[MyDomoAtHome] Support thread
epierre
Re: [MyDomoAtHome] Support thread
Post by epierre »
@korniza for having struggled a lot with Vera, the best is to have the camera as an independent device directly in Imperihome (add a device -> MJPEG/h264/MPEG4 IP Camera) which is good.
also, having something in a "room" does not make it a switch, it is a DevCamera, and if it isn't working (blank image) you need to raise a support issue to Imperihome directly for what you show me is correct in term of gateway.
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
Justintime
Post by Justintime »
I have updated MyDomoatHome
But i got this message:
./update-mdah.sh: 4: [: -ne: unexpected operator
[....] Stopping plack server: MyDomoAtHomestart-stop-daemon: warning: failed to kill 17582: No such process
 failed!
After that i got no connection with Imperihome.
The gateway is running. I see the devices in domo_ip:3001/devices
Justintime
OK?! Something has changed with the Nginx setup?!?!? What do i have to do to get it working again?
epierre
Post by epierre »
Justintime wrote:I have updated MyDomoatHome
The message has nothing to do with it.
do a ps -ax and search the starman master if it is present
epierre
Post by epierre »
Justintime wrote:OK?! Something has changed with the Nginx setup?!?!? What do i have to do to get it working again?
if you had 5001 for redirection, just change it to 3001 (if you're on the 3001 port)
Justintime
Okay thanks that worked out. I had to do a complete reboot. Instead of restarting the services of Nginx and MyDomoAtHome.
Maybe it's better to change the wiki if something big has changed....every member can change the Wiki.
Bikey
Domoticz version: 2020.x
Post by Bikey »
Not all my switches appear in the ImperiHome App for iOS. I have 30 switches in the "Switches" tab, but I do have more then 50 (real switches, remote-buttons, and virtual) switches.
They are received by the App, because I can add them in a Dashboard page, so it seems to be because of the limitation on the number of switches in a single tab-page.
So the question is: why can't I see my rooms as pages in ImperiHome? Because if they are divided in rooms then I would not need to have 1 page "switches" with all my switches.
Also I have to empty tabs: "Utility" and "Volumio" which I would like to disappear.
Justintime
My energy meter is not visible anymore. Water is still there.
Doler
Post by Doler »
Justintime wrote:My energy meter is not visible anymore. Water is still there.
I confirm this: energy devices aren not visible anymore since latest Domoticz version (V2.3072) and/or MyDomoAtHome update. The interface (IP:3001/devices) lists the devices with value="unk" but are not visible (not found) in Imperihome.
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
epierre
Post by epierre »
that is what happens when the backend data is changed without telling others it has...
We now have a "General" which is "kWh" ...
try updating to the latest version and tell me if it is better this way.
Doler
Post by Doler »
epierre wrote: that is what happens when the backend data is changed without telling others it has...
I guessed it was something like that :cry:
I have updated and I see the devices with correct value in the interface but they don't appear in Imperihome, not in page view nor in list view.
Justintime
I can see general(icon) now, only with total kwh.
The current power I can't select.
zbelko
Post by zbelko »
Hi All,
I have everything up and running on my Raspberry Pi (Domoticz, MyDomoAtHome, Nginx)
Everything works OK from LAN (Imperihome works just fine), everything seems ok from remote access:
- https://my_remote_ip/imperihome/devices shows my device list, no worries
BUT, when I try to setup Imperihome with my remote URL with login and password, I get "Invalid API response" error :(
Anyone got an idea why?
Thank you all for your help
Bikey
Post by Bikey »
That maybe has to do with the bug I ran into as well. The iOS App can't handle self signed certificates. It is raised with Imperihome, so hopefully they solve it in the next release.
zbelko
Post by zbelko »
Thanks Bikey
Thing is, I already tried to setup Imperihome (on iOS) without SSL, without authentication, and just port redirection, but I get the same problem: /devices is accessible from outside, but I still have the "Invalid API response" Error :(
Remote access is a pain!
epierre
Post by epierre »
@all I've made a docker image you can find here:
docker pull epierre/mydomoathome
I'll see how to change configuration for the config.yml
Last edited by epierre on Thursday 24 September 2015 14:13, edited 1 time in total.
DRuw
Post by DRuw »
I have some issues with getting my domoticz correctly in Imperihome..
for some reason, all items go to a folter called weather, also switches etc.
Any Idea how to fix this?
ntougait
Post by ntougait »
I had previous version of MyDomoAtHome working fine. Decided to update so i reinstalled following the wiki.
Now i cannot even start MyDomoAtHome :
pi@raspberrypi ~ $ sudo service MyDomoAtHome.sh start
[ ok ] Starting plack server: MyDomoAtHome.
I check if it's started by stopping it :
pi@raspberrypi ~ $ sudo service MyDomoAtHome.sh stop
[....] Stopping plack server: MyDomoAtHomestart-stop-daemon: warning: failed to kill 2889: No such process
failed!
pi@raspberrypi ~ $
Nope it's not started.
No Starman process anywhere.
Is there any log somewhere that can be checked ?
NAt
ntougait
Post by ntougait »
ntougait wrote:Hi,
failed!
pi@raspberrypi ~ $
NAt
Think i got it, was missing DateTime.pm.
Managed to find how to execute manually and get the output :
sudo /usr/bin/plackup -E production -s Starman --workers=4 -p 3001 -a /home/pi/domoticz/MyDomoAtHome/bin/app.pl --pid /tmp/mydomoathome.pid
And then installed libdatetime-perl :
sudo apt-get install libdatetime-perl
NAt
thorbj
Post by thorbj »
Hi, I'm trying to set up MyDomoAtHome on my Raspberry Pi running Domoticz.
After setup, when I try to access the devices list, I det a 502 Bad Gateway error. I notice that the MyDomoAtHome.sh service crashes immideately after I start it.
 sudo /usr/bin/plackup -E production -s Starman --workers=4 -p 5001 -a /home/pi/domoticz/MyDomoAtHome/bin/app.pl --pid /tmp/mydomoathome.pid
Pid_file "/tmp/mydomoathome.pid" already exists.  Overwriting!
2015/09/24-13:31:37 Starman::Server (type Net::Server::PreFork) starting! pid(18656)
Resolved [*]:5001 to [0.0.0.0]:5001, IPv4
Host [*] resolved to IPv6 address [::] but IO::Socket::INET6->new fails: Adressefamilien er ikke st%C3%B8ttet av protokollen at /usr/share/perl5/Net/Server/Proto.pm line 133.
Binding to TCP port 5001 on host 0.0.0.0 with IPv4
2015/09/24-13:31:37 Can't connect to TCP port 5001 on 0.0.0.0 [Adressen er allerede i bruk]
  at line 67 in file /usr/share/perl5/Net/Server/Proto/TCP.pm
2015/09/24-13:31:37 Received QUIT. Running a graceful shutdown
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 355.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 385.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 405.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 413.
2015/09/24-13:31:37 Worker processes cleaned up
2015/09/24-13:31:37 Server closing!
shutdown() on closed socket GEN1 at /usr/lib/perl/5.14/IO/Socket.pm line 294.
How can I fix this?
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
