val=val+15;Moderator: leecollings
val=val+15;Code: Select all
Measurement Mode Measurement Time. Resolution
H-resolution Mode2 Typ. 120ms. 0.5 lx
H-Resolution Mode Typ. 120ms. 1 lx.
L-Resolution Mode Typ. 16ms. 4 lx. Code: Select all
H-Resolution Mode is 1 l x resolution so that it is suitable for darkness ( less than 10 lx )
H-resolution mode2 is also suitable to detect for darkness. Maybe you've missed it, but you can find it now on github https://github.com/ESP8266nu/ESPEasyToni wrote:I'd be happy to contribute if it was a Github project
Maybe if you post it on the ESP easy website, they will look into it and maybe fix it. You can check here: http://www.esp8266.nu/forum/search.php? ... ive_topics. A newer version has been released today but is says nothing about the lux sensor in the release notes.Wirehead wrote:Hope the developer can chime in on this.. The datasheet doesn't take note of this. Basically, the sensor has 3 resolutions:An additional note concerning the default H-Resolution mode in the sheet:Code: Select all
Measurement Mode Measurement Time. Resolution H-resolution Mode2 Typ. 120ms. 0.5 lx H-Resolution Mode Typ. 120ms. 1 lx. L-Resolution Mode Typ. 16ms. 4 lx.So less than 10 lux is OK with the default setting. (H-mode 2 has some extra filtering for 50/60Hz noise). So I'm really clueless where this 15 lux comes fromCode: Select all
H-Resolution Mode is 1 l x resolution so that it is suitable for darkness ( less than 10 lx ) H-resolution mode2 is also suitable to detect for darkness.
brommetje wrote:Hi, for the ESP made easy software do I really need a Arduino or is it also possible to run/compile the software on a Raspberry PI?
Yes, http://www.esp8266.nu/index.php/LCDDisplaylukaz1987 wrote:Hi
Anybody have tutorial how send data to LCD(ESP easy)? I would be grateful.
Good to know, thanks for sharing! I'm sure it will come in handy for me one day if i need to convert RS232 to WiFi.zenit wrote:Hi guys,
I finally got it to work:
hope its the right forum, just wanted to share....
Using a nodemcue as borad this réal easy to use.gizmocuz wrote:i dont find it easy at all... (okey.. compared to mysensors.org)... but i am not giving up yet
deennoo wrote:Using a nodemcue as borad this réal easy to use.gizmocuz wrote:i dont find it easy at all... (okey.. compared to mysensors.org)... but i am not giving up yet
Https://www.google.fr/search?q=nodemcu+ ... e&ie=UTF-8Derik wrote:deennoo wrote:Using a nodemcue as borad this réal easy to use.gizmocuz wrote:i dont find it easy at all... (okey.. compared to mysensors.org)... but i am not giving up yet
Ex plane please....
Hard to get ..... for a dombo like me...
