Siri / HomeKit support for Domoticz
Heisenberg
Re: Siri / HomeKit support for Domoticz
Post by Heisenberg »
Hi, I need some help. After running 'npm run start' all the devices loaded correctly but then I get these errors. How can I solve this?
 Accessory [Homebridge] Creating new AccessoryInfo for our HAP server +0ms
  Accessory [Homebridge] Creating new IdentifierCache +31ms
  EventedHTTPServer Server listening on port 51826 +229ms
[Domoticz] Initializing device with name Achterdeur...
[Domoticz] Loaded services for Achterdeur
/home/pi/homebridge/node_modules/HAP-NodeJS/lib/Accessory.js:159
      throw new Error("Cannot add a bridged Accessory with the same UUID as an
Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 4df14a6b-862e-43a3-9a65-cec791c7d4fd
    at Bridge.Accessory.addBridgedAccessory (/home/pi/homebridge/node_modules/HAP-NodeJS/lib/Accessory.js:159:13)
    at /home/pi/homebridge/app.js:145:26
    at Request._callback (/home/pi/homebridge/platforms/Domoticz.js:129:5)
    at Request.self.callback (/home/pi/homebridge/node_modules/request/request.js:373:22)
    at Request.emit (events.js:110:17)
    at Request.<anonymous> (/home/pi/homebridge/node_modules/request/request.js:1318:14)
    at Request.emit (events.js:129:20)
    at IncomingMessage.<anonymous> (/home/pi/homebridge/node_modules/request/request.js:1266:12)
    at IncomingMessage.emit (events.js:129:20)
    at _stream_readable.js:908:16
EDIT: after applying this fix it worked: https://github.com/nfarina/homebridge/b ... omoticz.js
Last edited by Heisenberg on Tuesday 15 September 2015 23:45, edited 1 time in total.
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
MJanssen
Post by MJanssen »
I cannot manage to boot on startup. Tried both ways described. With PM2 i can get it running manually, with the big advantage that i can close the ssh session. But when i reboot my raspberry, it's not auto starting.
When i do de ps x command after reboot, PM2 is not running. Who can help me?
shoulder
Domoticz version: V2
Post by shoulder »
Read this thread a hundred of times.. still I'm stuck.
Can anyone please help?
Loading 1 platforms...
[Domoticz] Initializing Domoticz platform...
[Domoticz] Fetching Domoticz lights and switches...
Loading 0 accessories...
[Domoticz] Initializing platform accessory 'Golvlampa'...
[Domoticz] Loaded services for Golvlampa
[Domoticz] Initializing platform accessory 'Jordglob'...
[Domoticz] Loaded services for Jordglob
[Domoticz] Initializing platform accessory 'Marantz'...
[Domoticz] Loaded services for Marantz
  Accessory [Homebridge] Creating new IdentifierCache +27ms
  EventedHTTPServer Server listening on port 51826 +100ms
/home/pi/homebridge/node_modules/mdns/lib/advertisement.js:56
  dns_sd.DNSServiceRegister(self.serviceRef, flags, ifaceIdx, name,
Error: dns service error: unknown
    at Error (native)
    at new Advertisement (/home/pi/homebridge/node_modules/mdns/lib/advertisement.js:56:10)
    at Object.create [as createAdvertisement] (/home/pi/homebridge/node_modules/mdns/lib/advertisement.js:64:10)
    at Advertiser.startAdvertising (/home/pi/homebridge/node_modules/HAP-NodeJS/lib/Advertiser.js:43:30)
    at Bridge.Accessory._onListening (/home/pi/homebridge/node_modules/HAP-NodeJS/lib/Accessory.js:352:20)
    at HAPServer.emit (events.js:104:17)
    at HAPServer._onListening (/home/pi/homebridge/node_modules/HAP-NodeJS/lib/HAPServer.js:153:8)
    at EventedHTTPServer.emit (events.js:104:17)
    at EventedHTTPServer.<anonymous> (/home/pi/homebridge/node_modules/HAP-NodeJS/lib/util/eventedhttp.js:62:10)
    at Server.emit (events.js:104:17)
ivom74
Post by ivom74 »
shoulder wrote:Read this thread a hundred of times.. still I'm stuck.
    at Error (native)
I got the same problem here. Everything worked fine but now I got this error. I updated Domotica 3013, could that be a problem?
I think deleting settings will solve the problem but I really like to know how this is happened?
shoulder
Post by shoulder »
I've reinstalled everything and followed the wiki, but got the same error.
Which settings do you mean?
ivom74
Post by ivom74 »
The settings you made with the app on your smartphone (Insteon+, Eve).
On Iphone go to settings-> Privacy and then Insteon+. Here is a button to reset the settings.
shoulder
Post by shoulder »
Never got it working with domoticz, but previously with z way (razberry). Giving it a second try!
And deleting the settings. Thanks!
shoulder
Post by shoulder »
No! After clean install of domoticz image and following the wiki exactly. This is what I get:
Starting HomeBridge server...
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[Domoticz] Initializing device with name Golvlampa...
Cannot find secret key, creating One...
/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:56
    at Error (native)
    at new Advertisement (/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:56:10)
    at Object.create [as createAdvertisement] (/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:64:10)
    at Object.startAdvertising (/home/pi/homebridge/lib/HAP-NodeJS/Advertiser.js:7:28)
    at Object.publishAccessory (/home/pi/homebridge/lib/HAP-NodeJS/Accessory.js:10:29)
    at createHAPServer (/home/pi/homebridge/app.js:167:15)
    at /home/pi/homebridge/app.js:92:17
    at Request._callback (/home/pi/homebridge/platforms/Domoticz.js:91:6)
npm ERR! Linux 4.1.6-v7+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start"
npm ERR! node v0.12.1
npm ERR! npm  v2.5.1
npm ERR! code ELIFECYCLE
npm ERR! [email protected] start: `node app.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script 'node app.js'.
npm ERR! This is most likely a problem with the homebridge package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR!     node app.js
npm ERR! You can get their info via:
npm ERR!     npm owner ls homebridge
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR!     /home/pi/homebridge/npm-debug.log
King1987
Post by King1987 »
Hi Guys,
does anyone have installed this on a Synology? Homebridge is installed, but Nodejs is not working. (yes, on version 0.10 but we need 0.12) When we want to install 0.12 you need g++ but I can only find an old version (4.3 and you need 4.8 or higher) in ipkg.
Does anyone have a nice solution?
Thanks :mrgreen:
G3rard
Domoticz version: No
Post by G3rard »
King1987 wrote:Hi Guys,
Thanks :mrgreen:
I did try it but couldn't get it working. It was some while ago so don't know anymore what didn't work.
However Nodejs 0.12 is part of the Synology packages. You could try that. Please share your results.
Not using Domoticz anymore
dannybloe
Post by dannybloe »
Thanks :mrgreen:
It should be possible to somehow use the mdns libs on synology. I also gave up on Syno for now. But I also cannot get it to work on my RPi B+. First I can't get node 0.12.x installed (4.0.0 works) and second installing homebridge still give me the middle finger as well... Still trying to compile for the zillionth time as I write this..... :roll:
ipkg list | grep avahi
avahi - 0.6.30-1 - A system for multicast DNS service discovery, an implementation of Zeroconf.
so there's something for Syno.
charlysquare
Post by charlysquare »
I have installed the last version of homebridge with domoticz 2563.
Here is my config.json :
  GNU nano 2.2.6                File: config.json                              Modified
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "031-45-154"
    "description": "devices",
    "platforms": [
            "platform": "Domoticz",
            "name": "Domoticz",
            "server": "127.0.0.1",
            "port": "8080",
            "roomid": 9,
            "loadscenes": 1
    "accessories": [
And the error I'm encountering :
> [email protected] start /home/pi/homebridge
> DEBUG=* node app.js || true
_____________________________________________________________________
IMPORTANT: Homebridge is in the middle of some big changes.
           Read more about it here:
           https://github.com/nfarina/homebridge/wiki/Migration-Guide
[Domoticz] There was a problem connecting to Domoticz.
pi@raspberrypi ~/homebridge $
I don't know where to start.. Any idea ?
Heisenberg
This is odd. I have been able to connect to Homebridge with Eve. Everything works ok. But when I try to connect a second iPhone to Homebridge via Eve it does nothing. Any help?
Edit: I solved this by removing EVE and installing Insteon+. By adding 'Guest user' in Insteon+ I now can use my iPhone and iPad to control via Siri. Wife is happy :)
Last edited by Heisenberg on Friday 18 September 2015 15:56, edited 3 times in total.
Raspberry Pi Type B
RFXCOMtrx433e
Heisenberg
charlysquare wrote:Hi,
    "bridge": {
        "port": 51826,
        "pin": "031-45-154"
    "platforms": [
            "name": "Domoticz",
            "port": "8080",
            "roomid": 9,
            "loadscenes": 1
    "accessories": [
Looks like a connection issue with Domoticz. Maybe changing the server address 127.0.0.0 to your Domoticz ip address?
Were you able to add Homebridge with Eve or Insteon+?
Raspberry Pi Type B
RFXCOMtrx433e
charlysquare
Nope, changing to Domoticz IP 192.168.0.175 is not working.
Under Insteon+ nothing detecting, anyway homebridge is not even starting, I go back directly to the command prompt.
G3rard
Post by G3rard »
charlysquare wrote:Nope, changing to Domoticz IP 192.168.0.175 is not working.
My config.json part for Domoticz looks like this:
 "platforms": [
            "name": "Domoticz",
            "server": "192.168.1.102",
            "port": "8084",
         "roomid": "11"
I have a older version without the possibility to enable/disable scenes.
Difference is that roomid is between quotes. Maybe you can try that (and also for loadscenes if still not working)?
charlysquare
not better
Heisenberg
charlysquare wrote:not better
Try updating Domoticz.js. Then sudo reboot and see if it helps:
Raspberry Pi Type B
RFXCOMtrx433e
tcviper
Post by tcviper »
I tried installing this now a few times, but when i do i keep hitting this error on RPI2:
pi@raspberrypi ~/node.js $ node -v
node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by node)
node: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.16' not found (required by node)
This right after doing:
mkdir node.js
cd node.js
wget http://node-arm.herokuapp.com/node_latest_armhf.deb
sudo dpkg -i node_latest_armhf.deb
Anyone any idea on this?
R0cc0
Post by R0cc0 »
tcviper wrote:I tried installing this now a few times, but when i do i keep hitting this error on RPI2:
mkdir node.js
cd node.js
I have the exact same issue, Also on Rpi2.
I'm using Domoticz 2.3013. Any ideas?
