ELV Max! Heating control system
- l0gic
- Domoticz version: Latest
Re: ELV Max! Heating control system
Hi roman1528,
put your dummy back in
I run mine in Windows so can't give you any specific assistance.
However, looking at your domoticz script output it looks like you are picking up your devices ok.
Have you looked at the other logs in Max!Buddy to see if you have any errors reported at all?
It may give you a starting point.
Also try deleting the objects in Domoticz, if they are received again (will be if the script is working) they will repopulate.
If they don't then you have an issue between Max!Buddy and Domoticz.
All the best
Kevin
All the best
Kevin
Non credus crepitus
- Domoticz version: lat.beta
normally the domoticz script in maxbuddy should debug the values read from maxbuddy and the url wich opend to domoticz... but there is nothing... not in log not while running in console...
the hardware dummy in domoticz is in and activated! no devices created yet! cause there is no action to domoticz!!!
in maxbuddy (non headless) is all ok ... rooms, temperatures, devices... all at the right place and shown ... so headless have to get the same... devices values ...
it seems that domoticz script can't read these values... if i add a custum debug line the value is shown... so all must be fine... no error in maxbuddy or domoticz... just the script is not working ... i copied it and just changed HID PORT and IP
it worked meanwhile 4 days ago.. i had to setup all new cause of sd-card crash... the image, the installation of maxbuddy and domoticz is all the same... just the HID is a other one...
maxbuddy log:
maxbuddy log:
[2015-10-23 13:47:16,700] [DEBUG]: updateWallThermostatTemperatures()
[2015-10-23 13:47:16,702] [DEBUG]: updateRadiatorThermostatTemperatures()
[2015-10-23 13:47:16,704] [ INFO]: DUMP SYSTEM
[2015-10-23 13:47:16,705] [ INFO]: Room: Bad (3)
[2015-10-23 13:47:16,706] [ INFO]: Device: Wandthermostat (WallMountedThermostat | LKF0026190 | 1090301 | 16)
[2015-10-23 13:47:16,707] [ INFO]: Device: Thermostat (HeatingThermostat | KEQ0992947 | 852776 | 16)
[2015-10-23 13:47:16,708] [ INFO]: Device: Fensterkontakt rechts (ShutterContact | LEQ1157609 | 1087363 | 16)
[2015-10-23 13:47:16,710] [ INFO]: Room: Büro (1)
[2015-10-23 13:47:16,711] [ INFO]: Device: Wandthermostat (WallMountedThermostat | LKF0026362 | 1090533 | 16)
[2015-10-23 13:47:16,711] [ INFO]: Device: Thermostat (HeatingThermostat | KEQ0993833 | 854213 | 16)
[2015-10-23 13:47:16,712] [ INFO]: Device: Fensterkontakt rechts (ShutterContact | LEQ1156889 | 1086605 | 16)
[2015-10-23 13:47:16,713] [ INFO]: Room: Küche (2)
[2015-10-23 13:47:16,713] [ INFO]: Device: Thermostat (HeatingThermostat | JEQ0618718 | 407155 | 22)
[2015-10-23 13:47:16,714] [ INFO]: Device: Wandthermostat (WallMountedThermostat | LEQ1152452 | 1090990 | 16)
[2015-10-23 13:47:16,715] [ INFO]: Device: Fensterkontakt rechts (ShutterContact | LEQ1156849 | 1086658 | 16)
[2015-10-23 13:47:16,715] [ INFO]: Room: Wohnzimmer (4)
[2015-10-23 13:47:16,720] [ INFO]: Device: Thermostat (HeatingThermostat | KEQ0991634 | 917594 | 16)
[2015-10-23 13:47:16,720] [ INFO]: Device: Wandthermostat (WallMountedThermostat | LEQ1152239 | 1091173 | 16)
[2015-10-23 13:47:16,721] [ INFO]: Device: Fensterkontakt rechts (ShutterContact | LEQ1073084 | 1009923 | 16)
[2015-10-23 13:47:16,721] [ INFO]: Room: Schlafzimmer (5)
[2015-10-23 13:47:16,722] [ INFO]: Device: Fensterkontakt rechts (ShutterContact | JEQ0608068 | 401885 | 19)
[2015-10-23 13:47:16,723] [ INFO]: Device: Thermostat (HeatingThermostat | KEQ0344922 | 446375 | 24)
[2015-10-23 13:47:16,723] [ INFO]: Device: Wandthermostat (WallMountedThermostat | LKF0026366 | 1090538 | 16)
[2015-10-23 13:47:16,724] [ INFO]: Room: Wärmeunterbett (6)
[2015-10-23 13:47:16,725] [ INFO]: Device: Zwischenstecker (HeatingThermostat | KEQ9016681 | 860506 | 17)
[2015-10-23 13:47:16,726] [DEBUG]: Scheduling watchdogs...
[2015-10-23 13:47:16,734] [DEBUG]: Scheduling refresh daemon...
[2015-10-23 13:47:16,911] [DEBUG]: Loading script: Domoticz.js
--> actual temperature: 21.8° C (Bad)
--> actual temperature: 23.0° C (Büro)
--> actual temperature: 22.1° C (Küche)
--> actual temperature: 20.4° C (Wohnzimmer)
--> actual temperature: 18.4° C (Schlafzimmer)
[2015-10-23 13:47:18,946] [DEBUG]: updateRadiatorThermostatTemperatures()
[2015-10-23 13:47:18,950] [DEBUG]: updateWallThermostatTemperatures()
[2015-10-23 13:47:21,734] [DEBUG]: disconnect()
[2015-10-23 13:47:22,397] [DEBUG]: executeScript(Domoticz.js)
[2015-10-23 13:47:22,685] [DEBUG]: Script debug (Domoticz.js): Start run()
[2015-10-23 13:47:22,837] [DEBUG]: Script debug (Domoticz.js): Room = Bad
[2015-10-23 13:47:22,849] [DEBUG]: Script debug (Domoticz.js): Mode = AUTO
[2015-10-23 13:47:22,993] [DEBUG]: Script debug (Domoticz.js): Device = Wandthermostat
[2015-10-23 13:47:22,998] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LKF0026190
[2015-10-23 13:47:23,000] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,031] [DEBUG]: Script debug (Domoticz.js): Device = Thermostat
[2015-10-23 13:47:23,033] [DEBUG]: Script debug (Domoticz.js): SerialNumber = KEQ0992947
[2015-10-23 13:47:23,035] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,037] [DEBUG]: Script debug (Domoticz.js): Device = Fensterkontakt rechts
[2015-10-23 13:47:23,046] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LEQ1157609
[2015-10-23 13:47:23,048] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,056] [DEBUG]: Script debug (Domoticz.js): Room = Büro
[2015-10-23 13:47:23,059] [DEBUG]: Script debug (Domoticz.js): Mode = AUTO
[2015-10-23 13:47:23,062] [DEBUG]: Script debug (Domoticz.js): Device = Wandthermostat
[2015-10-23 13:47:23,063] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LKF0026362
[2015-10-23 13:47:23,064] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,066] [DEBUG]: Script debug (Domoticz.js): Device = Thermostat
[2015-10-23 13:47:23,067] [DEBUG]: Script debug (Domoticz.js): SerialNumber = KEQ0993833
[2015-10-23 13:47:23,068] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,070] [DEBUG]: Script debug (Domoticz.js): Device = Fensterkontakt rechts
[2015-10-23 13:47:23,072] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LEQ1156889
[2015-10-23 13:47:23,073] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,081] [DEBUG]: Script debug (Domoticz.js): Room = Küche
[2015-10-23 13:47:23,083] [DEBUG]: Script debug (Domoticz.js): Mode = AUTO
[2015-10-23 13:47:23,085] [DEBUG]: Script debug (Domoticz.js): Device = Thermostat
[2015-10-23 13:47:23,088] [DEBUG]: Script debug (Domoticz.js): SerialNumber = JEQ0618718
[2015-10-23 13:47:23,089] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,093] [DEBUG]: Script debug (Domoticz.js): Device = Wandthermostat
[2015-10-23 13:47:23,099] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LEQ1152452
[2015-10-23 13:47:23,105] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,107] [DEBUG]: Script debug (Domoticz.js): Device = Fensterkontakt rechts
[2015-10-23 13:47:23,109] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LEQ1156849
[2015-10-23 13:47:23,110] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,114] [DEBUG]: Script debug (Domoticz.js): Room = Wohnzimmer
[2015-10-23 13:47:23,116] [DEBUG]: Script debug (Domoticz.js): Mode = AUTO
[2015-10-23 13:47:23,117] [DEBUG]: Script debug (Domoticz.js): Device = Thermostat
[2015-10-23 13:47:23,118] [DEBUG]: Script debug (Domoticz.js): SerialNumber = KEQ0991634
[2015-10-23 13:47:23,120] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,123] [DEBUG]: Script debug (Domoticz.js): Device = Wandthermostat
[2015-10-23 13:47:23,127] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LEQ1152239
[2015-10-23 13:47:23,128] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,133] [DEBUG]: Script debug (Domoticz.js): Device = Fensterkontakt rechts
[2015-10-23 13:47:23,135] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LEQ1073084
[2015-10-23 13:47:23,137] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,143] [DEBUG]: Script debug (Domoticz.js): Room = Schlafzimmer
[2015-10-23 13:47:23,145] [DEBUG]: Script debug (Domoticz.js): Mode = AUTO
[2015-10-23 13:47:23,147] [DEBUG]: Script debug (Domoticz.js): Device = Fensterkontakt rechts
[2015-10-23 13:47:23,148] [DEBUG]: Script debug (Domoticz.js): SerialNumber = JEQ0608068
[2015-10-23 13:47:23,149] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,152] [DEBUG]: Script debug (Domoticz.js): Device = Thermostat
[2015-10-23 13:47:23,153] [DEBUG]: Script debug (Domoticz.js): SerialNumber = KEQ0344922
[2015-10-23 13:47:23,154] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,157] [DEBUG]: Script debug (Domoticz.js): Device = Wandthermostat
[2015-10-23 13:47:23,158] [DEBUG]: Script debug (Domoticz.js): SerialNumber = LKF0026366
[2015-10-23 13:47:23,159] [DEBUG]: Script debug (Domoticz.js):
[2015-10-23 13:47:23,163] [DEBUG]: Script debug (Domoticz.js): Room = Wärmeunterbett
[2015-10-23 13:47:23,164] [DEBUG]: Script debug (Domoticz.js): Mode = AUTO
[2015-10-23 13:47:23,166] [DEBUG]: Script debug (Domoticz.js): Device = Zwischenstecker
[2015-10-23 13:47:23,167] [DEBUG]: Script debug (Domoticz.js): SerialNumber = KEQ9016681
[2015-10-23 13:47:23,168] [DEBUG]: Script debug (Domoticz.js):
Raspberry Pi 2 Model B,
RFLink Gateway,
'OBI' RF Outlets,
some DS18B20 1-wire Temp.Sensors,
TSL2561 I2C Luminosity Sensor (not working at all)
RFLink Gateway,
'OBI' RF Outlets,
I can not get this to work.
Installations on the Raspberry Pi seems to be ok.
But when I run ./headless.sh I get this at the bottom???
Please help.
Please help.
[2015-11-02 09:43:33,594] [DEBUG]: MAXBuddy.run([-headless])
[2015-11-02 09:43:33,749] [DEBUG]: Settings#upgradeSettings()
[2015-11-02 09:43:34,007] [DEBUG]: Settings#flush()
[2015-11-02 09:43:34,190] [DEBUG]: Settings dump:
[2015-11-02 09:43:34,203] [DEBUG]: connect.lastport=20553
[2015-11-02 09:43:34,209] [DEBUG]: script.enabled.Domoticz.js=true
[2015-11-02 09:43:34,215] [DEBUG]: connection.reconnect=55
[2015-11-02 09:43:34,222] [DEBUG]: connect.lastip=192.168.0.175
[2015-11-02 09:43:34,228] [DEBUG]: connection.disconnect=1
[2015-11-02 09:43:34,235] [DEBUG]: settings.version=1
[2015-11-02 09:43:34,241] [DEBUG]: Searching for MAX!Cube...
[2015-11-02 09:43:34,491] [DEBUG]: Sending datagram to 255.255.255.255
[2015-11-02 09:43:34,517] [DEBUG]: Sending datagram to 224.0.0.1
[2015-11-02 09:43:34,526] [DEBUG]: receive()
[2015-11-02 09:43:34,536] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,543] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,624] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,633] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,725] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,733] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,826] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,834] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,904] [DEBUG]: Received datagram, sig: eQ3MaxAp / fw: 275
[2015-11-02 09:43:34,926] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:34,935] [DEBUG]: Received datagram, sig: eQ3Max* / fw: 0
[2015-11-02 09:43:35,532] [DEBUG]: Received datagram, sig: eQ3MaxAp / fw: 275
[2015-11-02 09:43:37,055] [DEBUG]: receive() done
[2015-11-02 09:43:37,081] [DEBUG]: Detected cube(s): 2
[2015-11-02 09:43:37,090] [ERROR]: Headless Mode: No cube found. Please specifiy a cube ip with the -connect parameter.
- Domoticz version: 4.10233
It seams that the script is unable to find your cube. Are you sure ther is no other program connected to the cube?
No other program is connected.Skippiemanz wrote:It seams that the script is unable to find your cube. Are you sure ther is no other program connected to the cube?
Hmm, perhaps the live account connection and the android app need to be closed?
How can I know what port the cube is using?
Dont know for sure but close them to be certain. The default port is 62914 if i remember correctly
Verstuurd vanaf mijn D6503 met Tapatalk
Skippiemanz wrote:Dont know for sure but close them to be certain. The default port is 62914 if i remember correctly
After closing the online function I still got the same error.
[2015-11-03 08:17:03,944] [DEBUG]: receive() done
[2015-11-03 08:17:04,038] [DEBUG]: Detected cube(s): 4
[2015-11-03 08:17:04,048] [ERROR]: Headless Mode: No cube found. Please specifiy a cube ip with the -connect parameter.
It now looks like this.
Nothing comes up in Domoticz
[2015-11-03 10:16:01,268] [DEBUG]: updateRadiatorThermostatTemperatures()
[2015-11-03 10:16:01,286] [DEBUG]: updateWallThermostatTemperatures()
[2015-11-03 10:16:02,835] [DEBUG]: disconnect()
[2015-11-03 10:16:12,834] [DEBUG]: ConnectionWatchdog:connect()
[2015-11-03 10:16:12,847] [DEBUG]: controller connect...
[2015-11-03 10:16:13,118] [DEBUG]: gateway fetchMaxCubeState()
[2015-11-03 10:16:13,555] [DEBUG]: getRawState().getHeader()
[2015-11-03 10:16:13,575] [DEBUG]: refresh()
[2015-11-03 10:16:14,744] [DEBUG]: updateRadiatorThermostatTemperatures()
[2015-11-03 10:16:14,753] [DEBUG]: updateWallThermostatTemperatures()
[2015-11-03 10:16:14,761] [DEBUG]: controller.cubeState()
[2015-11-03 10:16:14,769] [ INFO]: Connection established, serial: LEQ1279671, fw: 275
[2015-11-03 10:16:14,793] [DEBUG]: updateWallThermostatTemperatures()
[2015-11-03 10:16:14,800] [DEBUG]: updateRadiatorThermostatTemperatures()
[2015-11-03 10:16:14,808] [DEBUG]: disconnect()
[2015-11-03 10:17:07,833] [DEBUG]: ConnectionWatchdog:connect()
[2015-11-03 10:17:07,840] [DEBUG]: controller connect...
[2015-11-03 10:17:08,120] [DEBUG]: gateway fetchMaxCubeState()
[2015-11-03 10:17:08,458] [DEBUG]: getRawState().getHeader()
[2015-11-03 10:17:08,472] [DEBUG]: refresh()
[2015-11-03 10:17:09,181] [DEBUG]: updateRadiatorThermostatTemperatures()
[2015-11-03 10:17:09,189] [DEBUG]: updateWallThermostatTemperatures()
[2015-11-03 10:17:09,197] [DEBUG]: controller.cubeState()
[2015-11-03 10:17:09,203] [ INFO]: Connection established, serial: LEQ1279671, fw: 275
[2015-11-03 10:17:09,209] [DEBUG]: updateWallThermostatTemperatures()
[2015-11-03 10:17:09,216] [DEBUG]: updateRadiatorThermostatTemperatures()
[2015-11-03 10:17:09,810] [DEBUG]: disconnect()
What is all this Error. Java problmes?
[2015-11-10 00:08:04,074] [DEBUG]: Loading script: Domoticz.js
[2015-11-10 00:08:05,823] [ERROR]: Error evaluating script
javax.script.ScriptException: sun.org.mozilla.javascript.EvaluatorException: missing ; before statement (<Unknown source>#147) in <Unknown source> at line number 147
at com.sun.script.javascript.RhinoScriptEngine.eval(RhinoScriptEngine.java:224)
at com.sun.script.javascript.RhinoScriptEngine.eval(RhinoScriptEngine.java:240)
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264)
at org.fenwulf.maxbuddy.scripts.JavaScript.reload(JavaScript.java:134)
at org.fenwulf.maxbuddy.scripts.JavaScript.<init>(JavaScript.java:58)
at org.fenwulf.maxbuddy.scripts.Scripts.checkScripts(Scripts.java:49)
at org.fenwulf.maxbuddy.scripts.Scripts.<clinit>(Scripts.java:22)
at org.fenwulf.maxbuddy.MAXBuddy.openMainWindow(MAXBuddy.java:181)
at org.fenwulf.maxbuddy.MAXBuddy.access$000(MAXBuddy.java:50)
at org.fenwulf.maxbuddy.MAXBuddy$2.run(MAXBuddy.java:112)
at java.lang.Thread.run(Thread.java:745)
Caused by: sun.org.mozilla.javascript.EvaluatorException: missing ; before statement (<Unknown source>#147)
at sun.org.mozilla.javascript.DefaultErrorReporter.runtimeError(DefaultErrorReporter.java:109)
at sun.org.mozilla.javascript.DefaultErrorReporter.error(DefaultErrorReporter.java:96)
at sun.org.mozilla.javascript.Parser.addError(Parser.java:230)
at sun.org.mozilla.javascript.Parser.addError(Parser.java:208)
at sun.org.mozilla.javascript.Parser.reportError(Parser.java:265)
at sun.org.mozilla.javascript.Parser.reportError(Parser.java:252)
at sun.org.mozilla.javascript.Parser.reportError(Parser.java:245)
at sun.org.mozilla.javascript.Parser.autoInsertSemicolon(Parser.java:1109)
at sun.org.mozilla.javascript.Parser.nameOrLabel(Parser.java:1828)
at sun.org.mozilla.javascript.Parser.statementHelper(Parser.java:1074)
at sun.org.mozilla.javascript.Parser.statement(Parser.java:943)
at sun.org.mozilla.javascript.Parser.parse(Parser.java:568)
at sun.org.mozilla.javascript.Parser.parse(Parser.java:530)
at sun.org.mozilla.javascript.Context.compileImpl(Context.java:2403)
at sun.org.mozilla.javascript.Context.compileReader(Context.java:1328)
at sun.org.mozilla.javascript.Context.compileReader(Context.java:1300)
at sun.org.mozilla.javascript.Context.evaluateReader(Context.java:1139)
at com.sun.script.javascript.RhinoScriptEngine.eval(RhinoScriptEngine.java:214)
... 10 more
[2015-11-10 00:08:06,400] [DEBUG]: updateRadiatorThermostatTemperatures()
[2015-11-10 00:08:06,409] [DEBUG]: updateWallThermostatTemperatures()
[2015-11-10 00:08:08,442] [DEBUG]: disconnect()
Hi, I`m using Windows, Domoticz and Max. I`ve Max implemented in Domoticz via a Custom page. Works fine but I want to have one system.
I`m supprising to read that some of you have it working.
During my way to get it working I am missing the following files:
MaxEssentialsBackend-1.4.1.jar
MaxLocalBackend-1.4.1.jar
digest.txt
Please advice
Thankss
***EDIT***
Found the files in the original Max software. I`ve installed Max Buddy and followed the steps for Windows installation but it keeps saying ErrorNotFoundFile links-916.xml.
Suggestions?
digest.txt
Please advice
Thankss
***EDIT***
Suggestions?
Check out this post. Here is written how to make the links-916.xml http://www.domoticz.com/forum/viewtopic ... 960#p35960
Help
I have a Max! Cube and one radiator valve.
My plan is to extend use of the Max! system to all my radiators if it works.
Domoticz runs on my Pi
Initially the cube worked, was set up and everything seemed fine?
However since 19th October 2015 the Cube has refused to connect to the internet (The valve continues to work - I think?)
The eQ-3 Support Team have responded to my requests for help with nothing that has helped my problem, and always slowly!
My PC runs Windows 10 - with Norton 360 - It may be the case that Java was updated mid October.
I have configured Norton 360 to allow Java to connect to 192.168.0.222 Port 20669 (I think?)
FYI Latest log file attached
Can anyone help solve my problem
First computer BBC Micro
Now Windows 10
Netgear NAS
Android
Now Windows 10
Netgear NAS
Android
Re: ELV Max! Heating control system No File attached to my p
Missing Log File for my last posting - If I can make it work !!!!!!!!!!!!!!!!!!!!!!!
Sorry not very experienced using Forum !
Now Windows 10
Netgear NAS
Android
Now Windows 10
Netgear NAS
Android
the default portnumber for the MAX! cube is: 62910.
Bob.
Bob.
I`m using Domoticz with Windows.
I can`t get Max buddy working. What I try. Always the error about the download file is not found. Has someone it working on Windows Domoticz, if so which options are available.
Hi guys,
maxbuddy page is no longer available. Is there anyone who has maxbuddy windows/linux version available, could you post link to download (on some public page)?
Thanks in advance.
Thanks in advance.
- blackdog65
Erm....arctus wrote:Hi guys,
Thanks in advance.
http://www.domoticz.com/forum/viewtopic ... =80#p57883
Sorry couldn't resist it
While I'm here... I'm a little confused as to how I name my 2 RV devices. One is the actual temp. and the other is set point/open% . One I assume is RV SittingRoom but what do I name the other?
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
I followed these instructions but when starting it keeps saying file cannot be downlaoded. Any suggestions?l0gic wrote:Sean,
just checked, my instructions are for Windows only.
I'll post them up as it may give you a lead.
Hope that helpsCode: Select all
MAX! Buddy running with the new libraries yet, but the links have to download the latest libraries from the manufacturer eQ-3 and vonELV removed so that MAX! Buddy the required libraries currently can not download directly. Therefore, the error message Errors on Startup: Failed to download required libraries. However, it is possible to get MAX Buddy R9.16.2 and R9.17-beta2 to run: 1. Download the following files: MaxEssentialsBackend-1.4.1.jar MaxLocalBackend-1.4.1.jar digest.txt 2. This must for Windows XP users to folder C: \ Documents and Settings \ <username> \ Application Data \ MAXBuddy \ ext-libs \ u \ 57840205 \ Libs1-4-1 \ be copied. For Windows 7 users please to folder: C: \ Users \ <username> \ AppData \ Roaming \ MAXBuddy \ ext-libs \ u \ 57840205 \ Libs1-4-1 \ copy. WIndows 8 users copy the files into the directory: C: \ Users \ <username> \ AppData \ Roaming \ MAXBuddy \ ext-libs \ u \ 57840205 \ Libs1-4-1 \ 3. The modified file left-916.xml need for Windows XP users to folder C: \ Documents and Settings \ <username> \ Application Data \ MAXBuddy \ ext-libs \ and for Windows 7 users to folder C: \ Users \ <username> \ AppData \ Roaming \ MAXBuddy \ ext-libs \ All use the Windows 8, please to folder: C: \ Users \ <username> \ AppData \ Roaming \ MAXBuddy \ ext-libs copy. Then, very important to enable the write protection on the file, otherwise the file will be overwritten. 4. MAX! Start Buddy R9.16.2 as usual. 5. Do you use MAX! Buddy R9.17 beta2 need your modified file left-914.xml use. The 1st to 4th steps remain the same. All MAX! Buddy versions you can find here and here . Should you have problems just report briefly here in the forum. Greeting Matze
Kevin
-USing W8.
-Closed Max software itself
-------EDIT
Found it, you are speaking over The modified file left-916.xml . I saved that file with that name, but must be links-916.xml
Ive it working now
I am wondering what I can do more with Domoticz and Max, except reading the temprature?
I've got it up and running so far, however the devices are not appearing in Domoticz v2.4025.
The script sends the following command:
When I run this in a web browser, I get:
What could be wrong? Isn't Domoticz accepting JSON commands without IDX anymore?
http://[user]:[pwd]@192.168.1.196:8080/json.htm?type=command¶m=udevice&hid=8&did=6836312&dunit=1&dsubtype=9&dtype=80&nvalue=0&svalue=0
status: "ERR"
