New Raspberry1-2B+ Images based on OpenWRT (Update 3.5877)
- Domoticz version: V4.10717
Re: New Raspberry Image based on OpenWRT (Update r2335)
New raspberry image available v2015-03-25, with domoticz r2335 and OpenZWave 1.3.112 - link please see first message.
Successfully tested on RPI B+ (1) with RFXtrx433E USB 433.92MHz Transceiver by RFXCom and Z-Wave Plus USB Stick ZME_UZB1 by Z-Wave.me
Repository updated for old image as well, use opkg update.
Ignore possible OpenZWave downgrade message due to github switch and new OpenZWave version numbering.
Re: New Raspberry Image based on OpenWRT (Update r2383)
Update to Domoticz v2.2383 (incl. python bindings) & OpenzWave V1.3.144 is avaible via packetmanager.
Re: New Raspberry Image based on OpenWRT (Update r2505)
Update to Domoticz v2.505 & OpenzWave V1.3.293 is avaible via packetmanager.
This is a cool project. Does it support the Raspbery Pi 2?
No, RPI 2 is not supported. There are no update plans since openwrt supports RPI 2 only on trunk version.wizzard72 wrote:This is a cool project. Does it support the Raspbery Pi 2?
I have build a basic openwrt image for the Raspberry Pi 2. Can you share how you created a package for domoticz and openzwave?
This is very easy: just look at openwrt wiki how to add feeds, then add my feed:wizzard72 wrote:I have build a basic openwrt image for the Raspberry Pi 2. Can you share how you created a package for domoticz and openzwave?
git clone git://git.code.sf.net/p/audiculapi/code audiculapi
It doesn't work. So I used:irimi wrote:This is very easy: just look at openwrt wiki how to add feeds, then add my feed:wizzard72 wrote:I have build a basic openwrt image for the Raspberry Pi 2. Can you share how you created a package for domoticz and openzwave?Code: Select all
src-git audiculapi http://git.code.sf.net/p/audiculapi/code
Building OpenZWave Version 1.3.-1
Linking Shared Library
arm-openwrt-linux-muslgnueabi-ld: unrecognized option '-Wl,-z,now'
arm-openwrt-linux-muslgnueabi-ld: use the --help option for usage information
Did you change the makefile or did you remove the patchfiles ?wizzard72 wrote: When I try to compile, it breaks on compiling openzwave. This is the error:Any idea?Code: Select all
Building OpenZWave Version 1.3.-1 Linking Shared Library arm-openwrt-linux-muslgnueabi-ld: unrecognized option '-Wl,-z,now' arm-openwrt-linux-muslgnueabi-ld: use the --help option for usage information
I'm expecting this:
openzwave-1.3.321
make ./package/feeds/audiculapi/openzwave/{clean,compile} V=s
Applying ./patches/011-build_fix.patch using plaintext:
patching file cpp/build/Makefile
Hunk #2 succeeded at 126 (offset 5 lines).
Hunk #3 succeeded at 138 (offset 5 lines).
Thanks for the reply!
I think I am one step further. I now get the following error:
The strange thing is that if I compile it from the builddir with a normal make, I don't get errors, but when I compile this with "make ./package/feeds/audiculapi/openzwave/{clean,compile} V=s" I got the error above.
I think it's looking in the wrong directory. But I don't know how I can check this.
Building tinystr.o
arm-openwrt-linux-muslgnueabi-g++: error: arm: No such file or directory
Re: New Raspberry Image based on OpenWRT (Update r2659)
Update to r2659 with openzwave v1.3.401 is available via okpg update.
Re: New Raspberry Image based on OpenWRT (Update r3191)
Update to r3191 with openzwave v1.3.488 is available via okpg update
Hi.
I'm trying to publish domoticz in OpenWRT main package repository. Here's may pull request https://github.com/openwrt/packages/pull/2883
The basis of the project I took yours project.
Any suggestions are welcome.
- Domoticz version: 2020.3
@irimi
Any issues running your img on my new RPi 3 B+ cards?
No luck with the RPi 3 B+. Booting freezes at the initial "color check" screen.
Of course ! Available image is only for older RPI, for recent RPI3 the image has to be rebuild with other settings.jensc wrote:No luck with the RPi 3 B+. Booting freezes at the initial "color check" screen.
I'll try this.
If that is possible, I'd like to try it, thanks.
Re: New Raspberry Image based on OpenWRT (Update r3.5412))
Update for RPI 2B/3 is available now. I only have tested Model 2B , this one works fine for me.
Re: New Raspberry1-3 Images based on OpenWRT (Update 3.5412)
@irimi
Nope, doesn't boot on Pi 3 B+. Freezes at the color screen with a little color screen square in the upper right corner. Tried three different cards.
Mmh, according to https://wiki.openwrt.org/toh/raspberry_ ... spberry_pi it seems RPi3 is still unsupported with "OpenWrt's Chaos Calmer" release
For RPI3 recent openwrt's trunk version is required and actually I'm not able to compile OpenZWave due to strange compiler errors on that trunk version, hence no domoticz package possible for RPI3 , too
