Domoticz - air conditioning control
smq
Do you have any idea how to control home airconditioning?
I'm thinking about to use IR protocol to communicate with original wall controllers. Anybody proceed with that way?
And how to get it working with domoticz?
Greetings
Greetings
ThinkPad
Re: Domoticz - air conditioning control
Please tell us some more, your post is quite minimalistic.
What brand + type airconditioning are we talking about? How does the remote/wall control look like? What did you already found out yourself?
- RoadXY
- Domoticz version: 2.2331
Have been researching this myself lately and found this device:
http://www.remotec.com.hk/zaspx/product ... =45&main=f
Technical info here:
http://www.vesternet.com/downloads/dl/f ... manual.pdf
markk
I use a Broadlink RM pro to control my air con remotely. I haven't integrated this with Domoticz yet but I understand this is possible. See this thread here: http://www.domoticz.com/forum/viewtopic ... adlink+rm2
Philos31
If you have Daikin Aircon, there is already a script for Domoticz and Daikin integration.
RasPi2/KaKu/HUE/Xiaomi/Z-Wave/Nuki/Daikin 3,5kw Ururu Sarara/IR Heating Panels all working together with domoticz
Toni
Some while ago I implemented an Arduino library to control a number of different air conditioners through infrared: https://github.com/ToniA/arduino-heatpumpir
This could be connected into the network using the Arduino Ethernet/WiFi shield. I'm also looking at integrating this with MySensors. I think it would also be nice if Domoticz would have a widget for controlling heatpumps (temperature, operating mode, fan speed, power state).
Toni
Today I was able to send infrared commands from Domoticz to my old Panasonic CKP air conditioning / heat pump for the first time, wirelessly through the MySensors network. The interface is a bit clumsy, but it works
And yes, quite a few air conditioner models are supported.
https://github.com/ToniA/arduino-heatpu ... ensorsNode
oliviers
- Domoticz version: Stable
Paris area
Raspberry Pi 4 - RFXComm 433 - IrTrans - Zwave
- Arkie
Hi, i'm using the remotec zxt-120 with my zibro ac unit, this works, i can switch it on and off and i can switch on the heat function.
I use dummy switches for this control. I don't use the controle of the degrees, i only use maximum cooling, of heating with 24 c degrees
Synology DS412+
Philips Hue
Fibaro
Logitech Hamony elite
Foscam 9804 ip cam
RFXtrx433E USB 433.92MHz
ZXT 120 eu AC controller
Heatmiser NEO stat thermostats and Hub
Philips Hue
Fibaro
Foscam 9804 ip cam
schmin
Did you get this sorted brother??? I had similar problems with my ac unit.
Sateetje
I'm following the project of ToniA on Github closely. He wants to control an air conditioner with Domoticz with the use of the MySensors network/nodes.
I want the same functionallity in Domoticz. I think more people wants to control their air conditioner from Domoticz.
Here are the threads:
viewtopic.php?f=34&t=8751
tracker.php?p=2&t=650
Please see attached file also
- Overview
- Drawing1.jpg (79.15 KiB) Viewed 22632 times
Toni
Here's a teaser of what I have done with the air conditioning control so far. A bit clumsy, but this actually works now, together with a Lua event script which calculates the right IR command to be sent to the MySensors device. Now, if we just could combine those three dummy devices into one...
- Capture.PNG (78.67 KiB) Viewed 22602 times
Toni
OK, more fun with MySensors and the 'HeatpumpIRController' sketch: https://github.com/mysensors/Arduino/tr ... Controller
The demo now works with old & faithful Panasonic E12-CKP series air conditioner / heatpump. I have the three devices shown on the previous post, MySensors gateway connected to Domoticz (I'm using the serial gateway on Raspberry Pi), and the HeatpumpIRController MySensors node, with the IR led close to the IR eye of the Panasonic.
When the HeatpumpIRController MySensors node is connected, these new devices will be created automatically:
The final piece of the puzzle is a Lua event script which ties together the dummy 'Heatpump' devices and the MySensors nodes. I have attached it into this post. To use it, you need to set the global variables within the Lua script. The HeatpumpIRController.ino should work as such, for as long as your heatpump / air conditioner is on the list of supported modes.
- IR send
- IR data
- script_device_hp.lua.txt
- The event script. Remove the '.txt' extension, it's there just because the forum does not allow *.lua files.
- (2.2 KiB) Downloaded 582 times
alfred_j_kwak
- Domoticz version: 2.3530
This is maybe stupid question, but why do you have that hex convert function? Isn't it possible just use: string.format("%X", temperature) ?
Toni
The only reason is that I'm a bit new to Lua, and that was the first Google search result for converting a decimal number to hex when I asked for it
I'll change it later today.
alfred_j_kwak
I don't know much either. Just start to wonder and do some google.
Do you happend to know what device is Onnline heat pump? I know that Onninen has rebranded it, but what it originally was.
Toni
No idea, but take a look at lampopumput.info (for other folks, this is in Finnish). It might be a rebranded Midea heatpump. Anyway, if I get access to a remote control, or somebody with a remote controller has an Arduino + IR receiver, the reverse-engineering should be quite simple.
alfred_j_kwak
Thank you. Yes I was planning to do some arduino-ir testing.
Toni
Here's a new version of the Lua event script. I also modified the fan speed selector (in Domoticz V2.4192) to not show the 'Off' state, and to include 'Auto'.
- (1.85 KiB) Downloaded 705 times
