Mi-Light WiFi Bridge
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
Anyone is using Mi-Light Wifi Bridge with domoticz? The bridge is being kicked out of network periodically - this is very annoying :oops:
How can I update the firmware? I am also looking at http://servernetworktech.com/2014/09/li ... pberry-pi/
to convert it to wired rather than wireless.
I also have a problem with colours - it is blue instead of red etc. How can I correct it?
Alex
bizziebis
Domoticz version: 3.8805
Re: Mi-Light WiFi Bridge
Post by bizziebis »
I use Mi Light with Wifi bridge for 1,5 years now with almost no problems. I had to unplug the device maybe 3 times, but that was due to a change in my dhcp setup. I do have assigned a static IP to the bridge in the DHCP table of my router. I don't recognise the color problem you described..
safi78
Domoticz version: LastBeta
Post by safi78 »
My bridge disconnects alot of times per day as well, wouldn't be surprised if these (cheap!) things have a bit of a connection problem 'built-in' ;)
I connected my bridge to a 433mhz switchable wall outlet and ping it. When it's not there, switch Off/On and it's back. Fairly dumb workaround.
About the color prob's, seen that alot too (me, friends, etc).
My HUE-stuff doesn't have any of these problems ;)
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
bizziebis
Post by bizziebis »
Looks like I was lucky to get a stable version bridge. Maybe the power supply can also be a reason of error?
alexsh1
Post by alexsh1 »
bizziebis wrote:Maybe the power supply can also be a reason of error?
Tried various power sources - from router's USB to 2A power supply. I can assure you that the reason for this problem is not power.
alexsh1
Post by alexsh1 »
safi78 wrote: I connected my bridge to a 433mhz switchable wall outlet and ping it. When it's not there, switch Off/On and it's back. Fairly dumb workaround.
I looked at it too, but do not think this is a good workaround.
I am now looking at this -> http://servernetworktech.com/2014/09/li ... pberry-pi/
I guess I am the lucky one to have a bridge with wireless issues.
safi78
Post by safi78 »
I don't think it's good either. But it works . And we're both lucky
alexsh1
Post by alexsh1 »
I tried the bridge in a different location and it looks that it works flawlessly. No idea what may have caused the issue, but I think this is multiple WiFi networks at my place. Will have to modify the bridge.
alexsh1
Post by alexsh1 »
Just to let you all know I bought a new WiFi bridge and it is super unstable. I think it must be the network or combination of things. Modification is unavoidable if I have to stick to Mi-light.
sijones
Domoticz version: Git
Post by sijones »
Mine has been fine.
I'd look at the channel your using and see if there is many others in the area using the same channel. 2.4g gets very busy and the drop outs i'd say was possibly down to this.
Simon
alexsh1
Post by alexsh1 »
OK, I think I found the problem. Apple TV - as soon as I disconnected (unplugged) it, the bridge started working fine. I am still testing it.
