Automatic turn on screen of tablet using camera
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Just to let you know I have set up a simple solution it combines an app from the app store called Motion Detector by jastrzab: https://play.google.com/store/apps/deta ... n.detector Then install a plugin called Turn Screen: https://drive.google.com/file/d/0B59hfs ... sp=sharing
Install both apps.
Open the Motion Detector app and turn on "Send" at the bottom of settings. Click on motion detector (at the top) and then scroll down to "camera" and select "front".
Open the Turn Screen app. click the only button to make it active.
Open android settings, Turn off the lock screen or select "none".
Change the sleep settings to time out in the desired time.
Turn off Daydream.
Open the app (or home screen) you want to have displayed on the screen when the tablet wakes, and you're all set! Wait for the screen to go to sleep and walk by or wave at your camera and it will wake it up.
Heisenberg
Re: Automatic turn on screen of tablet using camera
Post by Heisenberg »
Great tutorial! How about the battery drain?
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
Completely depending on your settings. If you have high scanning rate, high sensitivity and bright screen it will go fast.
If you lower the sensitivity and the time between events, it will last some time longer. But you need to be connected to AC for a setup like this. I have the exact same configuration running for a couple of days already.
Triangle
Post by Triangle »
Hi, the link to the Turn Screen app is dead. Googeling does not give me the right results. I'm new to android, so I'm not sure how this supposed to work. I got the motion sensor workling (it's plinging ;-), but i don't understand how a notification should trigger a screen on action.
Help and/or explanation is highly appreciated.
koenjer
Domoticz version: 3.8153
Post by koenjer »
Is it necessary to root the tablet?
Installed the apps but the screen won't wake up.
bvduijv
Post by bvduijv »
Can someone share the 'Turn Screen' app with us?
bizziebis
Post by bizziebis »
bvduijv
Post by bvduijv »
Great! Thanks for sharing!
kiwitrc
Post by kiwitrc »
I signed up just to say thanks for posting this, worked first time. Much appreciated, thank you.
sisaenkov
Post by sisaenkov »
ImperiHome can turn the screen On initially.
gurkburk
Post by gurkburk »
Bringing life to an old thread, but I can't get this to work.
I have been searching for a method of waking up android tablets and find most of the same stuff however it doesn't seem to work, trying on 2 different (although identical) samsung galaxy tab tablets.
The combination of Motion Detector + Turn Screen does not work, I get the sound notifications that it has detected motion when the screen is off, however it stays off (security settings are "none" and you can just unlock it with power or home button).
Anyone has a setup that works for this?
The idea is to have the android tablets wall mounted and auto-turn on the screen when you walk around or up to it.
Onrust
Domoticz version: 4.10717
Post by Onrust »
Neither could I, but I managed to get it to work on my Samsung Galaxy Tab with the Fully Kiosk browser. For only €4,90 you can get the PLUS license which enables you to switch on the screen on motion detection by the front camera.
jannl
Domoticz version: 2022.2
Post by jannl »
I use an older android tablet (archos 70c) with both turn screen and motion detector. Works ok for me.
Verstuurd vanaf mijn SM-G930F met Tapatalk
Derik
Post by Derik »
@ Skippiemanz
Your link is dead..
Is there a free working version of your motion?
Skippiemanz
Maybe this one... https://play.google.com/store/apps/deta ... o.activity
Verstuurd vanaf mijn SM-G935F met Tapatalk
andi216
Domoticz version: 3.7243
Post by andi216 »
Or this app (WOLᵢ²)
http://woli.asp1.at/en/
markjgabb
Post by markjgabb »
also an option for anyone else still working on this
https://www.youtube.com/watch?v=HSHvc1PYBtU
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
Derik
Post by Derik »
is there some one that know for me and is using a great and nice fullscreen browser??
Brutus
Post by Brutus »
Derik wrote:is there some one that know for me and is using a great and nice fullscreen browser??
Dolphin
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
joostnl
Post by joostnl »
Onrust wrote: Saturday 24 June 2017 10:47 Neither could I, but I managed to get it to work on my Samsung Galaxy Tab with the Fully Kiosk browser. For only €4,90 you can get the PLUS license which enables you to switch on the screen on motion detection by the front camera.
Only Fully Kiosk Browser works without any problems! So don't try the rest just buy it and spare your time :D
