HOME COMFORT modules (or SMART HOME / IDK) ECR-100
sebitop
Post by sebitop »
Hi guys
does someone managed to have the ECR-100 module working with domoticz ?
here is the link
http://www.home-confort.net/fr/content/ ... -chauffage
I tried different signals but i don't know if i'm doing it well.
thank you in advance for your help
Last edited by sebitop on Monday 28 September 2015 23:32, edited 2 times in total.
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
ThinkPad
Re: home confortl / smart home/ ECR-100
Post by ThinkPad »
Looks exactly the same as: http://www.klikaanklikuit.nl/shop/nl/in ... -acm-1000/
Use type 'AC', use random code and when unit is in paring mode, click 'Test' button in Domoticz.
Let me know if it works
sebitop
Post by sebitop »
it looks but it's not exactly the same, mine as a green led and seems to refuse to work with AC
I will try again this evening and keep you posted, could be usefull to know.
Stuntteam
Post by Stuntteam »
ThinkPad wrote:Looks exactly the same as: http://www.klikaanklikuit.nl/shop/nl/in ... -acm-1000/
I doubt it is the same.
The RFLink Gateway supports the Home Confort Smart Home products (among others the TEL-010 remote control) and the protocol is totally different.
sebitop
Post by sebitop »
i tried by it dosen't work ...
sebitop
Post by sebitop »
I've been in contact with the RFXCOM team to implement this protocol on the RFXCOM module.
I just tested it with RFXMGR and it works perfectly i'm able to control these new modules
so now just nee to be implemented in Domoticz.
I posted a modification request in the tracker.
et me know if you need any help to test it.
cheers
sebastien
sebitop
Re: HOME COMFORT modules (or SMART HOME / IDK) ECR-100
Post by sebitop »
more info on HOME COMFORT modules : http://www.home-confort.net
they are exactly the same than chacon but cheaper (got one for 10€)
deennoo
Post by deennoo »
Need this to !
http://domo-attitude.fr
sebitop
Post by sebitop »
here the request in the tracker
http://www.domoticz.com/forum/tracker.php?p=2&t=615
the protocol is already available in the last RFXCOM firmware but need to be avilable on Domoticz;
slybreiz
Post by slybreiz »
Hello
I have several ecr-100 Module
I can not operate with a domotickz and rxfcom433E Version 248.
help thank you
b_weijenberg
Post by b_weijenberg »
Did you try with RFXmngr?
I suppose HomeConfort is not yet implemented in Domoticz, see http://www.domoticz.com/forum/tracker.php?p=2&t=615
RFX-433, RFX-433EMC, RFX-868
slybreiz
Post by slybreiz »
Hello
I just tested RFXmngr.
The selection I HC tab.
and selection of telecommandeTEL-010 (the remote control supplied with the ECR-100 module is the TEL-010 model)
I try a aperage but nothing happens.
I was therefore unable to operate the ECR-module 100 ave key RFXcom433E ....
b_weijenberg
Use an RFXtrx433E with firmware version 248.
Connect RFXmngr and enable only the HomeConfort protocol,
Transmit a command using the TEL-010 remote.
Check the codes received and transmit a command with RFXmngr using the same codes as received from the TEL-010.
slybreiz
Post by slybreiz »
It's ok
Home Confort command
Packettype = Home Confort
subtype = TEL-010
Sequence nbr = 6
ID = 1010C decimal:65804
House Code = A
Unit Code = 1
Command = On
Signal level = 0 -120dBi
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 6
response = ACK, data correct transmitted
subtype = TEL-010
Sequence nbr = 7
House Code = A
Unit Code = 1
Command = Off
Sequence nbr = 7
Merci Thank's :p
forumfab
Post by forumfab »
Ok, HOME COMFORT modules are know seen under RFXmgr, but not by DOMOTICZ
Best regards
gizmocuz
Post by gizmocuz »
Implemented in #3524, hope it works well
slybreiz
Post by slybreiz »
Nice job it's ok For me .
gizmocuz
Post by gizmocuz »
Great! thanks for the feedback
sebitop
Post by sebitop »
bakc from business trip I will try it soon and post a feedback
thank you gizmo !!
S.
forumfab
Post by forumfab »
gizmocuz wrote:Implemented in #3524, hope it works well
Hi gizmocuz,
Imposible to check "home confort" box in hardware set mode !
The system refuse this choice !
it's the same think with usb rfxcom 433 and usb rfxcom 433 E
Do you have an idea ?
Bests regards
