Script to get JPEG snapshot from RTSP-stream (ffmpeg)
- Domoticz version: 2020.2
Re: [Bash] Script to get JPEG snapshot from RTSP-stream (ffm
I use the script on my Raspberry and it's working. The only thing is when I execute the script from the CLI the *.jpg will we stored under the "Pi" account.
If I do it from Domoticz, with a virtual switch, it will be stored under the user root.
How can I change this. (Sorry, new to linux)
Another question: how can I email this *.jpg to my email address within Domoticz
I had a IP cam which I could add to a switch and in Domoticz the jpg will be send automagicly. But now I use this script and I love to have the picture in my email box.
Like i said you can change the path where the image will be stored. Store at some place like /home/pi/doorbellcam.
And to get it delivered to your mail: you have to find out yourself. I drop the image on Dropbox and get a link to it, through a Pushover message. See the scripts i posted earlier in this topic.
But it can also be dumped onto a FTP-server, like 'mvveelen' has posted.
I have edited the script to send the snapshot. It seems to work, but only my e-mail server links the attachment as spam.
When I find the root cause I'll post it in this topic
#!/bin/sh
IP="[IP address]" # IP address Camera
#Ping IP-address of camera to see if it's online, otherwise we don't have to grab a snapshot
if ping -c 1 $IP > /dev/null ; then
#Grab snapshot from RTSP-stream
/usr/bin/ffmpeg -rtsp_transport tcp -i 'rtsp://'$IP'/user=admin&password=&channel=1&stream=0.sdp' -f image2 -vframes 1 -pix_fmt yuvj420p /home/pi/doorbell/snapshot.jpeg
fi
sudo curl --url "smtp://[IP address of SMTP server]:25" --mail-from "[email protected]" --mail-rcpt "[email protected]" --upload-file "/home/pi/doorbell/snapshot.jpeg"
Nice, please post your result here. You'll get it working, just spend some time on it
The "curl" wasn't able to send the *.jpeg which have something to do with "Mime" settings.
I have installed "ssmtp" on the Pi to get the job done. I've used this setup:
https://rpi.tnet.com/project/faqs/smtp
I used my gmail credentials just like the setup in the url.
In the script I added the following line:
So the whole script is:
Thanks goes to Thinkpad for pushing me in the right direction.
mpack -s "Doorbell" /home/pi/doorbell/snapshot.jpeg [email protected] [email protected]
#!/bin/sh
IP="[ip address]" # IP address Camera
fi
Always nice to see the variations that people have on different scripts. Good to hear you got it working.
Maybe this can also be useful: http://domoticz.com/forum/viewtopic.php ... 451#p50451 so you won't get spammed with a lot of mails when someone is pressing your doorbell very often.
I updated my NAS to DSM 5.2 yesterday (still had 5.1 running) and today i noticed i didn't get a snapshot.
When i ran the script by hand, i got the dreaded 'rtsp://192.168.4.20/user=admin&password=&channel=1&stream=1.sdp: Input/output error'. The 'MediaServer' package i was using (/volume1/@appstore/MediaServer/bin/ffmpeg) was also upgraded it seemed. It was back on v1.0 of ffmpeg it said.
I uninstalled it and installed the 'Audio Station' package, and now it works back again It says it is version 2.02 of ffmpeg.
volume1/@appstore/AudioStation/bin/ffmpeg
Migrated Domoticz to a Ubuntu VM on ESXi, not running on my NAS anymore (which results in the HDD's of the NAS spinning down )
I changed the doorbell notification script, it now sends me a pushnotification (Pushover) with only text. The image is send through mail to my Gmail address (sent by myself).
I also changed from 'ffmpeg' to 'avconv' as it seems ffmpeg has become deprecated as of Ubuntu 14.04
To be able to send mail from the system through Gmail, i used this tutorial: http://www.renedohmen.nl/blog/2014/12/s ... on-ubuntu/
Backup of page if website ever goes down:
#!/bin/sh
today=`/bin/date '+%d-%m-%Y__%H-%M-%S'`; #Used to generate filename
datesubject=`/bin/date '+%d-%m-%Y om %T'`; #Used to generate timestamp in mailbody
IP="192.168.4.20" # IP address Camera
/usr/bin/avconv -rtsp_transport tcp -i 'rtsp://'$IP'/user=admin&password=&channel=1&stream=0.sdp' -f image2 -vframes 1 -pix_fmt yuvj420p /home/domoticz/deurbelsnapshots/$today.jpeg
#Send pushnotification with URL to snapshot
sh /home/domoticz/domoticz/scripts/bash/deurbel/pushover.sh -u USERTOKEN -a APPLICATIONTOKEN -q "Deurbel galerij" -m "Er is aangebeld op de galerij. Zie bijlage in Gmail voor foto."
echo "Er is op" $datesubject "aangebeld, zie de bijlage voor de foto." | mail -s "Deurbelfoto" -r "YOUR NAME<[email protected]>" -aFrom:[email protected] -A /home/domoticz/deurbelsnapshots/$today.jpeg [email protected]
#Delete previous taken snapshots older than 7 days
find /home/domoticz/deurbelsnapshots/ -name '*.jpeg' -mtime +7 -delete
sh /home/domoticz/domoticz/scripts/bash/deurbel/pushover.sh -u USERTOKEN -a APPLICATIONTOKEN -q "Deurbel galerij" -m "Net aangebeld, plaatje niet beschikbaar omdat cam offline is"
fi
- Spoiler: show
I have also a camera with only rtsp stream ( srcicam sp008) and i am newbie .
I use a Rpi 2 with domoticz
So i have some questions :
In which directory i have to save this script ?
How run it after each reboot ?
With this script is it possible to add camera in domoticz as a camera full compatible domoticz ? if yes what will be the parameter, Ip, port, url image,... to configure it?
Thanks in advance for your help
Just put the script in a folder like /home/pi/ and call it doorbell.sh or so. You link the script to a switch that is activated when someone presses your doorbell.
The script will work outside Domoticz, you cannot get your cam working in Domoticz. If you want that: buy a different camera that is supported.
Thank for your quick and clear answer.
It is the bad news no compatibility to view it in domoticz.
Re: [Bash] Script to get JPEG snapshot from RTSP-stream (ffmpeg)
I bought an Escam QD300 Wifi and want to use it to send a snapshot when someone presses the doorbel. I noticed that on some pages in the webgui for this cam a current snapshot appeared. So I used Fiddler to see what happens when I go to that page.
I discovered that the webgui uses a special command to retrieve the snapshot:
http://1.2.3.4/web/cgi-bin/hi3510/param.cgi?cmd=snap
The output of this command is a string in this format:
var path="/tmpfs/snap_tmpfs/20160227/IMG001/IMG_chn0_TIMER_MNG_20160227114416_008.jpg"
If you create the following URL you can get the picture in maximum resolution:
http://1.2.3.4/tmpfs/snap_tmpfs/2016022 ... 16_008.jpg
I'm interested in the fact if the snapshot option is also available in other cams. Like I said, I used fiddler to discover this.
Also, this URL does not need any username and password So it's a security issue as well...
I created a quick and dirty python script that I can execute when the doorbell is pressed. Here is the script for others to use. Quick and very dirty.
#!/usr/bin/python
import smtplib
import sys, json, urllib, urllib2
from cookielib import CookieJar
import base64
sender = '[email protected]'
receivers = ['[email protected]']
cj = CookieJar()
opener = urllib2.build_opener(urllib2.HTTPCookieProcessor(cj))
response = opener.open("http://1.2.3.4/web/cgi-bin/hi3510/param.cgi?cmd=snap")
content = response.read()
imgpath=content.split("=")[1]
imgPath = imgpath[1:-3]
imgUrl="http://1.2.3.4" + imgPath
#print imgUrl
imgData = urllib2.urlopen(imgUrl).read()
#output = open("/home/pi/test.jpg",'wb')
#output.write(imgData)
#output.close()
encodedcontent = base64.b64encode(imgData)
#Compose mail
marker = "AUNIQUEMARKER"
body ="""
Er is aangebeld.
# Define the main headers.
part1 = """From: Cam <[email protected]>
To: User Name <[email protected]>
Subject: Sending Attachement
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary=%s
--%s
""" % (marker, marker)
# Define the message action
part2 = """Content-Type: text/plain
Content-Transfer-Encoding:8bit
%s
--%s
""" % (body,marker)
# Define the attachment section
part3 = """Content-Type: multipart/mixed; name=\"%s\"
Content-Transfer-Encoding:base64
Content-Disposition: attachment; filename=%s
%s
--%s--
""" %("snapshot.jpg", "snapshot.jpg", encodedcontent, marker)
message = part1 + part2 + part3
try:
smtpObj = smtplib.SMTP('smtp.yourprovider.something')
smtpObj.sendmail(sender, reciever, message)
print "Successfully sent email"
except Exception:
print "Error: unable to send email"
Raspberry 3
Aeon Labs Z-Wave Stick Series 2 - RFLink USB Gateway
Z-Wave switches
433 MHz Temperature + Humidity sensors
Philips Hue Lights
Mi-Light WiFi Bridge + RGBW Controllers
Z-Wave switches
Philips Hue Lights
Re: [Bash] Script to get JPEG snapshot from RTSP (EScam QD50
Hi matthijs,matthijs wrote:It is working. I have almost the same code and copied your previous taken snapshots part. I also make a copy of the last snapshot and named it snapshot.jpg so I can use it to send a notification to Telegram (It is workaround I think, but I couldn't get it working otherwise). The only problem I have is my front door. We have a gallery with other houses so I can't put my camera there (for now).
Slightly offtopic but the Xiaomi had another problem. Newer firmware versions of the Xiaomi ants camera are lacking a rtsp stream, because it is protected with a username and password which Xiaomi doesn't reveal. so I had to downgrade the camera to get the stream working. I indeed used that website for the correct stream and it is working.
I have bought a Xiaomi Ants camera. Could you share your script how you got it setup up with this camera and Telegram?
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
Heisenberg wrote:
Hi matthijs,
#!/bin/sh
export DATETIME=`date +%Y%m%d%H%M%S`
ffmpeg -i rtsp://CAMERAIP/ch0_0.h264 -vframes 1 -r 1 -s 1920x1080 /home/pi/domoticz/www/snapshots/$DATETIME.jpg
cp /home/pi/domoticz/www/snapshots/$DATETIME.jpg /home/pi/domoticz/www/snapshots/snapshot.jpg
curl -s -X POST "https://api.telegram.org/BOTNAME/sendPhoto" -F chat_id=ID -F photo="@/home/pi/domoticz/www/snapshots/snapshot.jpg"
- Domoticz version: 3.4834
Hi matthijs,
I use also a Xiaomi Ants camera with the hack software (https://github.com/fritz-smh/yi-hack)
I am able to generate a snapshot of the rtsp stream with ffmpeg on my raspberry but how did you configure the camera in domoticz? I am not able to see the snapshot...
Thanks in advance
elpacito
Thanks in advance
elpacito
elpacito wrote:Hi matthijs,
Thanks in advance
elpacito
You could try this script below with xiaomi hack software:
1. Make sure you have avconv installed and a Telegram Bot
2. save the script in your script folder as doorbell.sh
3. assign doorbell.sh to your doorbell button in Domoticz (e.g. script:///home/pi/domoticz/scripts/doorbell.sh)
4. push the doorbell button to receive snapshot
#!/bin/sh
avconv -i rtsp://root:[email protected]:554/ch0_0.h264 -vframes 1 -r 1 -s 1920x1080 /home/pi/domoticz/www/snapshots/$DATETIME.jpg
curl -s -X POST "https://api.telegram.org/bot123456789:ABCDEFGHIJKLMNOPetc/sendPhoto" -F chat_id=12345678 -F photo="@/home/pi/domoticz/www/snapshots/snapshot.jpg"
find /home/pi/domoticz/www/snapshots/ -name '*.jpg' -mtime +7 -delete
Last edited by Heisenberg on Wednesday 22 June 2016 11:04, edited 1 time in total.
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
Thanks for your answer
The snapshot is working, I create a bot and it is working fine!!! Thanks a lot!
- Domoticz version: 3.5877
i try that on a escam qd 500, it's work. the ONVIF port is 8899.
http://www.openipcam.com/forum/index.ph ... 37#msg5125
i find this snapshot uri:
http://xxx.xxx.xxx.xxx/webcapture.jpg?c ... &channel=1
hope it's help
hope it's help
- Domoticz version: V4.9700
How can i execute that code on the openipcam forum? :/
I have a Escam QD300 but your url doesnt work for mine.
- Target OS: -
Please excuse the bumping of an old thread but I'm hoping someone may be able to assist.
I've got a Sricam sp009a camera that I can get a good feed displaying on VLC (on a PC) using rtsp://[IPaddress]:554/onvif1 and also surprisingly works on rtsp://[IPaddress]/onvif1 (without the explicit 554 port). However, when I try to save an image on the Raspberry Pi using ffmpeg or avconv using the examples in the scripts here I'm constantly getting "invalid data found when processing input".
Any suggestions on troubleshooting?
