BH1750 lux sensor: reading 54612 lux???
ThinkPad
Re: BH1750 lux sensor: reading 54612 lux???
0 lux.
For today it was like this, see attachment.
- lux.PNG (68.58 KiB) Viewed 12219 times
- thecosmicgate
- Domoticz version: newest
Dubbel post
- uploadfromtaptalk1446108200943.png (157.55 KiB) Viewed 12197 times
Last edited by thecosmicgate on Thursday 29 October 2015 9:50, edited 2 times in total.
It's nice to be important, but it's more important to be nice
Scooter ;)
Scooter ;)
ThinkPad
I deleted two of your messages, it looked like something went wrong
But like i said, just exchange the BH1750 for a different one, that will probably fix it.
- thecosmicgate
Already changed the BH1750 to one other , but still this low lux measurement'sThinkPad wrote:I deleted two of your messages, it looked like something went wrong![]()
Sent from my MotoG3 using Tapatalk
Scooter ;)
Scooter ;)
ThinkPad
Then i would say: check the wiring (connected to analog pin instead of digital pin by accident)? Or maybe the sketch has changed and some calculation is different... Try with a BH1750 example sketch to see what readings you get.
It should definately read more than 72 lux, my Aeon multisensor tops out at 1k lux at day, it sits in my livingroom with no direct sunlight at it.
- thecosmicgate
I used this example sketchThinkPad wrote:Then i would say: check the wiring (connected to analog pin instead of digital pin by accident)? Or maybe the sketch has changed and some calculation is different... Try with a BH1750 example sketch to see what readings you get.
I already checked the wiring 10times and already changed this to eliminate that.
I soldered the wires direct on the arduino instead of using the breadboard debont wires
Scooter ;)
Scooter ;)
ThinkPad
I don't know either then...
- thecosmicgate
I think i solved the problem lux measurement's are higher then >1000 todayThinkPad wrote:I don't know either then...
Scooter ;)
Scooter ;)
D'rMorris
How did you solve the problem? I have the same issue as you, currently reading 19luxthecosmicgate wrote:I think i solved the problem lux measurement's are higher then >1000 todayThinkPad wrote:I don't know either then...
Any help is highly appreciated
- thecosmicgate
Changed the sensor , and put it directly on the window.D'rMorris wrote:How did you solve the problem? I have the same issue as you, currently reading 19luxthecosmicgate wrote:I think i solved the problem lux measurement's are higher then >1000 todayThinkPad wrote:I don't know either then...
Sent from my MotoG3 using Tapatalk.
Any help is highly appreciated.
If you measure today the weather is that bad that the lux is very low (maybe that's all:-) )
Scooter ;)
Scooter ;)
D'rMorris
Didn't put it on the window indeed, just inside with lights on. Still, I think that 19 lux is too low. What were your readings today?
ThinkPad
Mine was around 800 during mid-day, and around 200 lux when it started to get a bit dark (~16:30).
Sensor is working really good in my situation. Faced south, behind matte window foil.
I wish i could help, but i already mentioned the things you could try (check pinout, change sensor etc).
- sincze
- Domoticz version: 2024.4
Unfortunately today I had the same issue.
However before re-flashing the sensor was working perfectly.
With that in mind I tried several different BH1750 libraries that I could find on the web and finally found one that worked.
So instead of the sensor being broken.. an 'incompatible' library can also cause problems.
From now on I keep the library with the sketch.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Mandet376
This website was designed as a component of the administration initiatives Panchayat Guru is Electronic Register and Monitoring System to finalize the annual strategy; review strategy application.
