Script delay
daveinhull
- Domoticz version: V2.2657
Script delay
HI,
Just a quick question (I hope).
I have a LUA script which detects a LightwaveRF mood switch button and turns on a light. It takes between 2 to 3 seconds for this to happen when the button is pressed.
Is this the expected duration to process a simple script, or should it be quicker?
Dave
Dave
Domoticz running on Windows 10 x64 Shuttle PC
RFComm, 9wall dimmers, 4dual sockets, 3x3way relays, 1x1way relay, 4PIRs, 2magnetic switches, 1radiator valve, WiFi link, coiler switch and controller, compatible security system, & lots of patience
daveinhull
Re: Script delay
Yes of course
Thoughts?
Dave
function getdifference(device)
t1 = (os.time())
s = otherdevices_lastupdate[device]
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
return os.difftime (t1, t2)
c=next(devicechanged)
v=tostring(devicechanged[c])
print '+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++'
print ('Mood => Trigger device -> '..c..' with data "'..v..'"')
if(c == 'Main Bedroom Mood') then
if(v == 'Group Mood 1') then
difference = getdifference('Main Bedroom Bedhead 1')
if (tostring(otherdevices['Main Bedroom Bedhead 1'])=='Off') then
commandArray['Main Bedroom Bedhead 1'] = 'Set Level 10'
elseif (tostring(otherdevices['Main Bedroom Bedhead 1'])=='Set Level') and difference < 5 then
commandArray['Main Bedroom Bedhead 1'] = 'Set Level 100'
elseif difference > 5 then
commandArray['Main Bedroom Bedhead 1'] = 'Off'
elseif(v == 'Group Mood 2') then
difference = getdifference('Main Bedroom Bedhead 2')
if (tostring(otherdevices['Main Bedroom Bedhead 2'])=='Off') then
commandArray['Main Bedroom Bedhead 2'] = 'Set Level 10'
elseif (tostring(otherdevices['Main Bedroom Bedhead 2'])=='Set Level') and difference < 5 then
commandArray['Main Bedroom Bedhead 2'] = 'Set Level 100'
commandArray['Main Bedroom Bedhead 2'] = 'Off'
elseif(v == 'Group Mood 3') then
difference = getdifference('Main Bedroom Ceiling')
if (tostring(otherdevices['Main Bedroom Ceiling'])=='Off') then
commandArray['Main Bedroom Ceiling'] = 'Set Level 10'
elseif (tostring(otherdevices['Main Bedroom Ceiling'])=='Set Level') and difference < 5 then
commandArray['Main Bedroom Ceiling'] = 'Set Level 100'
commandArray['Main Bedroom Ceiling'] = 'Off'
elseif(v == 'Group Mood 4') then
elseif(v == 'Group Mood 5') then
elseif(v == 'Group Off') then
print('Unknown value'..v)
print '-----------------------------------------------------------'
return commandArrayThanks
Dave
- gizmocuz
Re: Script delay
i cant see a problem / delay in the script, if you press one button, do you directly see a log line that it is received?
daveinhull
Re: Script delay
Not always, sometimes it appears immediately and other times it can take a few seconds.
daveinhull
Re: Script delay
Any thoughts anyone?
daveinhull
Re: Script delay
HI,
I've just checked with RFXmngr and the switch signals are received almost immediately, but in Domoticz they can take 5 or 6 seconds to appear in the log (although I appreciate that there may well be a time delay in updating the log).
Irrespective of the log, it does take around 2 second for the Domoticz to detect the switch signal in a LUA script and issue the light on signal - can any say if this is the expected time?
Any help would be appreciated, even if it is just to say that the delay is expected.
Dave
Dave
- gizmocuz
Re: Script delay
besides the lua/scripting, the display web gui updates every 10 seconds
simonrg
- Domoticz version: 3.8807
Re: Script delay
2 seconds would seem reasonable, 5 to 6 would seem a bit long, do you have other scripts?daveinhull wrote:HI,
Dave
Calling this script script_device_asomething.lua - does this speed it up?
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
daveinhull
Re: Script delay
Thanks for the reply. There were no other 'legally named' scripts in the lua directory, but I've moved everything out and its still about 2 to 3 seconds to go through button press light on.
Not sure what you mean
I also disabled all the Blockly scripts, not many, but just making sure there was nothing else that could be doing things - still no change.
As I mentioned RFXmgnr sees the button press almost immediately, so I'm not sure why there is a 2 to 3 second delay.
Dave
but it was called script_device_DavesMood.lua, so I renamed it as suggested - no change, still around 2 to 3 seconds.Calling this script script_device_asomething.lua - does this speed it up?
Dave
ThinkPad
Re: Script delay
I see you are running Domoticz on Windows.
Maybe Windows adds to much overhead, which causes Domoticz to work slower?
Try running Domoticz in a linux virtual machine or on a Raspberry Pi, see if it works faster there (more bare metal OS == less overhead).
daveinhull
Re: Script delay
Hi ThinkPad,
Yes that is were my thoughts were heading to also, but....
I did a little more testing and found that the log shows that when the switch signal is received the script is run and the light-on signal sent all within, a decent, 1/2 second.
So the delay must be in Domoticz detecting the switch signal. However...
So conclusion so far is that Domoticz is not seeing the switch signal as fast as RFXmgnr is seeing it. One difference of course is that Domoticz is running as a service whereas RFXmgnr is not, but I wouldn't expect that to cause such a delay, or would it? What are the factors involved in a signal being received by the RFXcom driver and Domoticz being notified?
Thoughts?
Dave
- RFXmgnr (on the same windows machine) detects the signal almost immediately - so can't really be the Windows PC.
- Also the Windows PC is a Shuttle(XS36V) with an Atom [email protected] process running nothing else but Domoticz (other than the usual Windows stuff of course), so again surprised that its the PC
Thoughts?
Dave
- StanHD
Re: Script delay
Hi, If it's any help, I am using Z-Wave PIRs and LightwaveRF Remote switches to operate LightwaveRF dimmer switches and relays. Domoticz running as a service on Windows 7 on a Celeron NUC.(Dedicated).
Usually I do not experience any noticeable delays. Rarely there is a 2-3 second delay, but I assume that is when my Evohome or 1-Wire is coincidentally updating at the same moment. Otherwise things are pretty much "instant".
I don't use scripts just Blockly, and some of the lighting ones are checking states of several other devices before execution.
Happy to "test" something with my setup if it helps?
Python:- Broadlink RM2, Sonos
daveinhull
Re: Script delay
Hi StanHD,
Thanks for the feedback and offer to help....
Do you have a LightwaveRF mood switch? If you do maybe you could put the following Lua script into the Domoticz/Scripts/Lua directory and then test it and see how long it takes.
You'd need to setup the mood switch as an on/off generic switch called Mood1 (or something, so long as the script name is the same) and have a light that you can turn on called Light1 (or again something that is the same in the script).
Probably best if the mood switch is not involved I anything else.
Then when you press button 1 (the one with one dot on it) it should turn the light on, any other button should turn it off.
If you could check the performance and also have a look in the Domoticz log to see the timings that would be great. The log will only show you the times when Domotiz see's the switch signal, so from actually pressing the button to the light coming on will have to be just visible timings. As I said in a previous post, the Domoticz log shows that it processes the signal with 1/2 a second, but the user experience is much slower. I guess without some expensive 433mhz monitoring equipment I can see what happens between the switch and the RFXcom receiver, although RFXmgnr does see it a lot quicker than Domoticz.
Many thanks in advance, at least I can see if it my Shuttle that is slowing things down.
Dave
if(c == 'Mood1') then
commandArray['Light1'] = 'On'
commandArray['Light1'] = 'Off'
return commandArrayThen when you press button 1 (the one with one dot on it) it should turn the light on, any other button should turn it off.
Dave
Re: Script delay
Hi there,
I see something similar, however I put it down to the 'slow-start' on the LED lights - I think this is supposedly to improve their life? What lights/housing are you using? I see 2-3 second delay with my GU10 Megaman downlights, with LightwaveRF dimmers, however the Hue lights called from the same Scene action on the Mood switch turn on visibly before the downlights (although there is obviously no lightwaverf action for turning the lights on here). My scripts do check a few things first, time of day, is it dark, brightness in the room (Z-wave motion sensors) etc and then act accordingly.
It does take probably 0.5 seconds or so for the lights turn on even when using their own physical switch. I have 10 mood switches around the house, downlights are always slightly slower than the Hue lights. Using an Ubuntu VM running on vSphere cluster.
UPDATE: I was just in the process of finishing off my iRule remote (iOS), this calls the JSON urls and the lights respond almost immediately (as fast as they do when using their physical switch). Using the Mood switch it is still the 2-3 seconds, usually the lower end, so potentially something with receiving/sending the commands with RFX (is there a 'sleep' or anything between commands?) or script processing.
Cheers,
Cheers,
- StanHD
Re: Script delay
Hi Dave,
I don't have a mood switch, but tonight I can try to test the script with a lwrf wireless switch (JSJS LW221). Would that be comparable?
Stan
Stan
daveinhull
Re: Script delay
Hi Stan,
Yes I guess it would, but you'd probably need to change the script to something like:
Although I'm not sure what the data would be with the switch, I'm assuming On/Off - I'll dig out a wireless switch and test it.
Many thanks
Dave
if(c == 'Switch') then
if(v == 'On') then
return commandArrayMany thanks
Dave
daveinhull
Re: Script delay
Hi Stan,
Did you manage to get chance to test the wireless switch with script? Any results?
Dave
Dave
- StanHD
Re: Script delay
Hi Dave,
Really sorry for the delay, got called away for work, then away for weekend.
Anyway, have tested using a LWRF remote control and also a wireless switch, both with a LWRF Dimmer and then a LWRF relay (on/off).
With the dimmer, the reaction was @ 0.5 - 1 second (max).
With the On/Off relay, the reaction was instant.
I think the dimmer reaction was dampened by the "soft start" effect that is built into it.
For background, I am running Version 2.2873 on a Celeron NUC. I have 30 Blockly Scripts and 129 Devices. No other Lua Scripts though.
Stan
Stan
daveinhull
Re: Script delay
Hi Stan,
Many thanks for testing this and absolutely need to apologies. So it sounds like something in my system is slowing things down, but where?
I need to break the system down into components and test each bit....that'll keep be occupied for a bit
I'm running version 2.2657, so will upgrade to the latest.
Thanks again
Dave
Thanks again
Dave
