Logitech Media Server
Chiel
Post by Chiel »
Hi, I've just started with Domoticz and right now I'm controlling my Milight's in the livingroom, just perfect!
I've got several RPi's with the Picoreplayer (squeezeplayer) running true the all house and I've created an event to try to stream a playlist to one off the RPi's.
for example: http://192.168.1.250:9000/status.html?p ... 2.168.1.59.
Does anyone knows How I can start a favoriet list that's stored in LSM wit a http commando?
Any help would be create!
Michiel
iceman187
Re: Logitech Media Server
Post by iceman187 »
Hi I use the following to start a playlist. You need to edit your ip address and mac address. Also change the name of your playlist under playlist
http://192.168.0.7:9000/status.html?p0= ... 0:00:00:00
Let me know if this works.
Chiel
Post by Chiel »
Hi Iceman, thanks for the quick reply! Works great, do you also now a way to play a favorite instead of a playlist?
Chiel
Post by Chiel »
Hi, this one works!
http://192.168.1.250:9000/status.txt?p0 ... 6:a5:03:d3
but, it puts all my favorites in a new playlist.. :?
Anyone knows how I can control and identify the favorite items??
Chiel
Post by Chiel »
I've got it!
Start the favorite that I want with this:
http://LMS-SERVER:9000/status.txt?p0=fa ... MAC-PLAYER
Stop playing and clear the current playlist with this:
http://LMS-SERVER:9000/status.txt?p0=pa ... MAC-PLAYER
thanks for the help!
iceman187
Post by iceman187 »
Glad you got it working. I shall make note of this for future reference. Thanks.
stuffer
Domoticz version: 3.6367
Post by stuffer »
Thanx,
Just what I needed (after lollipop upgrade the apps are not working anymore)
PLaying around gives me this value's:
http://LMSSERVER:9000/status.txt?p0=fav ... RES_PLAYER
Where id:1 is the second favorite (count from 0) and you can create a lot of new switches with your favorites.
I figured out that stopping the music is:
http://LMSSERVER:9000/status.txt?p0=sto ... RES_PLAYER
Thanx again!! :D
BTW I found this post:
http://tutoriels.domotique-store.fr/con ... -http.html
cyberclwn
Domoticz version: 2024.4
Post by cyberclwn »
Hey,
Do you control the players with Domoticz also ?
I can turn my players on/off with Domoticz, and have them all synced. And I use the web-interface of the LMS to select stuff to play.
Also i uploaded the icon for the switch, so you have a LMS-logo for it :)
Even have a script that changes the state of the switches in domoticz if i turn on a device with the use of the powerbutton on the device itself, or the webinterface.
It's really simple.
Did you make a scene to start play your favorite/playlist ?
Seems interesting to look into that also. Altho the webinterface of the LMS is doing good for me now.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
rron
Post by rron »
cyberclwn wrote:Hey,
It's really simple.
Can you explain it little more because I'm als interested in intergrating my lms in domoticz.
Thx
cyberclwn
Post by cyberclwn »
Hey,
I have a script called "script_device_squeeze.lua" which contains these lines, per player:
if (devicechanged['SqWoonkamer'] == 'On') then
        os.execute ('echo "Woonkamer power 1" | nc <LMS_IP> <LMS_PORT>')
        os.execute ('echo "Woonkamer play" | nc <LMS_IP> <LMS_PORT>')
if (devicechanged['SqWoonkamer'] == 'Off') then
        os.execute ('echo "Woonkamer power 0" | nc <LMS_IP> <LMS_PORT>')
Where "SqWoonkamer" is the virtual switch in domoticz, and "Woonkamer" is the name of the player in the LMS. Also the <LMS_IP> and <LMS_PORT> need to be replaced with the according IP and Port (port is probably 9090). The script send a power on and a play command, or an off command.
To detect the status of the players i use this script, which is run in the crontab, every 5 minutes:
#!/bin/bash
SB_SERVER=<LMS_IP>
SB_PORT=<LMS_PORT>
DOMO_SERVER="http://<domo_ip>"
DOMO_PORT="<domo_port>"
for SB_NAME in Woonkamer <LMS_player> <LMS_player>
do
SB_STATUS=`echo "$SB_NAME power ?" | nc -q 2 $SB_SERVER $SB_PORT | cut -d " " -f 3`
if [ $SB_STATUS == "%3F" ]
then
        SB_STATUS=0
fi
DOMO_STATUS_TXT=`curl -s "$DOMO_SERVER:$DOMO_PORT/json.htm?type=devices&filter=all&used=true&order=Name" | grep Sq$SB_NAME -A 20 | grep Status | cut -d '"' -f 4`
DOMO_STATUS_IDX=`curl -s "$DOMO_SERVER:$DOMO_PORT/json.htm?type=devices&filter=all&used=true&order=Name" | grep Sq$SB_NAME -A 20 | grep idx | cut -d '"' -f 4`
case $DOMO_STATUS_TXT in
        On)
                DOMO_STATUS=1
        Off)
                DOMO_STATUS=0
esac
if [ $SB_STATUS -ne $DOMO_STATUS ]
then
        case $SB_STATUS in
                0)
                        DOMO_MOD=`curl -s "$DOMO_SERVER:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$DOMO_STATUS_IDX&switchcmd=Off"`
                1)
                        DOMO_MOD=`curl -s "$DOMO_SERVER:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$DOMO_STATUS_IDX&switchcmd=On"`
        esac
fi
done
This way the script compares every 5 min the status of the players between LMS and DOMO, and adjusts DOMO accordingly.
At the moment i am trying a script, used in a scene, to start play a favorite. So if press the scene "Q-Music", the players start to play Q-music :)
It's working now, but need to test it a bit more
Eduard
Post by Eduard »
I'm building a Logitech Media Server plugin for Domoticz. I got it working with basic player controls. I'm planning to add timers in the future. I hope to get it ready in a couple off days so i can add it to a beta relaase of Domoticz...
rron
Post by rron »
Eduard wrote:I'm building a Logitech Media Server plugin for Domoticz. I got it working with basic player controls. I'm planning to add timers in the future. I hope to get it ready in a couple off days so i can add it to a beta relaase of Domoticz...
That is looking very promosing. I will try both sollutions.
Thx :D
cyberclwn
Post by cyberclwn »
Oh, sounds good indeed.
You know where to find me if you need some testing :)
Eduard
Post by Eduard »
cyberclwn wrote:Oh, sounds good indeed.
When it's 'test-ready' i will get in contact ;D thnx!
Chiel
Post by Chiel »
I'm also want to test! Sounds great
pvm
Domoticz version: 4.10538
Post by pvm »
Another interested user here... I only check the power on state now
rron
Post by rron »
Count me in :D
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
Count me in also
It's nice to be important, but it's more important to be nice
Scooter ;)
Eduard
Post by Eduard »
I expect it will be ready at the end of next week :D
stimpy
Post by stimpy »
thanks cyberclwn, will try the script later, just what I was looking for.
Eduard - i would be very interested in this too.
currently i have set up a few virtual switches to play specific favourites/albums, pause, power on/off (covered elsewhere in this thread). also I have set up BBC Radio switches so i have one-click access to radio (probably UK only).
Radio 1
http://IP:PORT/status?p0=playlist&p1=play&p2=iplayer://live?hls=http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/ak/bbc_radio_one.m3u8&radiovis=fm/ce1/c201/09880&player=MAC
Radio 2
http://IP:PORT/status?p0=playlist&p1=play&p2=iplayer://live?hls=http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/ak/bbc_radio_two.m3u8&radiovis=fm/ce1/c202/08880&player=MAC
Radio 4
http://IP:PORT/status?p0=playlist&p1=play&p2=iplayer://live?hls=http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/ak/bbc_radio_fourfm.m3u8&radiovis=fm/ce1/c204/09320&player=MAC
Radio 5
http://IP:PORT/status?p0=playlist&p1=play&p2=iplayer://live?hls=http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/ak/bbc_radio_five_live.m3u8&radiovis=dab/ce1/ce15/c225/0&player=MAC
