LUA script for Sony Bravia TV
StefanPuntNL
Domoticz version: 2.3190
Post by StefanPuntNL »
Hi there,
I want to share with you my LUA scripts for turning on/off a Sony Bravia TV. I created and tested this with a KDL-50W815B model, but i'm sure this will work with lots of other network connected Sony Bravia models.
My solution consists of two scripts. The first one is a time script that updates the status in Domoticz when the TV was turned on or off via another remote. The second script is a device script that can actually turn the television on and off.
The scripts are made for Domoticz on the Raspberry Pi, but may also work on other Linux/Unix distros.
Prerequisites:
  • Create a virtual switch (On/Off) named "TV"
  • Create a user variable (integer) named "TVOnlyStatusUpdate", with value 0
  • Install etherwake (sudo apt-get install etherwake)
  • Enable remote start on your TV: [Settings] → [Network] → [Home Network Setup] → [Remote Start] → [On]
  • Enable pre-shared key on your TV: [Settings] → [Network] → [Home Network Setup] → [IP Control] → [Authentication] → [Normal and Pre-Shared Key]
  • Set pre-shared key on your TV: [Settings] → [Network] → [Home Network Setup] → [IP Control] → [Pre-Shared Key] → [sony]
  • Give your TV a static IP address, or make a DHCP reservation for a specific IP address in your router.
  • Determine the MAC address of your TV: [Settings] → [Network] → [Network Setup] → [View Network Status]
The virtual switch will, obviously, be used in the interface to control the device and see the status. The user variable is to determine whether the device has been switched on or off via the timed script. If that is the case, the device script doesn't have to actually switch on/off the device. In that case only the status in Domoticz has to be updated.
What you need to adjust in the scripts:
  • In script 2, set the MAC address of your TV. Update the following to match the MAC address: 'etherwake ab:12:34:56:cd:78'.
  • In both scripts set the url to match the IP address of your TV.
  • I used 'sony' as pre-shared key in this example, but you can define your own pre-shared key. When you do so, make sure to update this in both scripts. (headervalue = 'sony')
1: script_time_tvstatus.lua
function getPowerStatus()
  local url = 'http://10.101.0.50/sony/system'
  local headername = 'X-Auth-PSK'
  local headervalue = 'sony'
  local jsonbodygetstatus = '{\\"id\\":2,\\"method\\":\\"getPowerStatus\\",\\"version\\":\\"1.0\\",\\"params\\":[]}'
  local runcommand = 'curl -v -H \"Content-Type:application/json\" -H \"' .. headername .. ':' .. headervalue .. '\" -d \"' .. jsonbodygetstatus .. '\" ' .. url .. ''
  local h=io.popen(runcommand)
  local response=h:read("*a")
  h:close()
  if string.find(response, '{"status":"active"}') then
    return 'active'
  elseif string.find(response, '{"status":"standby"}') then
    return 'standby'
    return 'unkown'
ping_success=os.execute('ping -c1 10.101.0.50')
if (ping_success) then
   print('TV ping success')
   powerstatus=getPowerStatus()
   print('TV says it is ' .. powerstatus)
   if(powerstatus == 'active') then
      if(otherdevices['TV'] == 'Off') then
         print('TV active, but status is OFF, so update to ON.')
         commandArray['Variable:TVOnlyStatusUpdate'] = '1'
         commandArray['TV'] = 'On'
         print('TV active, status is ON, so do nothing.')
   elseif(powerstatus == 'standby') then
      if(otherdevices['TV'] == 'On') then
         print('TV standby, but status is ON, so update to OFF.')
         commandArray['TV'] = 'Off'
         print('TV standby, status is OFF, so do nothing.')
      print('TV in unknown power status, doing nothing...')
   print("TV ping fail")
      print('TV current status here is ON, so update status to OFF.')
      commandArray['TV']='Off'
      print('TV current status here is OFF, so do nothing.')
2: script_device_tv.lua
if(devicechanged['TV']) then
  jsonbodypoweroff = '{\\"id\\":2,\\"method\\":\\"setPowerStatus\\",\\"version\\":\\"1.0\\",\\"params\\":[{ \\"status\\" : false}]}'
  if (devicechanged['TV'] == 'On') then
    if(uservariables['TVOnlyStatusUpdate'] == 1) then
       print('TV status update received (ON), resetting user variable.')
       commandArray['Variable:TVOnlyStatusUpdate'] = '0'
       os.execute('etherwake ab:12:34:56:cd:78')
       print('TV got wake up call')
  if (devicechanged['TV'] == 'Off') then
       print('TV status update received (OFF), resetting user variable.')
       runcommand = 'curl -v -H \"Content-Type:application/json\" -H \"' .. headername .. ':' .. headervalue .. '\" -d \"' .. jsonbodypoweroff .. '\" ' .. url .. ''
       response = os.execute(runcommand)
       if response then
          print('TV goes sleepy sleep')
          print('TV not in the mood for sleepy sleep')
Please share your suggestions, tips or other thoughts ;-)
G3rard
Domoticz version: No
Re: LUA script for Sony Bravia TV
Post by G3rard »
Thanks for sharing :D This works great on my KDL-50W829B.
Do you know how to start Netflix using a script? I have found some commands on http://mendelonline.be/sony/sony.txt but don't know how to use the Netflix command.
Not using Domoticz anymore
StefanPuntNL
G3rard wrote:Thanks for sharing :D This works great on my KDL-50W829B.
Starting Netflix from Domoticz was/is my next objective. I haven't integrated it yet in Domoticz, but I did figure out how to achieve this through the API on the TV.
You can retrieve a list of possible commands from the TV by executing the getRemoteControllerInfo method of the API. You can do this by posting the following JSON to 'http://[your tv ip here]/sony/system' (same as in the on/off scripts). Don't forget send the X-Auth-PSK header.
{"id":20,"method":"getRemoteControllerInfo","version":"1.0","params":[]}
This will return a JSON with command names and values. The values can be used to control the TV. However these commands must be send to a SOAP (XML) endpoint with a different url: 'http://[your tv ip]/sony/IRCC' (for some models the URL is 'http://[your tv ip]/IRCC'). Again, don't forget the X-Auth-PSK header.
This is an example of a SOAP XML message that should start Netflix (at least on some models, be sure to check the getRemoteControllerInfo result):
<?xml version="1.0"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
  <s:Body>
    <u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1">
      <IRCCCode>AAAAAgAAABoAAAB8Aw==</IRCCCode>
    </u:X_SendIRCC>
  </s:Body>
</s:Envelope>
I'm still thinking about what the best way is to integrate this into Domoticz: as a on/off-switch that automatically turns to off after Netflix has started or as a scene. If you have any good ideas let me know.
Another idea would be to pause the TV when someone presses the doorbell.
As soon as I have a Netflix integrated I will post my solution with scripts to this thread.
G3rard
Post by G3rard »
I have checked the getRemoteControllerInfo (Netflix command is the same as above) and sent the SOAP XML message to the TV, but can't get it working. Which curl command are you using for sending the XML file?
I have used https://github.com/breunigs/bravia-auth-and-remote on my laptop to start Netflix and it worked for some time, but not anymore.
So it would be nice if your method is working.
StefanPuntNL
G3rard wrote:I have checked the getRemoteControllerInfo (Netflix command is the same as above) and sent the SOAP XML message to the TV, but can't get it working. Which curl command are you using for sending the XML file?
Nice Github repo! I see that the author of those scripts has implemented the auth mechanism. Nice! However, when using the pre-shared key you don't have to save that cookie. I will use the repo to create my own variant. When I got it working I will post it here. Probably Saturday or Sunday.
G3rard
Post by G3rard »
Nice, I have issues with the auth cookie (doesn't work okay on my NAS, did work on my Ubuntu laptop) so I am looking forward to your solution.
StefanPuntNL
I created the following bash script: remote.sh
  • Set the variables at the top of the file to match your own environment
  • Place file in scripts folder of Domoticz
  • Make it executable (chmod +x remote.sh)
  • Example of usage: ./remote.sh PowerOn
  • Possible commands depend on exact type of TV, but most commands are probably the same for each Bravia TV.
#!/bin/bash
#Uncomment the following lines by removing the hash sign when your variables are not stored in profile.d
SonyBraviaAuthHeader="X-Auth-PSK"
SonyBraviaPreSharedKey="sony"
SonyBraviaIP="192.168.0.100"
SonyBraviaMAC=ab:12:34:56:cd:78
set -e
cd $(dirname $0)
if [ "$1" = "" ]; then
  echo "Usage: $0 <COMMAND>"
  exit 1
fi
if [ "$1" = "PowerOn" ]; then
  wakeonlan $SonyBraviaMAC >/dev/null
  echo "PowerOn: ✓"
  exit 0
fi
declare -A commandmap
commandmap[PowerOff]="AAAAAQAAAAEAAAAvAw=="
commandmap[Input]="AAAAAQAAAAEAAAAlAw=="
commandmap[GGuide]="AAAAAQAAAAEAAAAOAw=="
commandmap[EPG]="AAAAAgAAAKQAAABbAw=="
commandmap[Favorites]="AAAAAgAAAHcAAAB2Aw=="
commandmap[Display]="AAAAAQAAAAEAAAA6Aw=="
commandmap[Home]="AAAAAQAAAAEAAABgAw=="
commandmap[Options]="AAAAAgAAAJcAAAA2Aw=="
commandmap[Return]="AAAAAgAAAJcAAAAjAw=="
commandmap[Up]="AAAAAQAAAAEAAAB0Aw=="
commandmap[Down]="AAAAAQAAAAEAAAB1Aw=="
commandmap[Right]="AAAAAQAAAAEAAAAzAw=="
commandmap[Left]="AAAAAQAAAAEAAAA0Aw=="
commandmap[Confirm]="AAAAAQAAAAEAAABlAw=="
commandmap[Red]="AAAAAgAAAJcAAAAlAw=="
commandmap[Green]="AAAAAgAAAJcAAAAmAw=="
commandmap[Yellow]="AAAAAgAAAJcAAAAnAw=="
commandmap[Blue]="AAAAAgAAAJcAAAAkAw=="
commandmap[Num1]="AAAAAQAAAAEAAAAAAw=="
commandmap[Num2]="AAAAAQAAAAEAAAABAw=="
commandmap[Num3]="AAAAAQAAAAEAAAACAw=="
commandmap[Num4]="AAAAAQAAAAEAAAADAw=="
commandmap[Num5]="AAAAAQAAAAEAAAAEAw=="
commandmap[Num6]="AAAAAQAAAAEAAAAFAw=="
commandmap[Num7]="AAAAAQAAAAEAAAAGAw=="
commandmap[Num8]="AAAAAQAAAAEAAAAHAw=="
commandmap[Num9]="AAAAAQAAAAEAAAAIAw=="
commandmap[Num0]="AAAAAQAAAAEAAAAJAw=="
commandmap[Num11]="AAAAAQAAAAEAAAAKAw=="
commandmap[Num12]="AAAAAQAAAAEAAAALAw=="
commandmap[VolumeUp]="AAAAAQAAAAEAAAASAw=="
commandmap[VolumeDown]="AAAAAQAAAAEAAAATAw=="
commandmap[Mute]="AAAAAQAAAAEAAAAUAw=="
commandmap[ChannelUp]="AAAAAQAAAAEAAAAQAw=="
commandmap[ChannelDown]="AAAAAQAAAAEAAAARAw=="
commandmap[SubTitle]="AAAAAgAAAJcAAAAoAw=="
commandmap[ClosedCaption]="AAAAAgAAAKQAAAAQAw=="
commandmap[Enter]="AAAAAQAAAAEAAAALAw=="
commandmap[DOT]="AAAAAgAAAJcAAAAdAw=="
commandmap[Analog]="AAAAAgAAAHcAAAANAw=="
commandmap[Teletext]="AAAAAQAAAAEAAAA/Aw=="
commandmap[Exit]="AAAAAQAAAAEAAABjAw=="
commandmap[Analog2]="AAAAAQAAAAEAAAA4Aw=="
commandmap[*AD]="AAAAAgAAABoAAAA7Aw=="
commandmap[Digital]="AAAAAgAAAJcAAAAyAw=="
commandmap[Analog?]="AAAAAgAAAJcAAAAuAw=="
commandmap[BS]="AAAAAgAAAJcAAAAsAw=="
commandmap[CS]="AAAAAgAAAJcAAAArAw=="
commandmap[BSCS]="AAAAAgAAAJcAAAAQAw=="
commandmap[Ddata]="AAAAAgAAAJcAAAAVAw=="
commandmap[PicOff]="AAAAAQAAAAEAAAA+Aw=="
commandmap[Tv_Radio]="AAAAAgAAABoAAABXAw=="
commandmap[Theater]="AAAAAgAAAHcAAABgAw=="
commandmap[SEN]="AAAAAgAAABoAAAB9Aw=="
commandmap[InternetWidgets]="AAAAAgAAABoAAAB6Aw=="
commandmap[InternetVideo]="AAAAAgAAABoAAAB5Aw=="
commandmap[Netflix]="AAAAAgAAABoAAAB8Aw=="
commandmap[SceneSelect]="AAAAAgAAABoAAAB4Aw=="
commandmap[Mode3D]="AAAAAgAAAHcAAABNAw=="
commandmap[iManual]="AAAAAgAAABoAAAB7Aw=="
commandmap[Audio]="AAAAAQAAAAEAAAAXAw=="
commandmap[Wide]="AAAAAgAAAKQAAAA9Aw=="
commandmap[Jump]="AAAAAQAAAAEAAAA7Aw=="
commandmap[PAP]="AAAAAgAAAKQAAAB3Aw=="
commandmap[MyEPG]="AAAAAgAAAHcAAABrAw=="
commandmap[ProgramDescription]="AAAAAgAAAJcAAAAWAw=="
commandmap[WriteChapter]="AAAAAgAAAHcAAABsAw=="
commandmap[TrackID]="AAAAAgAAABoAAAB+Aw=="
commandmap[TenKey]="AAAAAgAAAJcAAAAMAw=="
commandmap[AppliCast]="AAAAAgAAABoAAABvAw=="
commandmap[acTVila]="AAAAAgAAABoAAAByAw=="
commandmap[DeleteVideo]="AAAAAgAAAHcAAAAfAw=="
commandmap[PhotoFrame]="AAAAAgAAABoAAABVAw=="
commandmap[TvPause]="AAAAAgAAABoAAABnAw=="
commandmap[KeyPad]="AAAAAgAAABoAAAB1Aw=="
commandmap[Media]="AAAAAgAAAJcAAAA4Aw=="
commandmap[SyncMenu]="AAAAAgAAABoAAABYAw=="
commandmap[Forward]="AAAAAgAAAJcAAAAcAw=="
commandmap[Play]="AAAAAgAAAJcAAAAaAw=="
commandmap[Rewind]="AAAAAgAAAJcAAAAbAw=="
commandmap[Prev]="AAAAAgAAAJcAAAA8Aw=="
commandmap[Stop]="AAAAAgAAAJcAAAAYAw=="
commandmap[Next]="AAAAAgAAAJcAAAA9Aw=="
commandmap[Rec]="AAAAAgAAAJcAAAAgAw=="
commandmap[Pause]="AAAAAgAAAJcAAAAZAw=="
commandmap[Eject]="AAAAAgAAAJcAAABIAw=="
commandmap[FlashPlus]="AAAAAgAAAJcAAAB4Aw=="
commandmap[FlashMinus]="AAAAAgAAAJcAAAB5Aw=="
commandmap[TopMenu]="AAAAAgAAABoAAABgAw=="
commandmap[PopUpMenu]="AAAAAgAAABoAAABhAw=="
commandmap[RakurakuStart]="AAAAAgAAAHcAAABqAw=="
commandmap[OneTouchTimeRec]="AAAAAgAAABoAAABkAw=="
commandmap[OneTouchView]="AAAAAgAAABoAAABlAw=="
commandmap[OneTouchRec]="AAAAAgAAABoAAABiAw=="
commandmap[OneTouchStop]="AAAAAgAAABoAAABjAw=="
commandmap[DUX]="AAAAAgAAABoAAABzAw=="
commandmap[FootballMode]="AAAAAgAAABoAAAB2Aw=="
commandmap[Social]="AAAAAgAAABoAAAB0Aw=="
IRCC=${commandmap[$1]}
if [ "$IRCC" = "" ]; then
  echo "Unkown command $1"
  exit 1
fi
cmd="<?xml version=\"1.0\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><u:X_SendIRCC xmlns:u=\"urn:schemas-sony-com:service:IRCC:1\"><IRCCCode>$IRCC</IRCCCode></u:X_SendIRCC></s:Body></s:Envelope>"
auth="$SonyBraviaAuthHeader: $SonyBraviaPreSharedKey"
url=http://$SonyBraviaIP/sony/IRCC
code=$(curl -w "%{http_code}" --silent -d "$cmd" -H 'Content-Type: text/xml; charset=UTF-8' -H "$auth" $url -o /dev/null )
if [ "$code" = "200" ]; then
  echo "$1: ✓"
  echo "$1: Command failed (HTTP_CODE: $code, try running it in a console)"
  exit 1
fi
I also created a bash script to start Netflix named: start_netflix.sh. In this script I call the remote.sh script. This script can optionally be called with parameter PowerOn, so that it will first power on the TV before starting Netflix. Don't forget to make it executable: chmod +x start_netflix.sh
  • ./start_netflix.sh PowerOn
You can also use this as an example for creating remote control macro's (e.g. PowerOn > Home > Left > Left > Confirm).
#!/bin/bash
set -e
cd $(dirname $0)
remote() {
  ./remote.sh $1
# turn on when poweron parameter is used, pass this from lua script
  remote 'PowerOn'
  echo 'Waiting for TV to boot!'
  sleep 30
fi
remote 'Netflix'
exit 0
The last piece of scripting for Netflix is a LUA script that is triggered when the virtual switch 'Netflix' is turned on: script_device_netflix.lua
if (devicechanged['Netflix'] == 'On') then
  print('Starting Netflix')
  scriptPath = '/home/pi/domoticz/scripts/start_netflix.sh'
    cmd= scriptPath .. ' &'
    os.execute(cmd)
    cmd=scriptPath .. ' PowerOn &'
    os.execute(cmd)
  commandArray['Netflix'] = 'Off'
Last edited by StefanPuntNL on Monday 12 October 2015 23:20, edited 1 time in total.
G3rard
Post by G3rard »
Thanks for the scripts :D Will try this asap and let you know the results.
G3rard
Post by G3rard »
@StefanPuntNL, I get an 500 error code when starting ./start_netflix.sh.
Netflix: Command failed (HTTP_CODE: 500, try running it in a console)
I changed the settings in the remote.sh scripts and the scripts are executable. The command for Netflix has the right code. I also tried other commands with the remote.sh script, but get the same 500 error.
Do you have an idea how to fix this? I have googled but found no relevant information.
StefanPuntNL
G3rard wrote:@StefanPuntNL, I get an 500 error code when starting ./start_netflix.sh.
Oooops, I made a copy/paste mistake while placing the variables at the top of the remote.sh script. That is because I don't use these variables myself.
Change: SonyBraviaHeader="X-Auth-PSK"
To: SonyBraviaAuthHeader="X-Auth-PSK"
I edited the script in my previous post.
G3rard
Post by G3rard »
Thanks, that did the trick :mrgreen: . Now it works!
I also placed the MAC address between quotes.
SonyBraviaMAC="ab:12:34:56:cd:78"
galadril
Domoticz version: latest
Post by galadril »
Thanks!!
Works great with my tv
assenzuid
Post by assenzuid »
Unfortunately it won't work with a Sony KDL xxHX850 series
2015-11-27 22:19:00.373 LUA: TV ping success
2015-11-27 22:19:03.479 LUA: TV says it is unkown
2015-11-27 22:19:03.479 LUA: TV in unknown power status, doing nothing...
If I browse to http://xxx.xxx.xxx.xxx/KDL-xxHX850/system the result is 'unknow', also to http://xxx.xxx.xxx.xxx result in 'unknow'
toming
Post by toming »
I'm trying to get this running, but i keep receiving an error 500 despite all settings on the TV and in the script-parameters are correct...
PowerOff: Command failed (HTTP_CODE: 500, try running it in a console)
I tried to run the command manually from the terminal (without --silent) to the tv, and the command gets send out, but looks like the TV doesn't accept it. i'm running a newer AndroidTV (KDL-55X8509C). Does anyone have a clue or experience this too?
wmnl
Post by wmnl »
toming wrote:Hi,
Same goes for me with a 49X8305C.
$ ./start_netflix.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   804  100   513  100   291  41417  23494 --:--:-- --:--:-- --:--:-- 42750
The first script posted in this thread, the on/off script with preshared key, works.
When I try to manually send data (eg the Netflix command) with the Chrome rest api app, first a 403 is returned. After authentication (which succeeds as described) I also receive a 500. Details:
<s:Envelope
  <s:Body>
    <s:Fault>
      <faultcode>s:Client</faultcode>
      <faultstring>UPnPError</faultstring>
      <detail>
        <UPnPError xmlns="urn:schemas-upnp-org:control-1-0">
          <errorCode>401</errorCode>
          <errorDescription>Invalid Action</errorDescription>
        </UPnPError>
      </detail>
    </s:Fault>
  </s:Body>
</s:Envelope>
Anyone have a clue :)?
noddy119
Domoticz version: 3.5837
Post by noddy119 »
I also have a 2015 Sony Android TV.
After a bit of trial and error the following bash script <thanks to StefanPuntNL :D > seems to work, at least from the shell
My TV does not respond to wake on lan or etherwake but by querying the TV using info from this post: http://www.openremote.org/display/forum ... TP+control I found a command called 'WakeUp' which turns on the tv.
N.b. I have not tested all the commands in the code below as yet, but have the output from my TV to compare.
Its actually simpler than before:
    Enable Simple IP Control on your TV: [Settings] → [Network] → [Home Network Setup] → [IP Control] → [Simple IP Control] → [On]
    Set pre-shared key on your TV: [Settings] → [Network] → [Home Network Setup] → [IP Control] → [Pre-Shared Key] → [yourkey]
#!/bin/bash
#Change these to your variables
SonyBraviaPreSharedKey="yourpresharedkey"
SonyBraviaIP="yourTVipaddress"
set -e
cd $(dirname $0)
  exit 1
fi
commandmap[PowerOn]="AAAAAQAAAAEAAAAuAw=="
  echo "Unknown command $1"
  exit 1
fi
code=$(curl -sw "%{http_code}" --silent -XPOST http://$SonyBraviaIP/sony/IRCC -H "X-Auth-PSK:$SonyBraviaPreSharedKey" -d "<?xml version=\"1.0\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><u:X_SendIRCC xmlns:u=\"urn:schemas-sony-com:service:IRCC:1\"><IRCCCode>"$IRCC"</IRCCCode></u:X_SendIRCC></s:Body></s:Envelope>" -H 'Content-Type: text/xml; charset=UTF-8' -H 'SOAPACTION: "urn:schemas-sony-com:service:IRCC:1#X_SendIRCC"' -o /dev/null)
#Debug should return 200
#echo "Returned code = " $code
  echo "Command $1 transmitted"
  echo "$1: Command failed (HTTP_CODE: $code)"
  exit 1
fi
WorldO
Post by WorldO »
When I try to manually send data (eg the Netflix command) with the Chrome rest api app, first a 403 is returned. After authentication (which succeeds as described) I also receive a 500. Details:????
O
piotr
Post by piotr »
The script logs an error every few seconds:
Error: EventSystem: Lua script /home/pi/domoticz/scripts/lua/script_device_tv.lua did not return a commandArray
Any ideas ?
G3rard
Post by G3rard »
Does your script start with
and end with?
piotr
Post by piotr »
G3rard wrote:Does your script start with
and end with?
I copied script_time_tvstatus.lua from the first post in this topic
