LUA: Summer / Winter from timeofday or other...
jcjames13009
Domoticz version: 2023.2
Post by jcjames13009 »
Do we have possibility to retreive season (Winter, Summer, etc...) using Lua script.
something like timeofday['Nighttime'] but for season.
Couldn't find something in the forum and net
Thansk in advance
JC
jannl
Domoticz version: 2026.1.x
Re: LUA: Summer / Winter from timeofday or other...
Post by jannl »
Seasons are fixed, 4 dates every year, why not hard code that?
ThinkPad
Post by ThinkPad »
Hardcoding it is also done by people using other home automation systems: http://board.homeseer.com/showthread.php?t=155133
jcjames13009
That's what I was thinking about. But wanted to know before if there were an easier solution.
JC
jannl
Post by jannl »
Normally hardcoding is the easy way.
jcjames13009
That's what I did:
Solution 1: Use dummy switches one for each season
Capture Saisons 1.PNG (58.84 KiB) Viewed 8268 times
with the following lua script that set each switch to "ON" or "OFF" depending on season change date
-- script_device_SaisonSW.lua
-- Ce script permet de gérer des switches virtuel pour chaque saison:
--    Printemps / Eté / Automne / Hiver
-- Le changement d'état se fait à date fixe:
-- 	  21/03 pour le printemps
-- 	  21/06 pour l'été
-- 	  21/09 pour l'automne
-- 	  21/12 pour l'hiver
-- Le script est lancé une fois par jour lors du basculement du switch virtuel 'Jour' synchronisé sur l'heure de levé et couché du soleil
local SWPrintemps = 'Printemps'	-- Switch virtuel printemps
local SWEte = 'Eté'				-- Switch virtuel été
local SWAutomne = 'Automne'		-- Switch virtuel automne
local SWHiver = 'Hiver'			-- Switch virtuel hiver
-- Récuperation de l'heure
time = os.time()
mois = tonumber(os.date('%m', time))
jours = tonumber(os.date('%d', time))
if devicechanged['Jour'] == 'On' then
	if (mois == 03 and jours >= 21 and otherdevices[SWPrintemps] == 'Off') then
		-- print(' > C\'est le printemps')	-- Pour debug
		commandArray[SWPrintemps]='On'		-- C'est le printemps
		commandArray[SWEte]='Off'
		commandArray[SWAutomne]='Off'
		commandArray[SWHiver]='Off'
	if (mois == 06 and jours >= 21 and otherdevices[SWEte] == 'Off') then
		-- print(' > C\'est l\'été')		-- Pour debug
		commandArray[SWPrintemps]='Off'
		commandArray[SWEte]='On'			-- C'est l'été
	if (mois == 09 and jours >= 21 and otherdevices[SWAutomne] == 'Off') then
		-- print(' > C\'est l\'automne')	-- Pour debug
		commandArray[SWAutomne]='On'		-- C'est l'automne
	if (mois == 12 and jours >= 21 and otherdevices[SWHiver] == 'Off') then
		-- print(' > C\'est l\'hiver')		-- Pour debug
		commandArray[SWHiver]='On'			-- C'est l'hiver
Solution 2: Use user variable
Capture Saisons 2.PNG (4.64 KiB) Viewed 8268 times
with the following lua script that change the value of the variable at season change date
-- script_device_SaisonVU.lua
-- Ce script permet de gérer la valeur d'une variable utilisateur en fonction de la saision :
-- Le changement d'état se fait à date fixe :
-- 	  21/06 pour l'été
time = os.time()
	if mois == 03 and jours >= 21 then
		commandArray['Variable:Saison'] = 'Printemps'	-- C'est le printemps
	if mois == 06 and jours >= 21 then
		commandArray['Variable:Saison'] = 'Eté'			-- C'est l'été
	if mois == 09 and jours >= 21 then
		commandArray['Variable:Saison'] = 'Automne'		-- C'est l'automne
	if mois == 12 and jours >= 21 then
		commandArray['Variable:Saison'] = 'Hiver'		-- C'est l'hiver
Maybe it can help someone.
JC
ThinkPad
Post by ThinkPad »
Thanks for sharing. I don't understand French very well, but i can 'read' how the script works luckily :)
Where do you use this for?
Can user variable be used in Blockly?
IF Var_Season = Summer
DO SET light1 = On
Otherwise if it is just for showing text, you could also use a text sensor and update it with this:
commandArray['OpenURL'] = "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEXT"
Text sensor can be created by Setup > Hardware > Dummy hardware. Then at the dummy hardware click 'Create device', type 'text'
jcjames13009
Thanks for the tip about Text Sensor. I didn't knew about taht :D
Cannot answer you for user variables in Blocky. I never tested it before.
And sorry for the text in french. Google works fine for transaltaion (just tested it). But I'll try to do an english version :P
I'll use this feature to manage humidity extraction (VMC in French). To let the extractor running at max speed during the night in summer when outside temp is lower that inside one to cool down (a bit) the house. Stop extraction in winter during the night to don't waste eating.
I plan to use it also to manage pool water pump and cleaning robot time slots depending on season.
Will post corresponding scrips as well
JC
ThinkPad
Post by ThinkPad »
But how do you control the extractor? By the virtual switches method you described?
IF Fan = Off AND Summer = On
DO SET Fan = Off
Like that?
Derik
Post by Derik »
Someone has this working???
Found some scripts [ thanks to the maker?? ] only cannot get this working..?
-- script_device_season.lua
-- This script allows you to manage the value of a user variable depending on this season:
-- Spring Summer Fall Winter
-- The change of state is a fixed date:
-- Lente: 1 maart t/m 31 mei
-- Zomer: 1 juni t/m 31 augustus
-- Herfst: 1 september t/m 30 november
-- Winter: 1 december t/m 28 februari
-- The script is run once a day when the virtual switch 'Day' gets flipped (every sunset & sunrise)
time = os.time()
month = tonumber(os.date('%m', time))
day = tonumber(os.date('%d', time))
if devicechanged['IsDonker (virt)'] == 'On' then
   if month == 03 and day >= 21 then
      print('Het seizoen is veranderd, het is nu lente')
      commandArray['Variable:Seizoen'] = 'Lente'
      commandArray['OpenURL'] = "http://192.168.5.70:8080/json.htm?type=command&param=udevice&idx=253&nvalue=0&svalue=Lente"
   if month == 06 and day >= 21 then
      print('Het seizoen is veranderd, het is nu zomer')
      commandArray['Variable:Seizoen'] = 'Zomer'
      commandArray['OpenURL'] = "http://192.168.5.70:8080/json.htm?type=command&param=udevice&idx=253&nvalue=0&svalue=Zomer"
   if month == 09 and day >= 21 then
      print('Het seizoen is veranderd, het is nu herfst')
      commandArray['Variable:Seizoen'] = 'Herfst'
      commandArray['OpenURL'] = "http://192.168.5.70:8080/json.htm?type=command&param=udevice&idx=253&nvalue=0&svalue=Herfst"
   if month == 12 and day >= 21 then
      commandArray['Variable:Seizoen'] = 'Winter'
      commandArray['OpenURL'] = "http://191.168.5.70:8080/json.htm?type=command&param=udevice&idx=253&nvalue=0&svalue=Winter"
Please help
Or perhaps some one have 4 dummy switches that are flipping by the seasons...
jvdz
Domoticz version: 4.107
Post by jvdz »
Which part isn't working for you?
You do have a virtual device called "IsDonker (virt)" which is set to On each day?
You realize that the tests for month&day will be valid multiple days on and after the 21st of the specified month?
Jos
Derik
Post by Derik »
jvdz wrote:Which part isn't working for you?
Jos
The hole part is not working because i do not understand this script...
isdonker dos not say a thing for me.
What i am simple looking for is ...
4 switches that switching on or of whe a season is active
jvdz
Post by jvdz »
Understood, a learning experience for you. :)
So what are your exact switchnames to use for the 4 seasons?
Jos
Derik
Post by Derik »
All dummys:
Voorjaar : IDX:4194
Zomer : IDX: 4195
Herfst : IDX: 4196
Winter: IDX: 4197
jvdz
Post by jvdz »
Something like this should be close.
Save the below code as script_time_season.lua. It will run each minute and will only change the Switches to the appropriate setting when something changes.
Let me know when you have questions.
-- script_time_season.lua
-- Lente: 21 maart t/m 20 juni
-- Zomer: 21 juni t/m 20 september
-- Herfst: 21 september t/m 20 december
-- Winter: 21 december t/m 20 maart
-- The script is run once a time.day when the virtual switch 'time.day' gets flipped (every sunset & sunrise)
time = os.date("*t")
Seizoen = '????'
-- check once a minute for the season to change
if (time.month == 12 and time.day >= 21)
or (time.month == 1)
or (time.month == 2)
or (time.month == 3 and time.day < 21) then
	Seizoen = 'Winter'
elseif (time.month == 3)
or (time.month == 4)
or (time.month == 5)
or (time.month == 6 and time.day < 21) then
	Seizoen = 'Voorjaar'
elseif (time.month == 6)
or (time.month == 7)
or (time.month == 8)
or (time.month == 9 and time.day < 21) then
	Seizoen = 'Zomer'
elseif (time.month == 9)
or (time.month == 10)
or (time.month == 11)
or (time.month == 12 and time.day < 21) then
	Seizoen = 'Herfst'
	print('Something wrong in the season logic :)')
if Seizoen ~= '????' and otherdevices[Seizoen] ~= 'On' then
	-- reset all switches to Off
	print('Het seizoen is veranderd, het is nu '..Seizoen)
	commandArray['Winter'] = 'Off'
	commandArray['Voorjaar'] = 'Off'
	commandArray['Zomer'] = 'Off'
	commandArray['Herfst'] = 'Off'
	-- reset current season to On
	commandArray[Seizoen] = 'On'
Jos
Derik
Post by Derik »
Jos...
Thanks, if you are a girl i .......you...
6-02-14 13:56:54.166 (D.M.: CV Opentherm) Thermostat (Max_CH Water Setpoint)
2016-02-14 13:56:57.530 (D.M.: Slave 1) General/Percentage (Slave 1: Cpu)
2016-02-14 13:56:59.050 (D.M.: Zwave) Usage (Unknown)
2016-02-14 13:56:59.054 (D.M.: Zwave) General/kWh (kWh Meter)
2016-02-14 13:56:59.483 (D.M.: Zwave) Usage (Z: Pomp)
2016-02-14 13:56:59.492 (D.M.: Zwave) General/kWh (kWh Meter)
2016-02-14 13:56:59.607 (D.M. :Winddelen) General/kWh (D.M.: 3x Jonge Held)
2016-02-14 13:56:59.906 (D.M.: Zwave) Usage (Unknown)
2016-02-14 13:56:59.910 (D.M.: Zwave) General/kWh (kWh Meter)
2[b]016-02-14 13:57:00.395 LUA: Het seizoen is veranderd, het is nu Winter[/b]
2016-02-14 13:57:01.867 (D.M.: P1) P1 Smart Meter (D.M. P1: Stroom)
2016-02-14 13:57:08.099 (D.M.: Zwave) Usage (Z: Pellet)
Really great work!!!!
Thanks!!!
One question. why do i need no IDX?
A option to place your code in the wiki...
deennoo
Post by deennoo »
Hello.
There is a free API d'or this.
This not a LUA script but works great, you need to create a dummy text device.
We create it on Easydomoticz.com a Domoticz french forum.
File: saison.sh
#!/bin/bash
saison=$(curl -s "http://domogeek.entropialux.com/season")
echo $saison
if [ $saison = "autumn" ];then
saisonfr="Automne"
elif [ $saison = "winter" ];then
saisonfr="Hiver"
elif [ $saison = "spring" ];then
saisonfr="Printemps"
elif [ $saison = "summer" ];then
saisonfr="Eté"
fi
echo $saisonfr
curl "http://192.168.0.21:8080/json.htm?type= ... =$saisonfr
To finish i call it everyday with a cron.
http://domo-attitude.fr
jvdz
Post by jvdz »
Derik wrote:Jos...
Not sure where you got the girl impression from but ... No ... very Male. :)
Derik wrote:One question. why do i need no IDX?
Why use the IDX when you can use the standard LUA Event tables like specified on this WiKi page? :
https://www.domoticz.com/wiki/Events
The IDX is only needed for the special devices like when using a Sensor or Text device.
Jos
Derik
Post by Derik »
deennoo wrote:Hello.
File: saison.sh
#!/bin/bash
echo $saison
saisonfr="Automne"
saisonfr="Hiver"
saisonfr="Eté"
fi
echo $saisonfr
The option from Jos, is without any hard to get stuff...... I got him working in a few minutes....
Without cron is better for my backup...
jvdz
Post by jvdz »
Derik wrote:The option from Jos, is without any hard to get stuff...... I got him working in a few minutes....
Did you see my post above your's since we posted around the same time?
Jos
