HOME COMFORT modules (or SMART HOME / IDK) ECR-100
sebitop
Hi guys
does someone managed to have the ECR-100 module working with domoticz ?
here is the link
http://www.home-confort.net/fr/content/ ... -chauffage
I tried different signals but i don't know if i'm doing it well.
thank you in advance for your help
here is the link
Last edited by sebitop on Monday 28 September 2015 23:32, edited 2 times in total.
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
ThinkPad
Re: home confortl / smart home/ ECR-100
Looks exactly the same as: http://www.klikaanklikuit.nl/shop/nl/in ... -acm-1000/
Use type 'AC', use random code and when unit is in paring mode, click 'Test' button in Domoticz.
Let me know if it works
sebitop
it looks but it's not exactly the same, mine as a green led and seems to refuse to work with AC
I will try again this evening and keep you posted, could be usefull to know.
- Stuntteam
I doubt it is the same.ThinkPad wrote:Looks exactly the same as: http://www.klikaanklikuit.nl/shop/nl/in ... -acm-1000/
The RFLink Gateway supports the Home Confort Smart Home products (among others the TEL-010 remote control) and the protocol is totally different.
sebitop
i tried by it dosen't work ...
sebitop
I've been in contact with the RFXCOM team to implement this protocol on the RFXCOM module.
I just tested it with RFXMGR and it works perfectly i'm able to control these new modules
so now just nee to be implemented in Domoticz.
I posted a modification request in the tracker.
et me know if you need any help to test it.
cheers
sebastien
cheers
sebastien
sebitop
Re: HOME COMFORT modules (or SMART HOME / IDK) ECR-100
more info on HOME COMFORT modules : http://www.home-confort.net
they are exactly the same than chacon but cheaper (got one for 10€)
deennoo
Need this to !
http://domo-attitude.fr
sebitop
here the request in the tracker
http://www.domoticz.com/forum/tracker.php?p=2&t=615
the protocol is already available in the last RFXCOM firmware but need to be avilable on Domoticz;
slybreiz
Hello
I have several ecr-100 Module
I can not operate with a domotickz and rxfcom433E Version 248.
help thank you
help thank you
b_weijenberg
- Target OS: -
Did you try with RFXmngr?
I suppose HomeConfort is not yet implemented in Domoticz, see http://www.domoticz.com/forum/tracker.php?p=2&t=615
RFX-433, RFX-433EMC, RFX-868
slybreiz
Hello
I just tested RFXmngr.
The selection I HC tab.
and selection of telecommandeTEL-010 (the remote control supplied with the ECR-100 module is the TEL-010 model)
I try a aperage but nothing happens.
I was therefore unable to operate the ECR-module 100 ave key RFXcom433E ....
b_weijenberg
- Target OS: -
Use an RFXtrx433E with firmware version 248.
Connect RFXmngr and enable only the HomeConfort protocol,
Transmit a command using the TEL-010 remote.
Check the codes received and transmit a command with RFXmngr using the same codes as received from the TEL-010.
slybreiz
It's ok
Home Confort command
Packettype = Home Confort
subtype = TEL-010
Sequence nbr = 6
ID = 1010C decimal:65804
House Code = A
Unit Code = 1
Command = On
Signal level = 0 -120dBi
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 6
response = ACK, data correct transmitted
subtype = TEL-010
Sequence nbr = 7
House Code = A
Unit Code = 1
Command = Off
Sequence nbr = 7
Merci Thank's :p
subtype = TEL-010
Sequence nbr = 6
House Code = A
Unit Code = 1
Command = On
Sequence nbr = 6
subtype = TEL-010
Sequence nbr = 7
House Code = A
Unit Code = 1
Command = Off
Sequence nbr = 7
Merci Thank's :p
forumfab
Ok, HOME COMFORT modules are know seen under RFXmgr, but not by DOMOTICZ
Best regards
Best regards
- gizmocuz
Implemented in #3524, hope it works well
slybreiz
Nice job it's ok For me .
- gizmocuz
Great! thanks for the feedback
sebitop
bakc from business trip I will try it soon and post a feedback
thank you gizmo !!
S.
thank you gizmo !!
S.
forumfab
Hi gizmocuz,gizmocuz wrote:Implemented in #3524, hope it works well
Imposible to check "home confort" box in hardware set mode !
The system refuse this choice !
it's the same think with usb rfxcom 433 and usb rfxcom 433 E
Do you have an idea ?
Bests regards
