What is the most stable platform to run Domoticz?
I have been running Domoticz for a few years now and love the software!
I mainly been using raspberry pi devices and have always been struggling with stability and have frequent outages due to the service going down or being unresponsive.
I was thinking of moving across to another platform host as a VM on me ESXI server, so could run Windows or Linux if required and keep my existing Pi’s as remote servers.
So my question is: Whats is the most stable platform to run Domoticz?
Grant
Grant
- Domoticz version: BETA
Re: What is the most stable platform to run Domoticz?
Cubietruck or Cubieboard..
Bananapi...
Perhaps something with Windows, only then you have less options...
1 of these three should i buy
Bananapi...
I'm running Domoticz on Intel NUC for almost two years now using Ubuntu and never had any issues concerning stability
My platform is a Raspberry Pi 2 24*7 without stability issues. All my sensors are wireless MySensors. All stable as it could be.
Josh
Josh
Thanks Josh,
Can I ask what version you are running and how you installed it (sd image or a custom build)?
Do you use monit? if so can you let me know your monit config? the suggest monit configuration does not work with apache and Nginx.
I am running rfxcom from my pi2 and have two other Pi (the early b model) one with piface and the other a zwave stick.
Thanks for the Info!
Grant
Grant
Same here. Intel NUC with VMware ESXi --> Ubuntu Server 14.04 LTS virtual machine --> Domoticz (compiled from source). See manual: http://domoticz.com/wiki/LinuxSweetPants wrote:I'm running Domoticz on Intel NUC for almost two years now using Ubuntu and never had any issues concerning stability
On my Synology NAS it also worked very stable, but it resulted in not letting the 2 HDD's sleep, so extra power usage.
I also use Monit on my Ubuntu setup, really handy.
- StanHD
Intel NUC under Windows. (Dedicated). Very reliable, but I have Windows Update set to manual so that I don't get uncontrolled re-starts.
This suits me because I have a Windows Home Server which does all my nightly backups and monitors the health of my PCs. (Also I have been working with Windows since the very first version which is comfortable for me ......... yep, I'm knocking on a bit
Python:- Broadlink RM2, Sonos
- Domosapiens
- Domoticz version: V3.5981
Here running on an old notebook with Windows Vista: rock stable 24/7!
Domosapiens
Domosapiens
- Domoticz version: 4.10538
Running stable on Pi 2
- Domoticz version: 3.4834
I'am curious to know what Grant choose for a stable Domoticz platform. I'm using two Rasberry Pi 2b (with Jessie lite) because of the unreliability of the Pi. My last problem was the update of Domoticz. It never worked until now, but unfortunately no Domoticz anymore. Furthermore, after a power failure ( installation work) ore a shutdown a real chance that Debian is corrupt ( mount problem etc.). A real frustrating experience until now.
Perhaps I use the wrong mem. cards, no idea.
I was thinking about Synology NAS, but hesitated after the remark of Thinkpad about the problem with the hdd.
- Westcott
Perhaps I'm lucky, or tempting fate, but I've been using a "Samsung Memory 16 GB PRO Micro SDHC Memory Card" in my Pi2 since the end of 2015.
- sincze
- Domoticz version: 2024.4
I am using Cubietruck with Debian Jessie + Integrated Battery pack in case of power outage.
For stability: SSD inside
the case.
Domoticz is Monitored by Monit and a script I found here: viewtopic.php?t=15167#p111461
Alerts I receive via telegram / sms or e-mail. In case something is wrong.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Ehhhh Windows and 'stable'Domosapiens wrote: ↑Tuesday 24 November 2015 0:00 Here running on an old notebook with Windows Vista: rock stable 24/7!
