OpenZwave & Fibaro Motion Sensor
mschut
Domoticz version: V3.5613
Re: OpenZwave & Fibaro Motion Sensor
Post by mschut »
pvm wrote:Did you:
-wait for 24 hours
Not yet....
-make big changes in light and temperature (it can be set to only report big changes,)
Definitely in light (day and night).
-check the device settings?
Did check all the settings. Didn't change the standard settings, and can't find a setting which would cause it not to work.
pvm
Domoticz version: 4.10538
Post by pvm »
Can you try changing report interval and required change in light level?
mschut
Post by mschut »
Fixed. Apparently the default setting for reporting temperature and light is 0, meaning, no updates to the controller.
nizaga
Post by nizaga »
hello, i have 3 fibaro motion sensors but temp and lux decive is only created for one of them. sensors are working fine but no related lux/temp devices.
any idea how this is happening? i have not changed default conf parameters.
thanks,
Glatzi
Post by Glatzi »
nizaga wrote:hello, i have 3 fibaro motion sensors but temp and lux decive is only created for one of them. sensors are working fine but no related lux/temp devices.
thanks,
Take a look in the "Groups & Nework" menu & check, if node 1 is in group 1 & 3 of the sensors.
If it is not the case you have to wake the sensor manually before adding node 1 to the mentioned group.
RPi3+UZB1,FIBARO FGMS001(9x),FIBARO FGD212,FIBARO FGRM222(6x),FIBARO FGSD002(1x),FIBARO FGWPE (3x),Neo CoolCam Power plug(5x),NodOn CRC-3-1 Remote(2x),Qubino ZMNHADx(1x),Qubino ZMNHDD1(2x),Z-Wave Weather Sensor(1x),Z-Wave ZME_WALLC-S,FIBARO System FGK10x
nizaga
Post by nizaga »
hi, yes, node 1 is in group 1 & 3 of the sensors, just verified. I just verified again the temp and lux.
I only have LUX in one of the nodes, the temp is available for the 3 nodes, so missing 2 lux :(
