How to create a switch has two speeds
warp
Post by warp »
How to create a switch has two speeds, eg a VMC.
Off, Speed 1, Speed 2
Raspberry 2B:RaZberry Z-Wave+:Edimax EW-7811UN:Huawei E220 3G
4xQubino ZMNHCA2
Everspring SE812 & ST812
Mcohome MH-S411 & MH-S412
2xAEON LABS ZW-100
2xFibaro FGSD-002:Fibaro FGFS-101:Fibaro FGS-221 & KLF-050
McSoda
Domoticz version: 2.3771
Re: How to create a switch has two speeds
Post by McSoda »
Hi warp,
I'm new to the forum, then I m just seeing your question.
For ventilation (VMC), I use a zwave device : Popp / Duwi ZW ESJ Blind Control. The speed 1 is connected to the down and the speed 2 to the Up. This works fine when I push the button directly on the device, but I'm unable for now to control the up and down from Domoticz. Domoticz seems to not correctly handle this device: it see the control as a dimmer, not a blind control.
If you purchase a device fully recognised by openzwave, you should be able to control your VMC.
Regards,
McSoda
Domoticz running on Synology 212j (main), Raspberry Pi B rev2 (remote)
Modules : z-wave, x10, teleinfo, karotz
McSoda
Post by McSoda »
Well, I finally found the correct configuration (things could seem obvious for most of the people but I'm discovering Domoticz :-).
* Select the device type to On/Off in Domoticz
* Set the running time to 0 in the zwave device configuration.
* Set Ignore Start Level to Off (OpenZwave Control Panel / Information tab)
Then, setting the device to "Off" in the Domoticz GUI starts the VMC at low speed.
"On" sets the high speed.
The draw back is you can't set easily the VMC off from the Domoticz GUI.
McSoda
