Reading Humidity Dummy sensor
usky73
Domoticz version: 2021.1
Post by usky73 »
Hi all
I am using a dataloger to read humidity & temperature.
I have used dummy devices + json solution to update the sensors values, and it works fine.
I am trying to merge humidity & temperature in the same sensor with a LUA script. My idea is to read temp & humidity values and to push them on a new dummy devie (Temp+Humid).
I found how to read the dummy temp value, how to write the values in the new dummy combined sensor.
But I did not succeed to read the Humidity dummy sensor value.
Here is my code :
sensorhumid = otherdevices_svalues[sensorh]
Where sensorh is the sensor name 'bathroom humidity 12345'
This function return the HUM_STAT but not the Humidity level...
Any idea ?
