Z-Wave.Me ZME_KFOB-S 4 Button Key Fob
jeeeberne
- Domoticz version: V2.3502
Re: Z-Wave.Me ZME_KFOB-S 4 Button Key Fob
Thanks for your reply ben92. I'll try tonight, but I'm pretty sure that I've already done this step and no particular log appears in Domoticz "log part" (neither in the Open Zwave log : OZW_Log.txt).
Perharps we have issue about our drivers (controller ? the kfob ? kfob firmware ?). That's could explain why we don't manage to realize a so simple step.
From the other research I've made, the (new) Aeotec Z-Stick Gen5 seems to be usable for Domoticz.
If I understood well the manufacturer information, It be more simple than before : "The Z-Stick Gen5 now uses UZB drivers instead of Silabs UART to USB. There is no need to install the UZB drivers in OSX and Linux as these OS already have drivers that will allow the use of the Z-Stick Gen5 without the UZB drivers."
The Synology OS couldn't be considered as a real Linux distribution I think. But I've tried also under Windows and install the specific driver, without better results.
@fpatou,
What is exactly the version of your Zwave Controller ?
@tophattaylor,
R U still with us ? Did you manage to add device from your ZME_KFOB-S ?
@fpatou,
@tophattaylor,
fpatou
For sure it does not happen for me like this
.i click button and no device are created
the device is awake when you do this ?
can you make a sceen shot like this ?
- kfob.jpg (73.96 KiB) Viewed 3519 times
fpatou
i don't find the controler firmware information
anywhere in the domoticz. I will try soon too enbale log of the conroler i guess the information will be inside.
OpenZWave USB
Version: 1.3-523-gb258e9e
001 (0x01) Controller Z-Wave.Me ZME_UZB1 USB Stick
OpenZWave USB
fpatou
ben92 can we have your configfile used( kfob.xml or ZME_KFOB-S.xml) as a attached file ?
and i guess i will give atry to this porcedure :
https://github.com/OpenZWave/open-zwave/issues/656
fpatou
Hello...
find here the result of my investigations...as i m not ready to give up
Yesterady coming back home i have tested to delete the kfob from material list and to reinclude it after some modification of xml files....and this succeed
the full setup and communication between kfob and zwave controler was ok.
I've got switch created and i was able to activate it (but only as ON
) i was not able to send OFF command. It was a first step.
after playing with the kfob i insiste to find out about the fact that i could succeed with a off command and then i delete the kfob from material and include it again....and then AGAIN the kfob was muted and no switch were created. then go back to the inital step : a muted kfob !
What i suspect after reading this article : http://www.z-wave.info/how-to-handle-ba ... -zme_kfob/ Is a issue with the eprom write of the kfob due to battery.
to be continued
to be continued
jeeeberne
Hello fpatou,
Thanks for not giving up
I hope you're near the truth by pointing out battery issue. Have you seen this post ?
viewtopic.php?f=6&t=3746&start=20
It seems that bjoern have exactly the same issue as us. The solution seems to be too simple : change the battery (ref : CR2032).
I'll try to buy one tomorrow.
As you said : to be continued
ben92
i use kfob.xml.
do u try to exclude, reset and re include properly ?
do u delete line of the kfob in the file zwcfg_XXXXX.xml ?
ben92
ok fpatou, i dont see ur post .... its ok for u.
the kfob doesnt send OFF command !!! its normal.
fpatou
Yes I know now....but you know about the fact that sometimes one click too far
....and from there never be able to fully integrate it again
fpatou
always the same schema timeout and no switche creation (with new battery!):
2015-11-06 20:23:21.459 OpenZWave: Node Include command initiated...
2015-11-06 20:23:24.009 OpenZWave: New Node added. HomeID: 4208202907, NodeID: 30 (0x1e)
2015-11-06 20:23:24.066 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2015-11-06 20:23:24.069 (ZwaveME) Lighting 2 (Unknown)
2015-11-06 20:23:24.077 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2015-11-06 20:23:24.077 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2015-11-06 20:23:24.078 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2015-11-06 20:23:34.386 OpenZWave: Received timeout notification from HomeID: 4208202907, NodeID: 30 (0x1e)
jeeeberne
Exactly the same. Not better with a new battery...
ben92
Parameters are ok ?
Its a battery node so the timeout is not a problem.
- exclude
- include
- wake up
-set parameters in DZ and send it
- wake up for parameters
Normaly it works....
Parameters are ok ?
- exclude
- include
- wake up
fpatou
Alleuia ! ...
This morning sun is shining and kfob is back to life
after another exclude restet include etc...
I did the following :
starting state is kfob inclued but muted
1 :delete all UNUSED devices from domoticz (as i supected a kind of conlict on this)
2 : without deletion or exclusion : include the kfob again
3 : Setup manualy association for the Five groups to the controller node 1
4 : wake up the kfob...done!
I can see many devices switch as before !
find here log....
2015-11-07 10:21:28.995 New sensors allowed for 5 minutes...
2015-11-07 10:21:28.995 OpenZWave: Node Include command initiated...
2015-11-07 10:21:38.325 OpenZWave: Node Removed. HomeID: 4208202907, NodeID: 31 (0x1f)
2015-11-07 10:21:38.376 OpenZWave: New Node added. HomeID: 4208202907, NodeID: 31 (0x1f)
2015-11-07 10:21:38.376 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2015-11-07 10:21:38.377 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:38.383 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2015-11-07 10:21:38.383 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2015-11-07 10:21:38.384 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2015-11-07 10:21:49.172 OpenZWave: Received timeout notification from HomeID: 4208202907, NodeID: 31 (0x1f)
2015-11-07 10:21:56.179 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:56.187 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:56.267 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:56.275 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:56.577 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:56.585 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.027 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.034 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.040 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.047 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.103 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.111 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.117 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.125 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.396 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.402 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.463 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.468 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.547 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.553 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:57.894 Hardware Monitor: Fetching data (System sensors)
2015-11-07 10:21:58.048 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:58.054 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:58.566 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:58.632 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:59.311 (ZwaveME) Lighting 2 (Unknown)
2015-11-07 10:21:59.761 (ZwaveME) Lighting 2 (Unknown)
find here log....
jeeeberne
Marvellous.
It works.
Thanks a lot fpatou.
I hadn't do step 1 (not able to deleted my very few unsued devices such as old motherboard sensors, this kfob is my first OZW device).
For step 3, I try using "Group & Network" from my Zwave Controller and set node 1 to each group and then apply configuration to my kfob. Is that the way you do ? When I go back "Goup & Network", I don't see my change.
But it works. I've 15 new devices (curiously, it misses only double click on button 4).
Thanks a lot again fpatou. You're my hero
It works.
fpatou
step 4 :wake up the kfob...4 bnt and then btn 2 to update kfob config and see changes in groups associations
From there kfob remote my SONOS
and a heater !!!
Comme quoi qd on cherche ...on trouve !
A bientot
A bientot
jeeeberne
Exactly. But it's sometimes hard to find
. Including 2 times the same device without excluding it before was not obvious. Neither the manual association. You've found some informations that lead to this process or it was just a (good) feeling ?
Thanks also to ben92 for its support too
Have a nice we
Have a nice we
fpatou
hello you are right : thank you to all contributor to this thread !
hope this will help some other users.
Bye
Bye
dolusystem
- Domoticz version: 2.3530
I have read this usefull post because I have the same issue with that KFOB-S Key, I have only one main device installed but no other device creation when I press the KFOB buttons.
If I well understood, I need to install again the KBOF without uninstall it to allow the auto creation of device when I press the button 1 to 4
I will try this.
To include the Key I did it with a double click on button 1, after putting the key in manage mode, the simple click did nothing.
I will try this.
