I need help you!
Can I ask for example events in wicht I send notification in few minutes after events?
THX
How send notification few minutes after events_
- Domoticz version: 2022.2
Re: How send notification few minutes after events_
Easiest way (I think) would be start a bash script, wait the desired time and sens the notification via json.
- Egregius
- Domoticz version: v2024.7
To be clear: if an event (motion, contact whatever) occurs, you want to wait several minutes before sending the notification? Does the event still need to be 'actual' at that point?
I think you need to explain a bit more the situation. I want notification to be sent asap, before burglars might cut the power.
- Domoticz version: 2.2563
Yes, if an event (motion, contact whatever) occurs, I want to wait several minutes before sending the notification! For example when my door garage stay open for 5 minutes I want get notification of them.Egregius wrote:To be clear: if an event (motion, contact whatever) occurs, you want to wait several minutes before sending the notification? Does the event still need to be 'actual' at that point?
Maybe but I don't know how I can dojannl wrote:Easiest way (I think) would be start a bash script, wait the desired time and sens the notification via json.
I would have to google a lot as well, nothing I did yet.
But I think there example scripts for what you want in wiki
- Domoticz version: Stable
You can create an virtual switch (for example named notification). Set on delay of this switch as you wish and off delay at for example 5 sec.
Blockly
if ... (trigger device) is on
do set notification on
if notification is on
do sent notification
Blockly
- Egregius
Oh, that way. I have that in my PHP scriptscatman wrote:Egregius wrote:For example when my door garage stay open for 5 minutes I want get notification of them.
if($Spoort!='Closed') {if(xcache_get('alertpoort')<$time-900&&$STpoort<$time-900) {$msg='Poort Open sinds '.strftime("%H:%M:%S", $STpoort);xcache_set('alertpoort',$time);telegram($msg);}}
Jan Jansen wrote:You can create an virtual switch (for example named notification). Set on delay of this switch as you wish and off delay at for example 5 sec.
Blockly
THX I used this advice.
