it's error guessing :)
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
badubo
Post by badubo »
same issue, did you find any solution?
pj-r
Domoticz version: V3.8650
Post by pj-r »
If you dont have off button in your doorbell you have to edit it and set off delay manually. Or how do you think it knows to go back to off state. Same thing with PiR.. :)
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
StanHD
Post by StanHD »
I don't think you need to turn it off.
I pause my Sonos like this:-
My doorbell switch is always on but blockly waits for a "new" on before it triggers again. I just press the Sonos switch back on again to resume play.
Python:- Broadlink RM2, Sonos
G3rard
Domoticz version: No
Post by G3rard »
The doorbell in Domoticz does not have an off delay.
I have solved this by making a virtual switch and a LUA script that turns that switch on when the doorbell is rang. In that virtual switch I have set an off delay of 10 seconds.
If you use that switch in your commands (eg pause TV) then it will work.
LUA code
if (devicechanged['doorbell']) then
	if otherdevices['virtual_doorbell_switch']=='Off' then
		commandArray['virtual_doorbell_switch']='On'
Not using Domoticz anymore
Mediacj
Post by Mediacj »
Nice solution but a short period before it gone off after a short time at itself. I used it to put my tv on pause and to automatically switch the light at the door :)
Maybe there has been changed something.
pj-r
Post by pj-r »
G3rard wrote:The doorbell in Domoticz does not have an off delay.
Oh, didnt know that :shock:
You could do the same thing then with "push on" button and off delay.. or pir.. or.. of course it would lead to wrong icon.
smokinjoev
Post by smokinjoev »
Here is my setup for a driveway buried magnetic sensor that alerts me with a tone when someone drives up my driveway....
I have a few motion sensors, but this one has no persistence like somePIR do, so it is identical to your doorbell. My event fires a 433Mhz buzzer in my home, then turns it off after 5 seconds. It works really well.
It seems you are trying to do same thing as I was.
