Elro PIR detector HA32P
alfred
Post by alfred »
does anyone know how to connect a Elro PIR detector HA32P to my Raspberrypi Domoticz
kind regeards,
Alfred
gizmocuz
Re: Elro PIR detector HA32P
Post by gizmocuz »
do you have some more information? like the link to the hardware?
alfred
Post by alfred »
I'm new here, so I don't understand what you mean,
I have a Raspberry pi with a RFXCOM - RFXtrx433 USB 433.92MHz receiver.
I also have a Elro PIR detector HA32P and a klikaanklikuit apa2-2300r
they both can't be found by the raspberry rfxcom configuration
I've tried to manual add the devices, but they are not recognized
gizmocuz
Post by gizmocuz »
For the apa2-2300r, the remote should be received, make sure you enabled the ERC protocol.
You could also manually add an ARC switch, and set the apa2-2300r wall socket in learn mode,
then press the test button, and you have learned the new domoticz switch in the socket.
The PIR, i dont know what protocol it uses, but it is probably in the user manual of the RFXTRX433
alfred
Post by alfred »
thank you, the apa2-2300r is added, I can't find the protocol of the PIR
gizmocuz
Post by gizmocuz »
That is why in my first reply i asked to a link of the hardware
