While pairing (after entering the code) It suddently stopped.
This is the output of my raspberry:
> [email protected] start /home/pi/homebridge
> DEBUG=* node app.js || true
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Starting HomeBridge server...
_____________________________________________________________________
IMPORTANT: Homebridge is in the middle of some big changes.
Read more about it here:
https://github.com/nfarina/homebridge/wiki/Migration-Guide
Loading 1 platforms...
[Domoticz] Initializing Domoticz platform...
[Domoticz] Fetching Domoticz lights and switches...
Loading 0 accessories...
[Domoticz] Initializing platform accessory 'Eetkamer 1'...
[Domoticz] Loaded services for Eetkamer 1
[Domoticz] Initializing platform accessory 'Keuken 1'...
[Domoticz] Loaded services for Keuken 1
[Domoticz] Initializing platform accessory 'Woonkamer 1'...
[Domoticz] Loaded services for Woonkamer 1
[Domoticz] Initializing platform accessory 'Woonkamer 2'...
[Domoticz] Loaded services for Woonkamer 2
[Domoticz] Initializing platform accessory 'Woonkamer 3'...
[Domoticz] Loaded services for Woonkamer 3
Accessory [Homebridge] Creating new AccessoryInfo for our HAP server +0ms
Accessory [Homebridge] Creating new IdentifierCache +133ms
EventedHTTPServer Server listening on port 51826 +565ms
EventedHTTPServer [192.168.0.7] New connection from client +39s
EventedHTTPServer [192.168.0.7] HTTP server listening on port 54826 +19ms
EventedHTTPServer [192.168.0.7] HTTP request: /identify +136ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /identify +7ms
Accessory [Homebridge] Identification request +32ms
Accessory [Homebridge] Identification request ignored; no listeners to 'identify' event +4ms
HAPServer [CC:22:3D:E3:CE:30] Identification success +9ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +63ms
EventedHTTPServer [192.168.0.7] HTTP request: /pair-setup +6s
HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /pair-setup +9ms
HAPServer [CC:22:3D:E3:CE:30] Pair step 1/5 +35ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +594ms
EventedHTTPServer [192.168.0.7] HTTP request: /pair-setup +11s
HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /pair-setup +5ms
HAPServer [CC:22:3D:E3:CE:30] Pair step 2/5 +18ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +468ms
EventedHTTPServer [192.168.0.7] HTTP request: /pair-setup +182ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /pair-setup +7ms
HAPServer [CC:22:3D:E3:CE:30] Pair step 3/5 +26ms
HAPServer [CC:22:3D:E3:CE:30] Pair step 4/5 +227ms
HAPServer [CC:22:3D:E3:CE:30] Pair step 5/5 +27ms
Accessory [Homebridge] Paired with client DFDE0C91-8341-4EFC-9108-A8CE14356731 +61ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +122ms
EventedHTTPServer [192.168.0.7] Client connection closed +273ms
EventedHTTPServer [192.168.0.7] New connection from client +88ms
EventedHTTPServer [192.168.0.7] HTTP server listening on port 54827 +17ms
EventedHTTPServer [192.168.0.7] HTTP connection was closed +60ms
EventedHTTPServer [192.168.0.7] HTTP server was closed +10ms
EventedHTTPServer [192.168.0.7] HTTP request: /pair-verify +54ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify +9ms
HAPServer [CC:22:3D:E3:CE:30] Pair verify step 1/2 +24ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +186ms
EventedHTTPServer [192.168.0.7] HTTP request: /pair-verify +219ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify +5ms
HAPServer [CC:22:3D:E3:CE:30] Pair verify step 2/2 +20ms
HAPServer [CC:22:3D:E3:CE:30] Client DFDE0C91-8341-4EFC-9108-A8CE14356731 verification complete +44ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +27ms
EventedHTTPServer [192.168.0.7] New connection from client +54ms
EventedHTTPServer [192.168.0.7] HTTP server listening on port 54826 +9ms
EventedHTTPServer [192.168.0.7] Client connection error: This socket has been ended by the other party +22ms
EventedHTTPServer [192.168.0.7] Client connection closed +6ms
EventedHTTPServer [192.168.0.7] HTTP connection was closed +21ms
EventedHTTPServer [192.168.0.7] HTTP server was closed +8ms
EventedHTTPServer [192.168.0.7] HTTP request: /pair-verify +22ms
HAPServer [CC:22:3D:E3:CE:30] Pair verify step 1/2 +11ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +114ms
EventedHTTPServer [192.168.0.7] HTTP request: /pair-verify +29ms
HAPServer [CC:22:3D:E3:CE:30] Pair verify step 2/2 +10ms
HAPServer [CC:22:3D:E3:CE:30] Client DFDE0C91-8341-4EFC-9108-A8CE14356731 verification complete +49ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +20ms
EventedHTTPServer [192.168.0.7] HTTP request: /accessories +49ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: GET /accessories +5ms
EventedHTTPServer [192.168.0.7] HTTP Repsonse is finished +75ms
, after reboot I had an empty list. Will give it another try in the coming weeks.
