I am working on a HVAC Thermostat sensor. I noticed the Setpoint Heat and Cool work fine, but it does not seem Domoticz currently support V_HVAC_FLOW_STATE and V_HVAC_FLOW_MODE types. To me it looks like it is something required in order to make a full HVAC Thermostat solution.
Here's what the log says (so I'm reporting it
2015-10-03 15:07:23.955 MySensors: Node: 9, Sketch Name: HVAC Thermostat
2015-10-03 15:07:23.963 MySensors: Node: 9, Sketch Version: 1.0
2015-10-03 15:07:23.979 (MySensors Gateway) Thermostat (Setpoint Heat)
2015-10-03 15:07:23.986 (MySensors Gateway) Thermostat (Setpoint Cool)
2015-10-03 15:07:23.994 Error: MySensors: Unhandled sensor (sub-type=21), please report with log!
2015-10-03 15:07:24.003 Error: MySensors: Unknown/Invalid sensor type (46)
2015-10-03 15:07:43.986 (MySensors Gateway) Temp (Thermostat Temp)
In fact, it would be cool if Domoticz also had a widget already for HVAC Thermostat, with temperature control, flow mode and state, current temperature (and humidity?) all in one widget, instead of individual widget for Set Points, etc.
