2015-11-11 19:07:51.783 (NestHuiskamer) Thermostat (HuiskamerTemperatuurInstelling)
2015-11-11 19:07:51.841 LUA: Motion sensor script started......
2015-11-11 19:07:51.850 LUA: Door Bell script started......
2015-11-11 19:07:51.826 (NestHuiskamer) Temp + Humidity (HuiskamerTemperatuur)
2015-11-11 19:08:00.350 LUA: -- Rene is at home, check when the lights need to be enabled.....
2015-11-11 19:08:00.497 Hardware Monitor: Fetching data (System sensors)
2015-11-11 19:08:00.519 LUA: Motion sensor script started......
2015-11-11 19:08:00.532 LUA: Door Bell script started......
2015-11-11 19:08:00.579 LUA: Motion sensor script started......
2015-11-11 19:08:00.592 LUA: Door Bell script started......
2015-11-11 19:08:00.647 LUA: Motion sensor script started......
2015-11-11 19:08:00.656 LUA: Door Bell script started......
2015-11-11 19:08:00.689 LUA: Motion sensor script started......
2015-11-11 19:08:00.698 LUA: Door Bell script started......
2015-11-11 19:08:00.746 LUA: Motion sensor script started......
2015-11-11 19:08:00.755 LUA: Door Bell script started......
2015-11-11 19:08:22.822 LUA: Motion sensor script started......
2015-11-11 19:08:22.831 LUA: Door Bell script started......
2015-11-11 19:08:22.807 (NestHuiskamer) Thermostat (HuiskamerTemperatuurInstelling)
2015-11-11 19:08:22.865 LUA: Motion sensor script started.....
Why LUA script execute multiple times per second
rgroothuis
I've developed multiple LUA scripts, I recently noticed that my doorbell script is executed multiple times. Or even worse on one doorbell push I get multiple notifications over Telegram. This means the script is executed multiple times. I only have one doorbell script in the LUA script directory. What is causing this problem?
- jvdz
- Domoticz version: 4.107
Re: Why LUA script execute multiple times per second
The Device lua scripts are started each time any device is updated.
So also when you update a device in your lua script ALL device scripts will be fired again.
Key is to only set commandArray actions when you really need to change anything.
Jos
Jos
rgroothuis
Ok, clear. This means in that one (example) second I've 7 times a commandArray update. Otherwise I would not see that many script executions.jvdz wrote:The Device lua scripts are started each time any device is updated.
Jos
I need to find out which script is responsible for this. It is a bit strange because all my scripts have the following framework:
print('Motion sensor script started......')
if (devicechanged['MailBoxMotionDetected'] == 'On') then
print('-- Mailbox usage detected at '.. os.date("%d/%m/%Y %X") .. '!')
-- os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..message..'" "https://api.telegram.org/bot'..token..'/sendMessage" ')
return commandArray- jvdz
Correct so it is either one of your defined devices receiving an update or one of your scripts setting a commandArray['device']='something'.
Jos
Jos
rgroothuis
Any suggestions on how to check/debug this? I just checked my LUA scripts and I cannot see a commandArray['device']='something' outside an if statement in which devicechanged is checked.jvdz wrote:Correct so it is either one of your defined devices receiving an update or one of your scripts setting a commandArray['device']='something'.
Jos
Is there a possibility in Domoticz so see which devices last have been changed?
- jvdz
You could add a print() inside of the if when you actually set a command to be performed, then you know for sure, but actually you can already see it now because the log will contains a
record like this in case an action is performed:
One other thing I understood is that the current production version will fire all device events for all known devices, not just the enabled devices.
Jos
EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_xyz.luaJos
rgroothuis
Thanks Jos, your last comment is probably the reason. Because I don't see that:
line in my log file every X seconds.
So it is not originating from a LUA script that sets the commandArray[] incorrectly. It has to come from one device changes inside Domoticz. In this situation it would be nice if I could see in a total overview which devices had a status change at which moment in time.
EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_xyz.luaSo it is not originating from a LUA script that sets the commandArray[] incorrectly. It has to come from one device changes inside Domoticz. In this situation it would be nice if I could see in a total overview which devices had a status change at which moment in time.
- jvdz
Guess you could just look at the devices view (Setup/Devices) and sort on date Last Seen. Maybe that gives you an idea.
Jos
Jos
